IMX519 camera kit not detected on Raspberry Pi (chip id read error)
Hey everyone, I’m struggling to get the B0388 16MP IMX519 Autofocus Synchronized Quad-Camera Kit working with my Raspberry Pi. I’m running what I think is Bookworm, because when I go into raspi-config, the “Enable Glamor graphic acceleration” and “GL Driver” / “GL (Full KMS)” options are completely missing from the Advanced Options menu. I followed all the steps in the getting started guides but no luck. I was about to just wipe everything and do a fresh OS install. Anyone run into this?
Before you go down the fresh install route, let’s get some diagnostic info first — that might save you a lot of time. Can you run this command and paste the output here?
dmesg | grep imx519
Also, just to put your mind at ease about the raspi-config thing — those missing Glamor and GL Driver options are completely normal on Bookworm. Those settings only existed in the older Bullseye release, so nothing is wrong with your OS there.
Ah, that’s a relief about the GL options — I was going crazy thinking my raspi-config was broken or something. Here’s the dmesg output:
imx519 10-001a: failed to read chip id 519, with error -5
Not sure what error -5 means but it doesn’t look great.
Thanks for that. That error — failed to read chip id 519, with error -5 — is actually very telling. It means the Pi can’t even talk to the camera sensor over the I2C/CSI bus at a hardware level. Error -5 in this context is an I/O error, which means the kernel is trying to communicate with the device at address 0x1a on I2C bus 10 and getting nothing back.
This is almost never a software problem. The most common cause with these quad-camera kits — and I mean by far the most common — is that the ribbon cable between the camera HAT and the Raspberry Pi’s main CSI port is inserted upside down.
It’s really easy to do because the blue tab orientation can be confusing depending on which side of the cable you’re looking at. Can you check the physical connections? Even better, could you take a couple of photos:
  1. A close-up of the ribbon cable connection between the camera HAT and the Pi’s CSI port — make sure the blue tab orientation is clearly visible at both ends.
  2. A photo of the Raspberry Pi’s CSI port itself after gently unplugging the HAT — just to rule out any bent pins or debris in the connector.
You nailed it. I took the cable out to take the photos and immediately realized what was wrong — the ribbon cable between the Arducam HAT and the Pi’s CSI port was inserted 180 degrees reversed. Completely upside down. I must have looked at it a dozen times before and it just never clicked.
Flipped it around the right way, reseated everything, and now all four cameras are working perfectly. The imx519 error is gone from dmesg too. Thanks for saving me from an unnecessary OS reinstall!
Great to hear! Yeah, that cable orientation trick catches almost everyone at least once — the way the blue tabs face on each end can be really counterintuitive. Glad it was an easy fix in the end.
Now that everything is working, I have a follow-up question — how do I target or address a single camera individually? Right now it seems like all four are being treated as one. I need to be able to capture from just camera 2 or just camera 3, not always all four simultaneously. Is there a way to do that?
What you’re looking for is the switch composition mode feature. It lets you address each camera channel independently rather than capturing from all four at once. The documentation covers it pretty well here:
https://docs.arducam.com/Raspberry-Pi-Camera/Multi-Camera-CamArray/quick-start/#switch-composition-mode
Essentially you’ll use libcamera’s camera selection to pick individual channels. The exact syntax depends on whether you’re using libcamera-still, libcamera-vid, or the Python bindings, but the docs walk through it for each case.
That switch composition mode is exactly what I needed — nice and simple. I’m going to go ahead and integrate this into my custom hardware setup now. Thanks again for all the help!
