IMX519 Quad Kit cameras won't work individually on Raspberry Pi Zero 2W
Hi, hoping someone can help. I’ve got a set of IMX519 autofocus cameras that I’m trying to use on a Raspberry Pi Zero 2W. I never got any of them to work on their own. I followed the guide in the ‘Pi Zero 2W and 16MP IMX519 - no cameras available’ thread and I still get the same thing - nothing detected. I’m trying to run them as stand-alone cameras (not on the quad hat). Is that even possible? For context I’m setting this up in a lab for a surround-vision system and I eventually want 16 cameras, so I need the full 16MP resolution. Any pointers appreciated.
Welcome. Quick clarification so we point you at the right thing: are these IMX519 modules from the Quad-Camera bundle kit, or the standard single-camera version? The guide in the Pi Zero 2W thread is written for a single standard IMX519. The four cameras that ship with the quad hat are a different build - they’re designed to run together on a shared clock, and they aren’t meant to be used individually. That usually explains the ‘no cameras available’ result.
Ah, right - yes, they came out of the quad kit. I assumed I could just take one off and use it like a normal camera module. Can you explain what’s actually different about them? On the Pi Zero 2W with a single one attached I get:
libcamera-hello --list-cameras
No cameras available!
dmesg doesn’t show any sensor probing, and i2cdetect -y 1 shows nothing on the usual 0x1a/0x36 addresses. So it looks like it’s just never enumerated at all.
That matches what we see for the quad-version boards. The difference is on the hardware side: the four cameras in the kit share a clock line and are meant to be driven simultaneously, so there isn’t a single-camera enable path in the same way. Whichever one you attach on its own won’t get detected by the Pi, which is why you see no cameras available and nothing on the i2c bus. This isn’t a software/config issue - no amount of dtoverlay tweaking will bring up a single quad-kit board. We did post a notice about this on the Kickstarter update page so it should have been clearer on the sales page, apologies for that.
OK that explains a lot, thanks. So is there any way at all to make these work one at a time? I only need to trial a couple singly for now before I scale up. Otherwise I’m a bit stuck.
There is - it’s a hardware modification, not a software one. You only need to move the resistor on the board to a different position (same component, just relocated - no part swap). Once it’s moved, the board can operate as a stand-alone camera. One warning: the part is tiny and in an awkward spot right next to the connector, so it needs a steady hand and a proper workstation. I’ve sent you the markings/close-up through private message so you can see exactly which one to move.
Update after the weekend: I took them to a proper workshop and we attempted the resistor move on all four. Good news - we successfully repositioned the resistor on two of them and they now come up fine individually, and honestly the image quality is great. Bad news - on the other two we damaged something during the rework and they no longer show up at all. They’re just dead on the bus, same ‘No cameras available!’. The element really is small and the location makes it easy to knock. Is there anything we can check on the two that died, or any alternative path to using them stand-alone that doesn’t involve this rework? Happy to share photos of the damaged boards if that helps.
Nice work getting two of them going - that’s exactly the expected result, and it confirms the boards themselves are fine once the resistor is moved. On the two that aren’t detected: this is the failure mode we warn about with this rework. If the resistor was knocked off or shifted, or a pad lifted, the board won’t enumerate and there’s no software fix for that - it won’t appear on i2c and libcamera will never see it. Two things worth checking: (1) look under magnification at whether the resistor is still correctly seated on the new pads, and (2) check for bridged or lifted pads around it. If a pad is gone, unfortunately that board is not recoverable without board-level rework. Please do share the photos and I’ll take a look.
Here are the close-ups of the two dead boards - the resistor looks like it’s sat slightly off the pad on one and there might be a lifted pad on the other. Sounds like that matches your call. One separate question while I’m here: I’m also looking at integrating an Arducam into a digital microscope in the lab sometime over the next year. Is there a platform/module you’d recommend that can actually be mounted on a microscope?
Thanks for the photos - yes, the one with the lifted pad is the problem, that’s not coming back without proper board-level rework. To summarise where we are on the main issue:
  • Root cause: the IMX519 modules from the quad kit are hardware-differentiated (shared clock, intended to run together), so a single one will never be detected on its own - you get ‘No cameras available!’ and nothing on i2c.
  • Workaround that works: the resistor-reposition hardware modification. Two of your four boards are now confirmed working stand-alone with good image quality.
  • The modification is delicate and the two remaining boards were damaged during rework, so they won’t enumerate - that’s a hardware fault, not a software one, and there’s no driver/config workaround.
For anything that needs a stand-alone single camera going forward, use the standard (non-quad) version of the module - that’s the one the Pi Zero 2W thread applies to. On the microscope question, I’ll follow up with specifics on mounting options.
