Issues with 16MP AF Sync Board and CSI-HDMI Adapters
    Scorpion Vision
    B0388 - AF Quad Camera Kit for Raspberry Pi
    B0091 - CSI - HDMI Cable Extension
    RPI 4 8GB, running Bullseye
    IMX519 Multi-Camera Kit Startup - Quick Start Guide for Arducam CamArray HAT Kit - Arducam Wiki
We are attempting to run four cameras connected via CSI-HDMI adapters to the AF Quad Camera board.
  1. Problems you were having
    Image distortion, camera disconnect, timeout. We have tried various boards (changed, Pi, MultiCamera board, Cameras, and all cables - MIPI and HDMI).
    [ 0.000000] Linux version 6.1.21-v8+ (d
om@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.143495] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.149384] SCSI subsystem initialized
[ 0.149662] usbcore: registered new interface driver usbfs
[ 0.149722] usbcore: registered new interface driver hub
[ 0.149789] usbcore: registered new device driver usb
[ 0.150212] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.150430] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.150797] pps_core: LinuxPPS API ver. 1 registered
[ 0.150810] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.150836] PTP clock support registered
[ 0.151944] vgaarb: loaded
[ 0.152762] clocksource: Switched to clocksource arch_sys_counter
[ 1.320880] VFS: Disk quotas dquot_6.6.0
[ 1.320982] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.321175] FS-Cache: Loaded
[ 1.321438] CacheFiles: Loaded
[ 1.330719] NET: Registered PF_INET protocol family
[ 1.331735] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.340685] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.340827] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.340862] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.341359] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 1.343974] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.344251] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.344409] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.344921] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.345778] RPC: Registered named UNIX socket transport module.
[ 1.345795] RPC: Registered udp transport module.
[ 1.345806] RPC: Registered tcp transport module.
[ 1.345816] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.345841] PCI: CLS 0 bytes, default 64
[ 1.348539] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.348965] kvm [1]: IPA Size Limit: 44 bits
[ 1.350322] kvm [1]: vgic interrupt IRQ9
[ 1.350562] kvm [1]: Hyp mode initialized successfully
[ 1.352845] Initialise system trusted keyrings
[ 1.353229] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.360683] zbud: loaded
[ 1.363638] NFS: Registering the id_resolver key type
[ 1.363679] Key type id_resolver registered
[ 1.363690] Key type id_legacy registered
[ 1.363806] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.363823] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.365233] Key type asymmetric registered
[ 1.365253] Asymmetric key parser ‘x509’ registered
[ 1.365347] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.365645] io scheduler mq-deadline registered
[ 1.365662] io scheduler kyber registered
[ 1.367834] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.377056] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.377101] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.377189] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.377274] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
[ 1.378293] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.378313] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.378331] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.378410] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.378672] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.382616] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.382890] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.383090] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.383191] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.450867] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.451037] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.451164] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.451647] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.452385] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.452429] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.452452] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.452497] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.452519] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.453620] simple-framebuffer 3eace000.framebuffer: framebuffer at 0x3eace000, 0x12c000 bytes
[ 1.453641] simple-framebuffer 3eace000.framebuffer: format=a8r8g8b8, mode=640x480x32, linelength=2560
[ 1.454143] Console: switching to colour frame buffer device 80x30
[ 1.455418] simple-framebuffer 3eace000.framebuffer: fb0: simplefb registered!
[ 1.468877] iproc-rng200 fe104000.rng: hwrng registered
[ 1.469513] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.471175] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.484458] brd: module loaded
[ 1.493420] loop: module loaded
[ 1.494302] Loading iSCSI transport class v2.0-870.
