Hello.
Today I got ArduCam IMX462 module from Amazon ( Amazon.com: Arducam for Raspberry Pi 5 Camera Module, IMX462 Color Ultra Low Light Camera, CMOS Camera with 141°(H) Wide-Angle M12 Lens, High NIR Sensitivity Camera for Raspberry Pi : Electronics ). CM4 module with 4GB memory and 32GB EMMC, latest Bookworm official image that works good with official IMX500. But I can’t get ArduCam IMX462. I found firmware update for B0444 but it is failed:
[INFO] Firmware Version: 0x10003
[INFO] Sensor ID: 0x00B2
[INFO] ==================First stage==================
[INFO] Write update flag 2.
[INFO] Write checksum.
[INFO] Write update flag.
[INFO] Sending… |=================================================================================================| ETA: 0h01m02s
[INFO] All data has been sent.
[INFO] Updating…
[SUCCESS] Firmware update successful.
[SUCCESS] ==================First stage success==================
[INFO] ==================Second stage==================
[INFO] Sending… |=================================================================================================| ETA: 0h00m01s
[INFO] Updating…
[ERROR] Firmware verification failed. val: 2
[ERROR] The second stage fails, exit the program.
My config.txt:
#dtparam=i2c_arm=on
dtparam=i2s=on
#dtparam=spi=on
#dtparam=audio=on
camera_auto_detect=0
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
dtoverlay=disable-wifi
dtoverlay=arducam-pivariety
hdmi_force_hotplug=1
config_hdmi_boost=10
disable_splash=1
dtoverlay=uart1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
enable_uart=1
libcamera-hello app filed with error:
[0:01:01.056650722] [1623] INFO Camera camera_manager.cpp:327 libcamera v0.4.0+75-6a393eec-dirty (2025-02-05T06:09:21GMT)
[0:01:01.126156648] [1628] ERROR IPAProxy ipa_proxy.cpp:154 Configuration file ‘arducam-pivariety.json’ not found for IPA module ‘rpi/vc4’
terminate called after throwing an instance of ‘std::runtime_error’
what(): Exception during zlib decompression: (-3) unknown compression method
Aborted
What I have to do to fix it? Thanks
