Hi everyone, I’m running into a weird issue with my Arducam 12MP IMX708 USB UVC Fixed-Focus Camera Module (it’s the B0304-1, 3-standard module version). When I plug the camera into my Raspberry Pi 4B via the MIPI ribbon connector, I get access to a ton of fine-grained camera controls through libcamera/V4L2 — autofocus, exposure modes, lens position, AWB, digital gain, the whole lot. But when I use the same module over USB in UVC mode, almost none of those controls show up. Running v4l2-ctl --list-ctrls over USB gives me maybe 5-6 generic controls and that’s it. Has anyone else hit this? Is there some trick to getting the full control set exposed through the USB connection?
Welcome! This is actually something that trips up a lot of people with UVC camera modules. Before we dig in, could you share a few more details about your setup? Which Pi model and OS are you on? And could you list out the specific controls you need that are present over MIPI but missing over USB? That’ll help narrow things down.
Yeah absolutely. Here’s the full rundown:
- Raspberry Pi 4B, Raspberry Pi OS Bookworm
- Arducam 12MP IMX708 USB UVC Fixed-Focus Camera Module
These are the controls I can set via MIPI/libcamera that I really need:
Digital gain:
–camera-isp.options=digital_gain=1000
Autofocus:
–camera-options=AfMode=0
–camera-options=AfSpeed=0
–camera-options=AfRange=2
–camera-options=AfMetering=1
Lens position:
–camera-options=LensPosition=0.75
Auto exposure:
–camera-options=AeEnable=1
–camera-options=AeMeteringMode=1
–camera-options=AeFlickerMode=0
–camera-options=AeExposureMode=1
–camera-options=AeConstraintMode=1
Exposure:
–camera-options=ExposureTimeMode=1
–camera-options=ExposureValue=0.8
AWB:
–camera-options=AwbEnable=1
–camera-options=AwbMode=0
I’ve been comparing MIPI vs USB side by side. Over MIPI, v4l2-ctl --list-ctrls dumps pages of controls. Over USB, I get brightness, contrast, saturation, and not much else. The autofocus, lens position, exposure metering, AWB modes — all completely absent.
Thanks for the detailed list — that confirms exactly what’s happening. Here’s the root cause:
The UVC (USB Video Class) specification defines a fairly narrow set of standard controls — brightness, contrast, saturation, white balance temperature, and a handful of others. That’s it. When your IMX708 module is connected via MIPI, libcamera talks directly to the sensor’s ISP and exposes the full internal control set: AF modes, lens position, exposure metering algorithms, AWB modes, digital gain, flicker compensation, all of it.
But when you connect over USB, the onboard bridge chip presents the module as a standard UVC device. It doesn’t — and frankly can’t — map those extended ISP-level controls into the UVC control space because the UVC spec simply has no standard definitions for them. So they just don’t appear in the V4L2 control list.
This isn’t a defect in your module. It’s an architectural limitation of UVC versus a direct MIPI + libcamera stack.
That said, there is a path around this. Arducam has an approach that uses OpenCV to reach controls beyond what standard V4L2/UVC exposes on their USB modules. The OpenCV integration can communicate through vendor-specific extensions on the USB pipe, essentially bypassing the limited UVC control set.
Oh that’s interesting — I hadn’t even considered OpenCV as a path to the controls. I’ve been stuck in the v4l2-ctl / V4L2 ioctl mindset this whole time. A couple questions: how exactly does OpenCV reach controls that the V4L2 driver can’t see? Also, is this a Windows-only thing, or will it work on the Pi? The last thing I want is to chase a solution that only works on x86.
The OpenCV path works differently from the standard V4L2 UVC driver. Instead of going through the kernel’s UVC class driver — which is what limits you to the spec-defined control set — the OpenCV integration from Arducam communicates with the camera’s internal control interface through USB vendor-specific protocols. It essentially reaches the same ISP-level controls that libcamera exposes over MIPI, just through a different transport.
And no, it’s not Windows-only. I’ve sent you the relevant Arducam documentation link through private message — check your inbox. The page title mentions Windows, but don’t let that throw you off; the OpenCV approach is platform-independent and the same concepts apply on Raspberry Pi.
One important thing to keep in mind: you’ll likely need Arducam’s OpenCV extensions or SDK rather than plain upstream OpenCV. A standard cv2.VideoCapture alone won’t magically expose these extra controls — the vendor-specific plumbing is what makes it work. Worth following the demo code in the docs closely to see how they’re initializing the camera handle.
