Increasing the frame_timeout Limit for the Arducam AR0234 Camera on Jetson Orin Nano
I am working on a Jetson Orin Nano board with the following specifications:
  • Model: NVIDIA Orin Nano Developer Kit - Jetpack 5.1.2 [L4T 35.4.1]
  • Platform Distribution: Ubuntu 20.04 focal
  • Kernel Release: 5.10.120-tegra
I downloaded the necessary libraries by following the instructions on the Arducam Quick Start Guide, then cloned the git repo from Arducam MIPI Camera GitHub. I tested my camera, and it works well.
However, I have some unclear points regarding the frame_timeout and disable_frame_timeout parameters:
  1. What is the unit of measurement for frame_timeout?
  2. What does disable_frame_timeout do when it is set to 0 versus when it is set to 1?
When I run the command v4l2-ctl -d /dev/video0 --all, I see this section:
Plaintext exposure 0x00980911 (int) : min=2 max=65535 step=1 default=700 value=10 horizontal_flip 0x00980914 (bool) : default=0 value=0 vertical_flip 0x00980915 (bool) : default=0 value=0 trigger_mode 0x00981901 (bool) : default=0 value=1 disable_frame_timeout 0x00981902 (bool) : default=0 value=0 frame_timeout 0x00981903 (int) : min=100 max=12000 step=1 default=2000 value=12000 frame_rate 0x00981906 (int) : min=5 max=60 step=1 default=60 value=60
I notice that frame_timeout cannot be set higher than 12000. This feels very restrictive, especially if the unit is in microseconds (which I suspect it might be).
My Goal: I want to know how to increase this maximum limit. If that is not possible, what alternative solutions can I follow?
