IMX462 camera streaming fails with Input/output error on Raspberry Pi 4
Hey everyone, I’m at my wit’s end here. I recently picked up an Arducam IMX462 (B0444) to use with my Raspberry Pi 4 Model B 8GB, and after about 4 hours of fiddling I cannot get this thing to stream at all.
I’ve followed the official Arducam docs, dug through forum posts, tried stuff from a few different GitHub repos, even updated the firmware — nothing. The camera just refuses to start.
Here’s the error I keep hitting when I try to start the stream:
[0:00:38.231477123] [2363] ERROR V4L2 v4l2_videodevice.cpp:2049 /dev/video0[13:cap]: Failed to start streaming: Input/output error
I can see /dev/video0 is there, so the system detects something, but it just won’t stream. Has anyone run into this before? I’m running whatever the latest Raspberry Pi OS is as of now. Totally stuck.
Sorry to hear you’re having trouble. Let’s do some proper diagnosis before jumping to conclusions. That I/O error can come from a few different things.
First, could you take some clear photos of your hardware connections — both the camera end and the Raspberry Pi end of the ribbon cable? Sometimes it’s just a slightly misaligned FFC connector.
Second, I’d like you to run our diagnostic tool to generate a bug report. It’ll grab all the relevant system info we need. Here’s what to do:
  1. Reboot your Pi first so we’re starting from a clean state.
  2. Download the bug report tool:
  1. Make it executable:
  1. Run it:
  1. It’ll generate a file called arducam-bug-report.txt in your current directory.
Send me that file along with the photos and I’ll dig in.
Alright, followed your steps — rebooted, downloaded the tool, ran it. Got the bug report generated.
I’ve sent you the arducam-bug-report.txt file and the hardware connection photos through private message. Didn’t want to dump raw system info publicly.
From what I could see skimming the report myself, the camera does show up on the I2C bus and /dev/video0 is present. But obviously something is still wrong. Any ideas what I should be looking at?
Thanks for sending those over. I’ve gone through the bug report and the photos — hardware connections look fine, so we can rule that out.
Here’s what I found: your /boot/config.txt (or /boot/firmware/config.txt depending on your OS version) has multiple camera driver overlays enabled at the same time. That’s the culprit.
On the Raspberry Pi, only one camera driver overlay can be active at a time. When you have two or more dtoverlay entries for different camera modules enabled simultaneously, they conflict with each other and the V4L2 subsystem can’t properly initialize the streaming pipeline. That’s exactly what your error — Failed to start streaming: Input/output error — is telling us. It’s not a hardware problem, it’s a driver conflict.
You need to go into your config.txt and clean this up. Here’s what to do:
  1. Open the config file:
    sudo nano /boot/config.txt
    (If you’re on a newer Bookworm-based Raspberry Pi OS, it might be /boot/firmware/config.txt)
  2. Look through the file and find any dtoverlay lines that reference camera drivers other than arducam-pivariety. Comment those out or delete them entirely.
  3. Make absolutely sure this line is present and not commented out:
    dtoverlay=arducam-pivariety
  4. Save the file (Ctrl+O, Enter, Ctrl+X in nano).
  5. Reboot:
    sudo reboot
The mutual exclusivity of camera overlays has to be enforced manually in config.txt — the system won’t do it for you. Once only the arducam-pivariety overlay is active, the streaming should work.
Alright, that was exactly it. I opened up config.txt and sure enough there was another dtoverlay line for a different camera module that must have been left over from some earlier tinkering — I completely forgot it was there. Commented it out, left only dtoverlay=arducam-pivariety active, rebooted, and the camera started streaming immediately.
Can’t believe I spent 4 hours chasing this. For anyone else who finds this thread — if you’re getting that Failed to start streaming: Input/output error on an Arducam with a Pi, check your config.txt for conflicting dtoverlay entries before you do anything else. Only one camera overlay can be enabled at a time.
Thanks for the help, really appreciate the thorough diagnosis!
