IMX519 not listed in Arducam Serial Tool, video device not found
I’m trying to change the USB serial numbers on my Arducam cameras but running into a wall here. I’ve got 6 of the Arducam 16MP IMX519 UVC camera modules, model B0471C. Downloaded the ArducamUVCSerialNumber tool from the official site (the ArducamUVCSerialNumber_Official.zip from their downloads page), but when I launch it, the IMX519 doesn’t appear as an option in the dropdown at all. Instead, I just get an error: “Can’t find video device!”
The cameras themselves seem fine though — they show up and work normally in OBS Studio on the same machine. So the hardware isn’t dead, the tool just can’t see them. I ran lsusb and noticed the bcdDevice shows 0.00, which seems suspicious. Could that be related? Anyone run into this before?
Good catch on the bcdDevice. Can you paste the full lsusb line for one of the cameras? Just want to confirm the USB ID and revision together.
Yeah, here it is:
Bus XXX Device XXX: ID 04b4:0471 Cypress Semiconductor Corp. bcdDevice 0.00
All 6 cameras show the exact same thing — bcdDevice 0.00 across the board. I was already leaning toward that being the problem since it looks like there’s no firmware revision being reported at all.
That confirms it. The bcdDevice 0.00 means the UVC firmware on these modules is either blank or corrupted — basically there’s no valid firmware revision being reported to the host.
The ArducamUVCSerialNumber tool depends on the firmware to properly enumerate and identify the device. When the firmware revision is 0.00, the tool has no way to recognize the camera as an IMX519, which is why it doesn’t show up in the dropdown and throws “Can’t find video device!” — even though the basic UVC video stream still works fine in apps like OBS. That raw video pipeline doesn’t need the same level of firmware handshaking.
The fix is to flash the proper firmware onto the modules first. I’ve sent you a private message with the UVC 3.0 Modification package — it includes the flasher tool and the correct .bin firmware file, along with step-by-step instructions for the update process. Once the firmware is properly flashed, the bcdDevice will report a valid revision and the serial number tool should pick up all your cameras.
That did the trick! Flashed all 6 cameras following the instructions you sent and now the ArducamUVCSerialNumber tool picks them up without any issues. bcdDevice is showing a proper revision now too. Was able to set unique serial numbers on all of them. Thanks a ton for the help!
Glad it’s sorted! For anyone else who stumbles on this thread with the same issue — if you have the B0471C (IMX519 UVC) modules and the ArducamUVCSerialNumber tool can’t find your video device, check lsusb for bcdDevice 0.00. That’s the telltale sign the firmware needs to be flashed. The UVC 3.0 Modification package with the flasher and firmware binary will get things back on track. Feel free to reach out if you run into anything else.
