Is there a cable that connects both the IMX708 SKU:B0312 and the raspberry pi 5?
    Amazon
    IMX708 SKU:B0312
    Raspberry pi 5
    User instruction manual
  5. Problems you were having?
    The camera cable provided has a smaller 22 pin end that fits into the raspberry pi 5’s 2 four-lane MIPI connectors, but that same 22 pin end is also the one that needs to fit into the raspberry pi IMX708 camera. All cables online are 22 pin to 15 pin, including the one provided, so the larger 15 pin side doesn’t fit into either end. Is the IMX708 SKU: B0312 incompatible with the pi5 then? Are there 22 pin - 22 pin cables out there? Maybe I’m putting it in wrong?
    N/A
  • Bought a replacement cable
  • Asked on reddit
  • Watched youtube videos/tutorials with the cables
  1. What help do you need?
  • Information about the cables
We should put a 22-22 pin white FFC in the package with the camera module.
You didn’t receive it, did you? If so, plz DM me with the order number and we will arrange a replacement asap.
Thanks for the response! I got one today and it seems to plug in ok.
The issue is now I’m getting ERROR: *** no cameras available *** even though I’ve plugged it in pretty snugly. I can get video from a USB webcam but not the pi camera unfortunately. I’ve tried a lot of fixes.
When I did dmesg | grep -i imx
I got
[ 3.508460] imx708 11-001a: failed to read chip id 708, with error -5
which suggests some kind of connection problem I think.
Thank you for your feedback.
The cable orientation here is reversed. Try to disconnect the cable, flip it over, and reconnect.
Thank you for your help so far. If I flip the orientation, as in the photo, the Raspberry Pi light turns red and can’t be started. This is likely due to the orientation being incorrect. If I flip the other end too, it turns green again and I can start my Pi, but I have the same “camera not found” issue.
I think I might have done something wrong with the camera itself, maybe that I fully took the grey plastic tab out when I got it. I can fit it back in snugly but it comes out fully if I pull on it. Maybe the 22 pin - 22 pin doesn’t work, and it wants a 15 pin input. I might just order another V2 camera to see if that works instead
Thanks again for helping me!
Daniel
Hi Daniel,
I take it you are using a type A FFC. Let me tell you the difference between type A and type B FFC.
  • Type A FFC: In a Type A FFC, the electrical contacts on both ends of the cable are on the same side . If you were to lay the cable flat, the exposed contacts at both terminations would be facing either upwards or downwards simultaneously.
  • Type B FFC: In a Type B FFC, the electrical contacts on either end of the cable are on opposite sides. If the contacts on one end are facing upwards, the contacts on the other end will be facing downwards. This effectively creates a “flipped” connection between the two boards it connects
If you use a Type A FFC where an opposite-side contact cable is expected, the pinout will be effectively reversed at one end of the connection. This means that the electrical signals intended for specific pins on the camera module will be sent to the wrong pins, and vice versa.
This incorrect pin mapping due to the mismatched FFC type can lead to several critical issues during the Raspberry Pi’s boot process:
  1. Incorrect Signal Communication: The MIPI camera interface relies on precise high-speed data and clock signals. With a Type A cable in a system expecting an opposite-side contact cable, these signals will not reach their intended destinations on either the Raspberry Pi or the camera module, disrupting communication.
  2. Power and Ground Issues: Crucially, power and ground connections will also be misaligned. This could lead to the camera module not receiving power correctly, or worse, could cause a short circuit by connecting power to ground pins or data pins, which can prevent the Raspberry Pi from starting up to protect itself from damage.
  3. Failure of Camera Detection: The Raspberry Pi’s firmware checks for the presence and proper functioning of the camera module during boot. If the electrical connection is incorrect due to the wrong FFC type, the camera will not be detected, triggering a boot failure.
At this point, I recommend buying a type B FFC to check if it’s working as expected. Here is the product link:
https://www.amazon.com/Arducam-Raspberry-Camera-Interface-Flexible/dp/B0CFPMD1DM?ref_=ast_sto_dp
Hi Dion,
Thank you again for your help. I will look for a type B FFC to purchase
All the best,
Daniel
I ended up getting the same error (libcamera-hello → *** no cameras available ***) with the type B FFC cable. I tried the other orientations too and they didn’t work. I tried it with a new v3 camera and had the same issue. I also have the shield and foam on the camera from when I bought it, does removing that affect anything? This can be seen on the camera lens in the first photo. Maybe I should try a v2 instead?
Keep these orientations unchanged.
You connect the camera module to the cam0 port on Pi 5, which means you need to add dtoverlay=imx708,cam0 in the config.txt file.
Worked perfectly! Thanks!
