./install_full.sh -m imx477
Kernel version: 5.15.148-tegra-36.4.0-20240912212859
Jetson type: NVIDIA Jetson Orin NX Engineering Reference Developer Kit
The installation of the driver fails and I can’t get an image out of the camera.
imx477 or ardu is not in the dmesg log
Try without the driver installed
Please support JetPack 6.1 (Jetson Linux 36.4)
When are we expected to get a JetPack 6.1 release of the driver, as it is the current LTS? Is the driver even needed for my hardware setup (IMX477 with Jetson Orin NX)
The error occurs because the script doesn’t currently support JetPack 36.4.0 on the Jetson Orin Nano. Here’s what you can do:
First, check your current JetPack version:
sudo apt-cache show nvidia-jetpack
The recommended solution is to use one of the officially supported JetPack versions listed in the Arducam documentation. The latest supported version for Orin Nano can be found at: Introduction to Arducam Jetson Cameras - Arducam Wiki
To proceed, you have two options:
a. Downgrade to a supported JetPack version b. Wait for us to release support for JetPack 36.4.0(in two weeks)
thanks for the quick response. I am happy waiting the two weeks to not downgrade.
Will the driver be released also for the Jetson Orin NX because you stated the Jetson Orin Nano?
And also I was wondering why this camera module needs a separate driver, as the IMX477 sensor is supported out of the box by jetpack. Is the board too different?
What will be the best way of getting to know when the new driver is released when I don’t want to check every hour? Do you have an exact date?
Hello!
Currently the jetson-io solution is not working for me, we have a project with dual imx477 camera and only one work, we found out that the jetson-io script changes the device tree and had to manually set to serial_a instead of serial_b.
But with jetson-io on jetpack 6.1 the device tree doesn’t have a 4032x3040 resolution (which for us is strictly necessary). We had to go rollback to 5.1.3, install de arducam driver and manually overwrite the serial.
So we are patiently waiting for the new release so we can use our cameras with the latest updates.
