Amazon
https://www.amazon.com/gp/product/B08MPYVJCK/
Jetson Nano Production Module + Auvidea Carrier Board
Flashing production module using NVIDIA and Auvidea’s instructions, along with a custom device tree and the RidgeRun IMX477 driver
Yes, this exact same process with the same Auvidea board, same files, same procedure has worked fine for many IMX477 cameras in the past. Recently, with some of the more recent IMX477 cameras we’ve been receiving from Arducam, we have not been able to capture images.
No method of capturing images works, whether it be using gst-launch, the Deepstream application, or nvgstcapture. The logs from nvargus-daemon show a hardware timeout issue.
The IMX477 does work fine when testing with an A02 Dev Kit. The Auvidea board also works fine with an IMX219. We have tried multiple Auvidea boards, multiple camera connectors, and multiple IMX477 cameras with no luck in the recent weeks. The most confusing thing is that we've changed nothing in the past 2 months with the firmware, software, flashing procedure, etc.
Testing different ribbon cables, testing different IMX477 cameras, testing with other methods of image capture.
Have there been any changes recently to the IMX477 that might be causing this issue? We have contacted Auvidea and they are not being very responsive or helpful in their support…
