I am trying to test the pivariety IMX230 on a Raspi 4.
I followed the install instructions and want to test the cam with
‘‘libcamera-still -t 0 -o test.jpg’’
the response is
‘‘libcamera-still: error while loading shared libraries: libSM.so.6: cannot open shared object file: No such file or directory’’
After I installed libSM.so.6 libcamera produces the following:
pi@raspberrypi:~ $ libcamera-still -t 0 -o test.jpg --nopreview
[0:09:05.840624593] [1104] INFO Camera camera_manager.cpp:296 libcamera v0.0.0+2736-579f55b1-dirty (2021-07-01T03:47:30-04:00)
[0:09:05.849987218] [1106] WARN CameraSensor camera_sensor.cpp:197 ‘arducam-pivariety 10-000c’: Recommended V4L2 control 0x009a0922 not supported
[0:09:05.876022301] [1106] WARN CameraSensor camera_sensor.cpp:249 ‘arducam-pivariety 10-000c’: The sensor kernel driver needs to be fixed
[0:09:05.876132355] [1106] WARN CameraSensor camera_sensor.cpp:251 ‘arducam-pivariety 10-000c’: See Documentation/sensor_driver_requirements.rst in the libcamera sources for more information
[0:09:05.884545953] [1106] WARN CameraSensorProperties camera_sensor_properties.cpp:109 No static properties available for ‘arducam-pivariety’
[0:09:05.884672174] [1106] WARN CameraSensorProperties camera_sensor_properties.cpp:111 Please consider updating the camera sensor properties database
[0:09:05.884783913] [1106] WARN CameraSensor camera_sensor.cpp:403 ‘arducam-pivariety 10-000c’: Failed to retrieve the camera location
[0:09:06.035702553] [1106] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file ‘arducam-pivariety.json’ not found for IPA module ‘raspberrypi’
[0:09:06.433413421] [1104] WARN V4L2 v4l2_pixelformat.cpp:181 Unsupported V4L2 pixel format XB24
[0:09:06.434681611] [1104] INFO Camera camera.cpp:906 configuring streams: (0) 2672x2008-YUV420
[0:09:06.435284920] [1106] INFO RPI raspberrypi.cpp:128 Mode: 5344x4012 fmt RG10 Score: 2669.5 (best 2669.5)
[0:09:06.435388696] [1106] INFO RPI raspberrypi.cpp:128 Mode: 3840x2160 fmt RG10 Score: 1997.66 (best 1997.66)
[0:09:06.435445381] [1106] INFO RPI raspberrypi.cpp:128 Mode: 2592x1944 fmt RG10 Score: 1789 (best 1789)
[0:09:06.435500714] [1106] INFO RPI raspberrypi.cpp:128 Mode: 2656x2004 fmt RG10 Score: 1555.98 (best 1555.98)
[0:09:06.435553010] [1106] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt RG10 Score: 5027.66 (best 1555.98)
[0:09:06.435630416] [1106] INFO RPI raspberrypi.cpp:128 Mode: 1280x960 fmt RG10 Score: 6381 (best 1555.98)
[0:09:06.435683249] [1106] INFO RPI raspberrypi.cpp:128 Mode: 1280x720 fmt RG10 Score: 7027.66 (best 1555.98)
[0:09:06.435785044] [1106] INFO RPI raspberrypi.cpp:128 Mode: 640x480 fmt RG10 Score: 8621 (best 1555.98)
[0:09:06.435853395] [1106] INFO RPI raspberrypi.cpp:128 Mode: 5344x4012 fmt pRAA Score: 2169.5 (best 1555.98)
[0:09:06.435973172] [1106] INFO RPI raspberrypi.cpp:128 Mode: 3840x2160 fmt pRAA Score: 1497.66 (best 1497.66)
[0:09:06.436027023] [1106] INFO RPI raspberrypi.cpp:128 Mode: 2592x1944 fmt pRAA Score: 1289 (best 1289)
[0:09:06.436080782] [1106] INFO RPI raspberrypi.cpp:128 Mode: 2656x2004 fmt pRAA Score: 1055.98 (best 1055.98)
[0:09:06.436165318] [1106] INFO RPI raspberrypi.cpp:128 Mode: 1920x1080 fmt pRAA Score: 4527.66 (best 1055.98)
[0:09:06.436237521] [1106] INFO RPI raspberrypi.cpp:128 Mode: 1280x960 fmt pRAA Score: 5881 (best 1055.98)
[0:09:06.436290409] [1106] INFO RPI raspberrypi.cpp:128 Mode: 1280x720 fmt pRAA Score: 6527.66 (best 1055.98)
[0:09:06.436342779] [1106] INFO RPI raspberrypi.cpp:128 Mode: 640x480 fmt pRAA Score: 8121 (best 1055.98)
[0:09:06.489306857] [1106] INFO RPI raspberrypi.cpp:625 Sensor: /base/soc/i2c0mux/i2c@1/arducam@0c - Selected mode: 2656x2004-pRAA
[0:09:06.554593399] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Sharpness = 1.000000
[0:09:06.554777749] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Saturation = 1.000000
[0:09:06.554845045] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Contrast = 1.000000
[0:09:06.554912674] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: Brightness = 0.000000
[0:09:06.554969747] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: FrameDurationLimits = [ 33333, 33333 ]
[0:09:06.555073709] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: NoiseReductionMode = 3
[0:09:06.555196708] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: AeMeteringMode = 0
[0:09:06.555327336] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: AeExposureMode = 0
[0:09:06.555386039] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: ExposureValue = 0.000000
[0:09:06.555453113] [1110] INFO IPARPI raspberrypi.cpp:637 Request ctrl: AwbMode = 0
[0:09:06.558838355] [1106] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:09:06.558906002] [1106] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:09:06.558947002] [1106] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:09:06.558984409] [1106] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:09:07.158048188] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (7 left)
[0:09:07.192897547] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (6 left)
[0:09:07.230297472] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (5 left)
[0:09:07.271152840] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (4 left)
[0:09:07.306915577] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (3 left)
[0:09:07.344877753] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (2 left)
[0:09:07.380720823] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (1 left)
[0:09:07.416421116] [1106] INFO RPI raspberrypi.cpp:1671 Dropping frame at the request of the IPA (0 left)
I am guessing that some dependecies are missing…