[ 1.499860] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.560925] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.562113] usbcore: registered new interface driver r8152
[ 1.562191] usbcore: registered new interface driver lan78xx
[ 1.562251] usbcore: registered new interface driver smsc95xx
[ 1.609854] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.610035] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.610068] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.610787] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ 1.611875] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.611898] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.611920] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.612299] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.612320] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.612336] usb usb1: Product: xHCI Host Controller
[ 1.612349] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.612362] usb usb1: SerialNumber: 0000:01:00.0
[ 1.613149] hub 1-0:1.0: USB hub found
[ 1.613219] hub 1-0:1.0: 1 port detected
[ 1.614193] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.614215] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.614230] usb usb2: Product: xHCI Host Controller
[ 1.614243] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.614256] usb usb2: SerialNumber: 0000:01:00.0
[ 1.614958] hub 2-0:1.0: USB hub found
[ 1.615055] hub 2-0:1.0: 4 ports detected
[ 1.616927] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.617295] dwc_otg: FIQ enabled
[ 1.617306] dwc_otg: NAK holdoff enabled
[ 1.617316] dwc_otg: FIQ split-transaction FSM enabled
[ 1.617333] Module dwc_common_port init
[ 1.617916] usbcore: registered new interface driver uas
[ 1.618035] usbcore: registered new interface driver usb-storage
[ 1.618259] mousedev: PS/2 mouse device common for all mice
[ 1.625120] sdhci: Secure Digital Host Controller Interface driver
[ 1.625140] sdhci: Copyright(c) Pierre Ossman
[ 1.625885] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.629761] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.630197] hid: raw HID events driver (C) Jiri Kosina
[ 1.630380] usbcore: registered new interface driver usbhid
[ 1.630394] usbhid: USB HID core driver
[ 1.639477] NET: Registered PF_PACKET protocol family
[ 1.639614] Key type dns_resolver registered
[ 1.641379] registered taskstats version 1
[ 1.641473] Loading compiled-in X.509 certificates
[ 1.642369] Key type .fscrypt registered
[ 1.642384] Key type fscrypt-provisioning registered
[ 1.658465] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.659220] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.659374] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.668585] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.669548] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.670943] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.670963] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.700930] of_cfs_init
[ 1.701110] of_cfs_init: OK
[ 1.737913] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.738263] Waiting for root device PARTUUID=68a65737-02…
[ 1.785036] mmc1: new high speed SDIO card at address 0001
[ 1.838046] mmc0: new ultra high speed DDR50 SDXC card at address 59b4
[ 1.839094] mmcblk0: mmc0:59b4 USD00 58.9 GiB
[ 1.842287] mmcblk0: p1 p2
[ 1.842865] mmcblk0: mmc0:59b4 USD00 58.9 GiB
[ 1.862081] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.862203] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.867740] devtmpfs: mounted
[ 1.872836] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.876526] Freeing unused kernel memory: 4160K
[ 1.876939] Run /sbin/init as init process
[ 1.876952] with arguments:
[ 1.876961] /sbin/init
[ 1.876971] splash
[ 1.876980] with environment:
[ 1.876989] HOME=/
[ 1.876998] TERM=linux
[ 2.023454] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.023493] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.023510] usb 1-1: Product: USB2.0 Hub
[ 2.025952] hub 1-1:1.0: USB hub found
[ 2.026289] hub 1-1:1.0: 4 ports detected
[ 2.274546] systemd[1]: System time before build time, advancing clock.
[ 2.320876] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
[ 2.429796] usb 1-1.1: New USB device found, idVendor=05ac, idProduct=1006, bcdDevice=96.15
[ 2.429836] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.429853] usb 1-1.1: Product: Keyboard Hub
[ 2.429867] usb 1-1.1: Manufacturer: Apple, Inc.
[ 2.429881] usb 1-1.1: SerialNumber: 000000000000
[ 2.431639] hub 1-1.1:1.0: USB hub found
[ 2.431772] hub 1-1.1:1.0: 3 ports detected
[ 2.456901] NET: Registered PF_INET6 protocol family
[ 2.458806] Segment Routing with IPv6
[ 2.458871] In-situ OAM (IOAM) with IPv6
[ 2.534903] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.535918] systemd[1]: Detected architecture arm64.
[ 2.542432] systemd[1]: Set hostname to .
