Hey everyone, I’m trying to get an Arducam IMX519 working on my Jetson Orin Nano Engineering Reference Developer Kit Super. I ran the driver installation script from Arducam’s repo and it failed with this error:
The script detected my system info but couldn’t find a matching .deb package. Here are the details it pulled:
Jetson Type: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
Has anyone run into this before? The camera doesn’t show up at all after running the script. Not sure if there’s a workaround or if I’m missing something obvious.
Thanks for including the kernel and L4T details upfront — that helps a lot.
I’ve checked our package repository and can confirm the root cause: there is currently no pre-compiled .deb driver package available for your specific kernel version (5.10.216-tegra-35.6.4-20260126234748 under L4T 35.6.4) on the Jetson Orin Nano. The installation script searches for a matching pre-built binary and fails because one simply doesn’t exist yet for that kernel build.
This happens occasionally when NVIDIA releases a newer kernel build for a given L4T release and our pre-compiled packages haven’t caught up yet.
We do have a troubleshooting guide that covers exactly this scenario — camera driver installation failure on Jetson devices. It walks through manual compilation steps that should get you up and running:
Follow the steps in that section and let me know how it goes. The guide covers building the driver from source against your running kernel, which bypasses the need for a matching pre-compiled .deb.
Appreciate the quick response. That makes sense — I figured it might be a kernel version mismatch but wasn’t sure if I was doing something wrong on my end.
I’ll go through the troubleshooting guide and try the manual build approach. Will report back once I’ve given it a shot. Hopefully it’s straightforward since I haven’t had to build kernel modules on the Jetson before.
It should be fairly straightforward. The guide is specific to Jetson and covers the steps for building the driver against your running kernel. The main thing is making sure your kernel headers are installed and match the running kernel version before you start the build. If you hit any snags during the process, post the error output here and I’ll help you work through it.
