Install_full.sh cannot find matching .deb for 64MP autofocus module on Jetson AGX Xavier
Hi everyone,
I’m trying to get the 64MP autofocus camera module working on my NVIDIA Jetson AGX Xavier. I ran the install_full.sh script but it fails pretty quickly. The error says it can’t find a matching .deb driver package for my system.
Here’s the output I’m seeing:
Has anyone run into this before? Not sure if I missed a prerequisite step or if there’s a compatibility issue I’m not aware of.
Thanks for posting that screenshot — that helps narrow things down. Could you share a few more details about your environment? Specifically, what kernel version are you running on the Jetson? You can grab that by running:
uname -r
That’ll help me check whether there’s a matching driver package for your setup.
Sure, here’s what I get:
$ uname -r
4.9.201-tegra-32.5.1-20210219084708
This is on a stock AGX Xavier dev kit, JetPack 4.5.1 I believe, based on that L4T version string.
Alright, I’ve looked into this and unfortunately the news isn’t great.
The 64MP autofocus module does not support the NVIDIA Jetson AGX Xavier platform. There is no driver package built for the combination of kernel 4.9.201-tegra-32.5.1-20210219084708 and the Jetson AGX Xavier board — which is why install_full.sh couldn’t find anything. It’s not a missing dependency or a script bug; the driver simply doesn’t exist for this platform/kernel pairing.
Ah, that’s disappointing. Is there any workaround for this? Maybe compiling the driver from source, or using a different kernel version that does have a matching package?
I completely understand the frustration. Unfortunately, there’s no workaround available here — the 64MP autofocus camera module has a hard platform limitation when it comes to the Jetson AGX Xavier. There’s no alternative driver package, no source tree to compile against, and no other kernel version supported on that hardware that would resolve it.
To summarize: the 64MP autofocus module is not compatible with the NVIDIA Jetson AGX Xavier, and this is a known platform limitation. If you’re looking for a high-res camera module for that board, you’d need to explore other options designed for the Jetson ecosystem.
