Where did you get the camera module(s)? Arducam Technology Co. Limited
Model number of the product(s)? 12MP multi-camera kit. SKU: B0473, 327938, 102820
What hardware/platform were you working on? Nvidia Jetson agx orin devkit
Instructions you have followed. (link/manual/etc.)Quick Start Guide - Arducam Wiki for
IMX477 camera module
Installed 12MP multi-camera kit on Jetson agx orin devkit. Added one camera on slot 3.
The V4L2 shows:
$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG10' (10-bit Bayer RGRG/GBGB)
Size: Discrete 4032x3040
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3840x2160
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1920x1080
Accessing the camera kit using this commands sequence:
SENSOR_ID=0
FRAMERATE=21
width=4032
height=3040
gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=$width,height=$height,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
I got:
WARNING: erroneous pipeline: no element “nvoverlaysink”
Removed “nvoverlaysink” from pipeline:
$ gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=$width,height=$height,framerate=$FRAMERATE/1" ! nvvidconv ! nvoverlaysink
WARNING: erroneous pipeline: no element "nvoverlaysink"
kepler@jetsonDevkit2:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! "video/x-raw(memory:NVMM),width=$width,height=$height,framerate=$FRAMERATE/1" ! nvvidconv
New clock: GstSystemClock
GST_ARGUS: 4032 x 3040 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
Camera index = 0
Camera mode = 0
Output Stream W = 4032 H = 3040
seconds to Run = 0
Frame Rate = 21.000000
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: **Internal data stream error.**
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason not-linked (-1)
Execution ended after 0:00:00.798267351
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline ...
Why do I get Internal data stream error
[ 14.173250] nv_imx477: no symbol version for module_layout
[ 14.188156] imx477 30-001a: tegracam sensor driver:imx477_v2.0.6
[ 14.490685] imx477 30-001a: imx477_board_setup: error during i2c read probe (-121)
[ 14.490857] imx477 30-001a: board setup failed
[ 14.491109] imx477: probe of 30-001a failed with error -121
[ 14.491828] imx477 31-001a: tegracam sensor driver:imx477_v2.0.6
[ 14.823949] imx477 31-001a: imx477_board_setup: error during i2c read probe (-121)
[ 14.824113] imx477 31-001a: board setup failed
[ 14.824467] imx477: probe of 31-001a failed with error -121
[ 14.824929] imx477 32-001a: tegracam sensor driver:imx477_v2.0.6
[ 15.147374] imx477 32-001a: imx477_board_setup: error during i2c read probe (-121)
[ 15.156001] imx477 32-001a: board setup failed
[ 15.161425] imx477: probe of 32-001a failed with error -121
[ 15.168150] **imx477 33-001a: tegracam sensor driver:imx477_v2.0.6**
[ 15.470052] **tegra-camrtc-capture-vi tegra-capture-vi: subdev imx477 33-001a bound**
[ 15.474296] imx477 34-001a: tegracam sensor driver:imx477_v2.0.6
[ 15.776046] imx477 34-001a: imx477_board_setup: error during i2c read probe (-121)
[ 15.784661] imx477 34-001a: board setup failed
[ 15.790048] imx477: probe of 34-001a failed with error -121
[ 15.796634] imx477 35-001a: tegracam sensor driver:imx477_v2.0.6
[ 16.097603] imx477 35-001a: imx477_board_setup: error during i2c read probe (-121)
[ 16.106385] imx477 35-001a: board setup failed
[ 16.116417] imx477: probe of 35-001a failed with error -121
There is only one camera on slot 3, and it is detected by kernel.
The root cause of Internal data stream error and make the camera operational.
