IMX219 camera on Jetson Xavier detected at /dev/video0 but gst-launch reports no camera found
Hi, I’m stuck trying to get an IMX219 camera working on a Jetson Xavier. The camera does show up as /dev/video0, but any time I try to use it with gst-launch I get an error saying there’s no camera found. I’ve honestly never gotten it to work. The product series is Jetson Nano/Xavier NX Cameras and the camera model is imx219. Anyone know what’s going on here?
Hi, thanks for the details. The pattern you describe — camera enumerating at /dev/video0 but gst-launch saying no camera found — usually points to a camera driver/config mismatch on the Jetson rather than a dead camera. On Xavier the IMX219 typically needs to be driven through the native nvarguscamerasrc path instead of a plain v4l2 pipeline.
Before I point you at the right pipeline, I need to confirm exactly which IMX219 board you have, since there are a few variants with different connectors/adapters. Could you send a couple of pictures of the camera (front and back), or the link to where you purchased it? That will help me match the correct setup.
Sure, here are photos of the camera, front and back:
I got it from a seller called clients camera if that helps. Let me know if you need anything else.
Also, just to add — I bought it a while back and I don’t have the order number anymore, I never kept track of it. Sorry about that.
No worries, the photos are the main thing. I’ll take a look at the connector and board layout to confirm the exact variant.
In the meantime, here’s the reference doc for this camera family so you can compare your setup:
https://www.arducam.com/docs/camera-for-jetson-nano/native-jetson-cameras-imx219-imx477/imx219-8mp-camera/
Also, could you paste the exact gst-launch command you’re running, and the full error text? I want to see whether it’s failing at the sensor probe stage or just the pipeline.
This is the command I’ve been using:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM),width=1920,height=1080,framerate=30/1’ ! nvvidconv ! nvoverlaysink
And it prints the standard stuff then fails with something like “no camera found”. Sometimes I also see a message about the camera not being available. If I try a plain v4l2src pipeline instead, it doesn’t give me usable frames either. The /dev/video0 node is definitely there though.
That error from nvarguscamerasrc is usually a sign that the sensor isn’t being probed over I2C, or the device tree entry for your specific module isn’t loaded — even though the v4l2 node exists.
Can you run these and share the output?
ls /dev/video*
cat /proc/device-tree/model
sudo i2cdetect -y -r 6
dmesg | grep -i imx219
Also which JetPack/L4T version is on the Xavier? That determines which driver and device tree you need.
Here’s what I got:
$ ls /dev/video*
/dev/video0
$ cat /proc/device-tree/model
NVIDIA Jetson Xavier
$ sudo i2cdetect -y -r 6
00: – – – – – – – –
70: – – – – – – – – – – – – – – – –
$ dmesg | grep -i imx219
(no output)
So nothing shows up on I2C bus 6 and no imx219 messages in dmesg at all.
That’s actually useful. No hit on i2cdetect plus no imx219 lines in dmesg strongly suggests the sensor isn’t being detected on the bus — so the driver never binds. /dev/video0 being present alone doesn’t mean the camera is actually linked up.
A few things to check now:
  1. Confirm the ribbon is fully seated and oriented correctly on both the camera and the Xavier side (these connectors are easy to insert backwards).
  2. Try the other CSI port and see if the camera appears on the matching I2C bus.
  3. Are you on a devkit, or is this a custom carrier board? Custom boards often need a modified device tree.
Once I can match the photos to the exact IMX219 variant, I can tell you whether it needs a different device tree/camera overlay for the Xavier.
It’s a custom carrier board, not an official devkit. I reseated the ribbon on both ends and tried the other CSI port — same result, /dev/video0 exists but nvarguscamerasrc still says no camera found and i2cdetect is still empty on that bus. So it looks like the sensor isn’t being detected at all regardless of the port.
Okay, so to sum up where we are:
  • Camera enumerates at /dev/video0, but nvarguscamerasrc fails with “no camera found” and no imx219 entries appear in dmesg.
  • i2cdetect shows nothing on the camera bus, and swapping CSI ports/reseating the ribbon didn’t change anything.
  • This points at the sensor not being detected over I2C on your setup, which is consistent with a driver/device-tree configuration mismatch on the Xavier rather than a fault in the camera module itself — though we haven’t confirmed the root cause yet.
The next step is to confirm the exact IMX219 variant from your photos and, since you’re on a custom carrier board, likely apply the correct device tree/camera overlay for that board and JetPack version. Please also tell me your exact L4T/JetPack version.
I’ve sent you a couple of additional test resources through private message — check your messages when you get a chance. If you can reply with the JetPack version and confirm the board details, I can point you to the right overlay and we can keep digging from there.
