IMX477 AF camera on Jetson NX with 8mm M12 lens: random blur, autofocus not working
Hi, hoping someone here can help. I’m using an IMX477 AF camera module (B0273) with the 8mm FL M12 motorized AF lens on a Jetson NX. The focus/blur is totally random — if I just take pictures without touching the camera, some come out sharp and some are completely blurred, and it’s random. The autofocus function also doesn’t seem to work at all.
Setup:
  • IMX477 Jetson NX version, motorized AF lens (8mm FL M12)
  • All images from the same camera, same position
  • ~1.5m distance to the object
I read on some forums that changing a resistor on the PCB fixes this kind of thing, but I’m not sure if that’s really the right way to go. Should I share some sample images?
Thanks for the details. The module you’re using is a motorized focus camera, and there are a few factors that can affect its focus. In general, focus/blur issues on a motorized focus camera can be caused by the light condition, the object movement, or objects in the scene changing, etc. If you can post a few of the sample images, we can take a closer look at what’s happening.
That’s exactly what I don’t get though. I was NOT moving the camera, I was NOT moving the object and I was NOT changing the lens. Which change do you talk about? Everything is the same setup, nothing on my side is changing between shots.
Looking at the images you shared, the light condition of the first two pictures looks darker than the last three. Have you noticed that? I’m also checking with our engineers whether there are other reasons that could explain this.
No, there is no light condition change in the office. The images are taken totally under the same conditions, in less than 30 seconds. And you can still see some blurred and some non-blurred images in there. Do you have any solution for this? Or just selling products with lots of bugs and without any support… Thank you, looking forward to your reply.
We received your email and had a look at the sample images. Honestly, we’re not sure yet what is the reason causing this issue. To help narrow it down: in the images you annotated, are both the orange and the green words labelled in your email the blurred areas? Just want to confirm we’re reading the annotation correctly before we dig further.
