I used a IMX477 camera(SKU:B0251) on a Jetson xavier NX with Jetpack 4.4 and it worked fine.
I recently upgraded version of Jetpack to 5.0.2 and the camera no longer works properly.
It works in FullHD mode, but if I change it in 4K mode, it stops working.
Is there any way to capture 4K image on the Jetpack 5.x environment?
The error message I got is as follows.
gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! \"video/x-raw(memory:NVMM),width=4032,height=3040,framerate=$FRAMERATE/1\" ! nvvidconv ! \"video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1\" ! nvvidconv ! xvimagesink
New clock: GstSystemClock
GST_ARGUS: 4032 x 3040 FR = 20.000000 fps Duration = 50000000 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 903 Frame Rate specified is greater than supported
Camera index = 0
Camera mode = 0
Output Stream W = 4032 H = 3040
seconds to Run = 0
Frame Rate = 20.000000
ARGUS_ERROR: Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute: 1139 InvalidState.
GST_ARGUS: Cleaning up
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
Execution ended after 0:00:00.787472344
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
The driver I used is the following.
