SOS Solutions Netherlands -
Arducam ToF camera Rev. B -
Raspberry Pi 4B 4Gb -
according to website/pdf/github -
Error after installation:
open WARNING Could not open device node /dev/video0. Please check for permissions.
initialization failed -
Happy to provide if needed. -
Troubleshooting attempts youâve made?
To exclude HW issues I re - inserted Buster OS, than it worked fine, so no defect camera. So it must be the settings or Bookworm OS specifics, not sure where to start. See below for result of ls /dev/video* -
Please provide a solution for the initialisation problem in Bookworm 64 bit.
If I check with ls /dev/video* I get:
/dev/video10 /dev/video13 /dev/video16 /dev/video20 /dev/video23
/dev/video11 /dev/video14 /dev/video18 /dev/video21 /dev/video31
/dev/video12 /dev/video15 /dev/video19 /dev/video22
I used a fresh install of Bookworm 64 bit, I commented camera_auto_detect=0 out. So config.txt setting seems to be the same as with Buster (the working version).
