Trying to use the OV9281-B0225 Rev. B (1MP OV9281 Mono Global Shutter MIPI Camera Module with M12 Mount lens for Raspberry Pi - Arducam) with Pi Zero 2W and RasPi OS lite over SSH. Running into setup problems while following Arducam setup guide, ls /dev/video0 confirms the camera is connected but trying to capture with the camera through V4L2 throws errors UNTIL libcamera-still is run (must be done after each reboot).
Uctronics -
Model number of the product(s).
OV9281-B0225 -
RPI Zero 2W and 4B -
Wiki install instructions on Arducam website (OV9281 1MP Global Shutter Camera for Raspberry Pi - Arducam) -
Problems you were having.
Module is detected (ls /dev/video0), but camera doesn’t respond to capture using V4L2 UNLESS libcamera-still is run first. Capture only works when quantization=full range in V4L2 format video capture; this parameter cannot be set through the terminal directly. When trying “v4l2-ctl --stream-mmap --stream-count=-1 -d /dev/video0 --stream-to=/dev/null” returns “VIDIOC_STREAMON returned -1 (Invalid argument)” -
The dmesg log from your hardware.
Best way to attach? -
Troubleshooting attempts you’ve made.
New ribbon cable, new Pi (changed from Zero 2W to Pi4B), new micro sd card, reformat/reinstall all software with fresh OS, tried both Pi OS full and lite, tried another camera (I ordered 2). See 5) for other steps. -
Need assistance configuring camera for capture without running libcamera-still. Suggestions for processing Y10P format data in python is also appreciated, thank you!