[ 2.720898] usb 1-1.1.2: new low-speed USB device number 4 using xhci_hcd
[ 2.830156] usb 1-1.1.2: New USB device found, idVendor=05ac, idProduct=0221, bcdDevice= 0.71
[ 2.830196] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.830213] usb 1-1.1.2: Product: Apple Keyboard
[ 2.830227] usb 1-1.1.2: Manufacturer: Apple, Inc
[ 2.920811] usb 1-1.1.3: new low-speed USB device number 5 using xhci_hcd
[ 3.028947] usb 1-1.1.3: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 3.028982] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.028998] usb 1-1.1.3: Product: USB Optical Mouse
[ 3.029011] usb 1-1.1.3: Manufacturer: PixArt
[ 3.038378] input: PixArt USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/0003:093A:2510.0003/input/input0
[ 3.038930] hid-generic 0003:093A:2510.0003: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:01:00.0-1.1.3/input0
[ 3.115791] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.250935] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.270479] systemd[1]: Created slice system-getty.slice.
[ 3.271810] systemd[1]: Created slice system-modprobe.slice.
[ 3.272877] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.273723] systemd[1]: Created slice User and Session Slice.
[ 3.274252] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.275343] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.275804] systemd[1]: Reached target Slices.
[ 3.275947] systemd[1]: Reached target Swap.
[ 3.277018] systemd[1]: Listening on Syslog Socket.
[ 3.277736] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.278154] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.279362] systemd[1]: Listening on Journal Audit Socket.
[ 3.280165] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.281190] systemd[1]: Listening on Journal Socket.
[ 3.283298] systemd[1]: Listening on udev Control Socket.
[ 3.284141] systemd[1]: Listening on udev Kernel Socket.
[ 3.285222] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.309281] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.314393] systemd[1]: Mounting RPC Pipe File System…
[ 3.320321] systemd[1]: Mounting Kernel Debug File System…
[ 3.326588] systemd[1]: Mounting Kernel Trace File System…
[ 3.327142] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.336217] systemd[1]: Starting Restore / save the current clock…
[ 3.344813] systemd[1]: Starting Set the console keyboard layout…
[ 3.351043] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.357283] systemd[1]: Starting Load Kernel Module configfs…
[ 3.363928] systemd[1]: Starting Load Kernel Module drm…
[ 3.370218] systemd[1]: Starting Load Kernel Module fuse…
[ 3.373244] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.379529] systemd[1]: Starting File System Check on Root Device…
[ 3.390610] systemd[1]: Starting Journal Service…
[ 3.400126] systemd[1]: Starting Load Kernel Modules…
[ 3.405972] systemd[1]: Starting Coldplug All udev Devices…
[ 3.441137] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.442141] systemd[1]: Mounted RPC Pipe File System.
[ 3.442934] systemd[1]: Mounted Kernel Debug File System.
[ 3.443080] fuse: init (API version 7.37)
[ 3.443785] systemd[1]: Mounted Kernel Trace File System.
[ 3.456928] systemd[1]: Finished Restore / save the current clock.
[ 3.465209] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.467674] systemd[1]: [email protected]: Succeeded.
[ 3.469764] systemd[1]: Finished Load Kernel Module configfs.
[ 3.478665] systemd[1]: [email protected]: Succeeded.
[ 3.483583] systemd[1]: Finished Load Kernel Module fuse.
[ 3.505567] i2c_dev: i2c /dev entries driver
[ 3.513440] systemd[1]: Mounting FUSE Control File System…
[ 3.525397] systemd[1]: Mounting Kernel Configuration File System…
[ 3.533286] systemd[1]: Started File System Check Daemon to report status.
[ 3.550608] systemd[1]: Finished Load Kernel Modules.
[ 3.560555] systemd[1]: Mounted FUSE Control File System.
[ 3.561952] systemd[1]: Mounted Kernel Configuration File System.
[ 3.569891] systemd[1]: Starting Apply Kernel Variables…
[ 3.573154] systemd[1]: [email protected]: Succeeded.
[ 3.574938] systemd[1]: Finished Load Kernel Module drm.
[ 3.651459] systemd[1]: Finished Apply Kernel Variables.
[ 3.679214] systemd[1]: Finished File System Check on Root Device.
