IMX415 on RK3588
The RK3588 System already validated with Radxa 4K and Edgeble IMX415. Both are working properly.
I’m trying Arducam IMX415 [B0569] and Waveshare IMX415 on RK3588 system.
Camera detection are proper but the stream failed from 2nd run. same happening for both RPi based cameras.
$ sudo dmesg | grep imx415
[   12.570773] platform csi2-dcphy0: Fixed dependency cycle(s) with /i2c@fec90000/imx415@37
[   12.924278] imx415 7-0037: driver version: 00.01.08
[   12.924297] imx415 7-0037:  Get hdr mode failed! no hdr default
[   12.924318] imx415 7-0037: detect imx415 lane 4
[   12.924326] imx415 7-0037: current mode 1, cfg_num 11
[   12.924448] imx415 7-0037: could not get default pinstate
[   12.924455] imx415 7-0037: could not get sleep pinstate
[   12.924463] imx415 7-0037: Looking up dvdd-supply from device tree
[   12.924570] imx415 7-0037: Looking up dovdd-supply from device tree
[   12.924661] imx415 7-0037: Looking up avdd-supply from device tree
[   12.996670] imx415 7-0037: Detected imx415 id 0000e0
[   12.996720] imx415 7-0037: Consider updating driver imx415 to match on endpoints
[   12.996744] rockchip-csi2-dphy csi2-dcphy0: dphy0 matches m00_b_imx415 7-0037:bus type 5
[   14.416636] imx415 7-0037: set exposure(shr0) 1845 = cur_vts(2250) - val(405)
$ v4l2-ctl -d /dev/video11 --set-fmt-video=width=1920,height=1080,pixelformat=NV12 --stream-mmap=4 --stream-skip=100 --stream-to=11.yuv --stream-count=1 --stream-poll
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.00 fps
select timeout
<6>[  247.241212] rkisp_hw fdcb0000.rkisp: set isp clk = 594000000Hz
<7>[  247.248580] imx415 7-0037: set exposure(shr0) 2242 = cur_vts(2250) - val(8)
<6>[  247.255797] rkisp rkisp0-vir0: first params buf queue
<6>[  247.257739] rkcif-mipi-lvds: stream[0] start streaming
<3>[  247.257888] rockchip-mipi-csi2 mipi0-csi2: stream on, src_sd: 000000008058b40a, sd_name:rockchip-csi2-dphy0
<3>[  247.257902] rockchip-mipi-csi2 mipi0-csi2: stream ON
<6>[  247.257937] rockchip-csi2-dphy0: dphy0, data_rate_mbps 892
<6>[  247.257949] rockchip-csi2-dphy0: dphy0, data_rate_mbps 892
<6>[  247.258246] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_s_stream stream on:1, dphy0, ret 0
<6>[  247.258260] imx415 7-0037: s_stream: 1. 1920x1080, hdr: 0, bpp: 10
<3>[  247.258633] m00_b_imx415 7-0037: start stream failed while write regs
<6>[  247.259687] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_s_stream_stop stream stop, dphy0
<6>[  247.259702] rockchip-csi2-dphy csi2-dcphy0: csi2_dphy_s_stream stream on:0, dphy0, ret 0
<3>[  247.259713] rockchip-mipi-csi2 mipi0-csi2: stream off, src_sd: 000000008058b40a, sd_name:rockchip-csi2-dphy0
<3>[  247.259724] rockchip-mipi-csi2 mipi0-csi2: stream OFF
<3>[  247.259754] rockchip-mipi-csi2 mipi0-csi2: stream off, src_sd: 000000008058b40a, sd_name:rockchip-csi2-dphy0
<6>[  247.259764] imx415 7-0037: s_stream: 0. 1920x1080, hdr: 0, bpp: 10
<4>[  249.787171] rkisp0-vir0: rkisp_stream_stop id:0 timeout
<6>[  249.787184] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x0, cur 0x2
<6>[  249.787187] rkcif-mipi-lvds: stream[0] stopping finished, dma_en 0x0
I’m using RK based kernel-6.1
Device Tree change:
Any inputs?
