IMX519 and Jetson Orin Nano
I have a IMX519 camera and a NVIDIA Jetson Orin Nano Super with nvidia-jetpack (6.2.1).
sudo dmesg | grep imx519
[   11.289820] imx519 9-001a: tegracam sensor driver:imx519_v2.0.6
[   11.591036] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx519 9-001a bound
[   11.591931] imx519 10-001a: tegracam sensor driver:imx519_v2.0.6
[   11.892641] imx519 10-001a: imx519_board_setup: error during i2c read probe (-121)
[   11.892674] imx519 10-001a: board setup failed
[   11.892744] imx519: probe of 10-001a failed with error -121
v4l2-ctl --all
Driver Info:
	Driver name      : tegra-video
	Card type        : vi-output, imx519 9-001a
	Bus info         : platform:tegra-capture-vi:2
	Driver version   : 5.15.148
	Capabilities     : 0x84200001
		Video Capture
		Streaming
		Extended Pix Format
		Device Capabilities
	Device Caps      : 0x04200001
		Video Capture
		Streaming
		Extended Pix Format
Media Driver Info:
	Driver name      : tegra-camrtc-ca
	Model            : NVIDIA Tegra Video Input Device
	Serial           :
	Bus info         :
	Media version    : 5.15.148
	Hardware revision: 0x00000003 (3)
Interface Info:
	Type             : V4L Video
Entity Info:
	Name             : vi-output, imx519 9-001a
	Function         : V4L2 I/O
	Pad 0x0100000a   : 0: Sink
	  Link 0x0200000f: from remote pad 0x1000006 of entity '13e00000.host1x:nvcsi@15a00000-' (Unknown sub-device (0002000a)): Data, Enabled
Priority: 2
Video input : 0 (Camera 2: ok)
Format Video Capture:
	Width/Height      : 4656/3496
	Pixel Format      : 'RG10' (10-bit Bayer RGRG/GBGB)
	Field             : None
	Bytes per Line    : 9312
	Size Image        : 32554752
	Colorspace        : sRGB
	Transfer Function : Default (maps to sRGB)
	YCbCr/HSV Encoding: Default (maps to ITU-R 601)
	Quantization      : Default (maps to Full Range)
	Flags             :
Streaming Parameters Video Capture:
	Capabilities     : timeperframe
	Frames per second: 9.000 (9/1)
	Read buffers     : 0
Camera Controls
                     group_hold 0x009a2003 (bool)   : default=0 value=0 flags=execute-on-write
                    sensor_mode 0x009a2008 (int64)  : min=0 max=4 step=1 default=0 value=0 flags=slider
                           gain 0x009a2009 (int64)  : min=16 max=257 step=1 default=16 value=16 flags=slider
                       exposure 0x009a200a (int64)  : min=13 max=683710 step=1 default=2495 value=13 flags=slider
                     frame_rate 0x009a200b (int64)  : min=2000000 max=9000000 step=1 default=9000000 value=2000000 flags=slider
           sensor_configuration 0x009a2032 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[22] flags=read-only, volatile, has-payload
         sensor_mode_i2c_packet 0x009a2033 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[1026] flags=read-only, volatile, has-payload
      sensor_control_i2c_packet 0x009a2034 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[1026] flags=read-only, volatile, has-payload
                    bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0 (0 0x0)
				0: 0 (0x0)
				1: 1 (0x1)
                override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0 (0 0x0)
				0: 0 (0x0)
				1: 1 (0x1)
                   height_align 0x009a2066 (int)    : min=1 max=16 step=1 default=1 value=1
                     size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0 (1 0x1)
				0: 1 (0x1)
				1: 65536 (0x10000)
				2: 131072 (0x20000)
               write_isp_format 0x009a2068 (int)    : min=1 max=1 step=1 default=1 value=1
       sensor_signal_properties 0x009a2069 (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][18] flags=read-only, has-payload
        sensor_image_properties 0x009a206a (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][16] flags=read-only, has-payload
      sensor_control_properties 0x009a206b (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][36] flags=read-only, has-payload
              sensor_dv_timings 0x009a206c (u32)    : min=0 max=4294967295 step=1 default=0 dims=[30][16] flags=read-only, has-payload
               low_latency_mode 0x009a206d (bool)   : default=0 value=0
               preferred_stride 0x009a206e (int)    : min=0 max=65535 step=1 default=0 value=0
    override_capture_timeout_ms 0x009a206f (int)    : min=-1 max=2147483647 step=1 default=2500 value=2500
                   sensor_modes 0x009a2082 (int)    : min=0 max=30 step=1 default=30 value=4 flags=read-only
How can I capture a small video?
I’m using this command and I obtain an empty file ora a video file with total green frames
gst-launch-1.0 nvv4l2camerasrc device=/dev/video0 num-buffers=180 ! nvvidconv ! 'video/x-raw,width=1920,height=1080' ! videoconvert ! 'video/x-raw' ! x264enc speed-preset=fast ! h264parse ! mp4mux ! filesink location=video.mp4
Thank you for reaching out.
Please refer to the commands in the following link:
I managed to record videos by making changes to the pipeline and adapting it to my machine (nvv4l2h264enc is not present on Jetson Orin Nano :frowning: ).
Can’t I capture a 1920x1080x30fps video with this camera?
If I use camera mode 2 (1920x1080), the resulting image is a cropped part of the full image captured at 4656x3496, as if it were zoomed in, thus losing the FOV declared by this camera specifications.
SENSOR_ID=0 # 0 for CAM0 and 1 for CAM1 ports
FRAMERATE=30 # Framerate can go from 2 to 60 for 1920x1080 mode
gst-launch-1.0 -e nvarguscamerasrc sensor-id=$SENSOR_ID num-buffers=180 ! "video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1" ! nvvidconv ! video/x-raw, format=BGRx ! videoconvert ! video/x-raw, format=BGR ! videoconvert ! video/x-raw,format=I420 ! x264enc ! h264parse ! mp4mux ! filesink location=rpi_v3_imx477_cam_1080.mp4
Pipeline is PREROLLED ...
New clock: GstSystemClock
Redistribute latency...
GST_ARGUS: 4656 x 3496 FR = 9,000000 fps Duration = 111111112 ; Analog Gain range min 1,000000, max 16,000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 17,000000 fps Duration = 58823528 ; Analog Gain range min 1,000000, max 16,000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 16,000000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 16,000000; Exposure Range min 13000, max 683709000;
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 59,999999
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:10.274694165
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline ...