[ 3.706356] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.815363] systemd[1]: Started Journal Service.
[ 3.859550] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 3.935122] systemd-journald[143]: Received client request to flush runtime journal.
[ 3.943998] systemd-journald[143]: File /var/log/journal/61697359f3f642319ba654f48bad4835/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.055748] mc: Linux media interface: v0.10
[ 5.131602] videodev: Linux video capture interface: v2.00
[ 5.355545] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.367081] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.367124] [vc_sm_connected_init]: start
[ 5.368219] [vc_sm_connected_init]: installed successfully
[ 5.380436] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.383544] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.403955] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.460461] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.479624] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.503716] i2c i2c-22: Added multiplexed i2c bus 10
[ 5.616005] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.623041] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.674440] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.686134] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.747172] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.759529] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.775171] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.775410] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.790955] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 5.800936] rpivid feb10000.codec: Device registered as /dev/video19
[ 5.801139] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.801184] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.807524] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.813754] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.813831] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.823365] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.823464] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.841134] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.841214] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.849905] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 5.850008] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 5.854354] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.855699] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.856473] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.857048] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.857087] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.857111] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.857129] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.857145] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.884621] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.885434] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.889928] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.905928] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.905993] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.906018] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.906037] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.906080] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.923988] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.077763] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.313307] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.327079] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.442842] usbcore: registered new interface driver brcmfmac
[ 6.501292] Console: switching to colour dummy device 80x25
[ 6.555482] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.632594] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 6.735701] Registered IR keymap rc-cec
[ 6.769810] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 6.893272] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 6.983471] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.091992] Registered IR keymap rc-cec
[ 7.092251] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.092506] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input2
[ 7.106788] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.107421] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.107925] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.108375] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.115961] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.116384] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.175598] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.370507] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.477674] Console: switching to colour frame buffer device 80x30
[ 7.477787] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 7.640448] input: Apple, Inc Apple Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:05AC:0221.0001/input/input3
[ 7.739621] apple 0003:05AC:0221.0001: input,hidraw1: USB HID v1.11 Keyboard [Apple, Inc Apple Keyboard] on usb-0000:01:00.0-1.1.2/input0
[ 7.757402] apple 0003:05AC:0221.0002: Fn key not found (Apple Wireless Keyboard clone?), disabling Fn key handling
[ 7.757924] input: Apple, Inc Apple Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:05AC:0221.0002/input/input4
[ 7.860034] apple 0003:05AC:0221.0002: input,hidraw2: USB HID v1.11 Device [Apple, Inc Apple Keyboard] on usb-0000:01:00.0-1.1.2/input1
[ 7.928407] ak7375 10-000c: supply vio not found, using dummy regulator
[ 8.179571] imx519 10-001a: Device found is imx519
[ 8.184313] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 8.505333] uart-pl011 fe201000.serial: no DMA platform data
[ 8.646828] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.982477] 8021q: 802.1Q VLAN Support v1.8
[ 9.481593] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.762186] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.763681] bcmgenet fd580000.ethernet eth0: Link is Down
    We have tried new installs, changing hardware, but cannot get this setup working reliably without drop-outs, quality issues.
  2. What help do you need?
    Advice on what to do to get this working. We are trying to build a fleet of camera systems using this setup and see that CSI-HDMI adapters, with these multiple-camera boards should be possible. This is a very urgent request for help.
#cameras-for-raspberry-pi:sync-stereo-camera-hat #cameras-for-raspberry-pi:mipi-camera-modules #imx519
Are you using the four same HDMI cables?
Hi Dion - yes we are using the same HDMI cables for all. We have tried with different makes of HDMI cable too, but with the same behaviour.
@Dion Do you have any suggestions?
Hi @otills
For this case, 4 cameras + 4 HDMI extension kits, is a customized project at first. There was a difference in opinion on this case between me and our Technical Documentation Engineer. I strongly suggested deleting this solution from the DOC because it is not universal. Otherwise, other customers may face a difficult situation that they cannot resolve. (BTW, you are currently experiencing this situation.)
Here are our suggestions for your dilemma:
