IMX477 driver install error and no 4032x3040 resolution on Jetson Orin Nano
Hey everyone, I’m trying to get an Arducam IMX477 running on my Jetson Orin Nano Super dev kit, but hitting a wall right out of the gate.
I ran the install script:
./install_full.sh -m imx477
And it bombs with:
Here’s what I’m working with:
  • Board: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
  • Kernel: 5.15.148-tegra-36.4.7-20250918154033
  • Sensor: IMX477 (using -m imx477, though I see there are also imx477_master_slave, imx477_stereo, and imx477_v3link modes)
My goal is to capture full 12MP (4032×3040) raw stills via V4L2. But when I check the available formats:
v4l2-ctl --list-formats-ext
I only see RG10 (10-bit Bayer) with these resolutions:
[0]: 'RG10' (10-bit Bayer RGRG/GBGB)
  Size: Discrete 3280x2464 — Interval: Discrete 0.048s (21.000 fps)
  Size: Discrete 3280x1848 — Interval: Discrete 0.036s (28.000 fps)
  Size: Discrete 1920x1080 — Interval: Discrete 0.033s (30.000 fps)
  Size: Discrete 1640x1232 — Interval: Discrete 0.033s (30.000 fps)
  Size: Discrete 1280x720 — Interval: Discrete 0.017s (60.000 fps)
No 4032×3040 anywhere. That’s the whole reason I bought this sensor.
I dug around the Arducam release repo and found a matching .deb — but it’s for an older kernel:
agx_orin_names["5.15.148-tegra-36.4.4-20250616085344"]="arducam-nvidia-l4t-kernel-t234-agx-orin-5.15.148-tegra-36.4.4-20250711143817_arm64_imx477.deb"
Linked from:
https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.1-agx-orin/arducam-nvidia-l4t-kernel-t234-agx-orin-5.15.148-tegra-36.4.4-20250711143817_arm64_imx477.deb
So now I’m wondering — should I try rolling back my kernel to 5.15.148-tegra-36.4.4 to use that existing package? Or is there a build for 36.4.7 in the pipeline? Happy to be a beta tester if there’s something experimental I can try. Just want my 12MP frames.
Thanks for the detailed report — that’s actually really helpful.
The root cause here is pretty straightforward: our MIPI camera driver .deb packages are tied to a specific kernel build. They include precompiled kernel modules that have to match the exact kernel version string. The install_full.sh script looks up your running kernel and tries to fetch the corresponding package — and when there isn’t one, you get that error.
At the time you ran the script, we simply hadn’t built a package for 5.15.148-tegra-36.4.7 yet. The available packages only went up to 36.4.4. That’s why the script couldn’t find a match.
Rolling back to 36.4.4 is one option, but I wouldn’t recommend it — there are usually other fixes and updates in the newer L4T point release that you’d lose.
Let me check with our build team and see if we can spin up a 36.4.7 package. I’ll get back to you here once I have something.
Good news — we’ve built a new driver package targeting kernel 5.15.148-tegra-36.4.7.
I’ve sent you the download link for the .deb via private message (the file is:
arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.7-20251023170635_arm64_imx477.deb).
Once you’ve got it, install with:
sudo dpkg -i arducam-nvidia-l4t-kernel-t234-nx-5.15.148-tegra-36.4.7-20251023170635_arm64_imx477.deb
After that, reboot and you should see the IMX477 at the full sensor resolution. Give it a shot and let me know how it goes.
That did it — driver installed clean and after a reboot the IMX477 is showing RG10 at 4032×3040. Exactly what I was after.
Thanks for the quick turnaround on the 36.4.7 build. Really appreciate it.
Now, on a related note, I have a feature request I wanted to run by you while I’m here. It’s about the pixel format…
So I’ve got the sensor working at full res, which is great, but I’m trying to squeeze more throughput out of the pipeline. The standard RG10 V4L2 format is unpacked — each 10-bit pixel takes up 2 bytes (16 bits), so there’s a fair bit of wasted bandwidth.
I’d like to propose a packed 10-bit raw format — let’s call it pRAA — where 4 pixels are stored in 5 bytes. That’s 37.5% more payload-efficient than the unpacked RG10 representation.
Here’s the byte layout:
Byte Content
Byte 1 Pixel 1 upper 8 bits
Byte 2 Pixel 2 upper 8 bits
Byte 3 Pixel 3 upper 8 bits
Byte 4 Pixel 4 upper 8 bits
Byte 5 LSBs packed: bits 7‑6 = P1 LSB2, bits 5‑4 = P2 LSB2, bits 3‑2 = P3 LSB2, bits 1‑0 = P4 LSB2
So for every group of 4 pixels you’re transmitting 5 bytes instead of 8. Over a 4032×3040 frame that adds up fast — faster sensor readout, less memory pressure, higher effective frame rate at the same MIPI lane speed.
My question: is there any chance Arducam would be interested in developing a V4L2 driver that exposes this pRAA format natively? If not, I’m planning to write it myself against your existing driver code, but I figured I’d ask before diving in.
Glad the 36.4.7 driver is working for you.
Regarding the pRAA packed format — I can see the appeal for your use case. Reducing payload by 37.5% is nothing to sneeze at when you’re pushing 12MP frames around.
That said, implementing a custom V4L2 pixel format like this is outside our current development roadmap. Our focus right now is on core driver functionality and keeping up with L4T kernel releases for the broader user base — adding a bespoke pixel format doesn’t really fit into that at this stage.
The good news is that our drivers are fully open-source specifically for this reason. You’re absolutely welcome (and encouraged) to fork the code and implement pRAA yourself. The existing Bayer capture pipeline should give you a solid starting point — you’d essentially be adding a new fourcc, registering it in the format enumeration, and writing the packing/unpacking logic in the data path.
If you run into specific questions while hacking on it, feel free to post them here and the community (or we) can weigh in. But for a full driver implementation, you’re in the best position to tailor it to your exact throughput requirements. Good luck!
