Hi Wong,
Tried re-plug those, nothing changed
dmesg log:
[email protected]:~$ dmesg
[ 0.000000] Linux version 4.9.140-tegra ([email protected]) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Oct 16 12:32:46 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node [email protected], reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: [email protected]
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefa6000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 [email protected] section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 [email protected] video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 [email protected] core_edp_mv=1075 core_edp_ma=4000 [email protected] is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29232(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562012K/4159488K available (15294K kernel code, 2936K rwdata, 6644K rodata, 8576K init, 611K bss, 122340K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13e008 ( 2937 KB)
[ 0.000000] .bss : 0xffffff800a13e008 - 0xffffff800a1d6f7c ( 612 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /[email protected]: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001801] Console: colour dummy device 80x25
[ 0.001810] console [tty0] enabled
[ 0.001816] bootconsole [uart8250] disabled
[ 0.001835] kmemleak: Kernel memory leak detector disabled
[ 0.001855] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001868] pid_max: default: 32768 minimum: 301
[ 0.002322] Security Framework initialized
[ 0.002547] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002556] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003719] ftrace: allocating 47119 entries in 185 pages
[ 0.173736] sched-energy: CPU device node has no sched-energy-costs
[ 0.173774] ASID allocator initialised with 65536 entries
[ 0.212309] tegra-id: chipid=22117.
[ 0.212323] tegra-id: opt_subrevision=0.
[ 0.212340] Tegra Speedo/IDDQ fuse revision 4
[ 0.212345] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.212349] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.212355] Tegra: CPU Speedo Value 2050, SoC Speedo Value 1954, GPU Speedo Value 2055
[ 0.212359] Tegra: CPU IDDQ Value 1896, SoC IDDQ Value 2108, GPU IDDQ Value 2610
[ 0.212376] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.212392] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.212399] DTB Build time: Oct 16 2020 12:38:12
[ 0.261093] CPU1: Booted secondary processor [411fd071]
[ 0.292999] CPU2: Booted secondary processor [411fd071]
[ 0.324989] CPU3: Booted secondary processor [411fd071]
[ 0.325079] Brought up 4 CPUs
[ 0.325087] SMP: Total of 4 processors activated.
[ 0.325095] CPU features: detected feature: 32-bit EL0 Support
[ 0.325362] CPU: All CPU(s) started at EL2
[ 0.325381] alternatives: patching kernel code
[ 0.333812] devtmpfs: initialized
[ 0.373256] Initilizing CustomIPI irq domain
[ 0.373656] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.373679] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.385269] pinctrl core: initialized pinctrl subsystem
[ 0.385875] OS set in device tree is not L4T.
[ 0.386308] regulator-dummy: no parameters
[ 0.386595] Initializing plugin-manager
[ 0.386763] Plugin module not found
[ 0.386954] node /plugin-manager/[email protected] match with board >=3448-0000-100
[ 0.387505] node /plugin-manager/[email protected] match with board >=3448-0000-101
[ 0.388371] node /plugin-manager/[email protected] match with odm-data enable-tegra-wdt
[ 0.388776] node /plugin-manager/[email protected] match with odm-data enable-tegra-wdt
[ 0.389410] node /plugin-manager/[email protected] match with board >=3448-0000-300
[ 0.391367] node /plugin-manager/[email protected] match with board >=3448-0000-300
[ 0.395268] NET: Registered protocol family 16
[ 0.396577] pstore: using zlib compression
[ 0.396619] console [pstore-1] enabled
[ 0.396623] pstore: Registered ramoops as persistent store backend
[ 0.396628] ramoops: attached [email protected], ecc: 0/0
[ 0.413107] cpuidle: using governor menu
[ 0.417540] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.419375] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.419399] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421717] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.424177] Serial: AMBA PL011 UART driver
[ 0.424702] tegra_powergate_init: DONE
[ 0.424717] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.424725] DTB Build time: Oct 16 2020 12:38:12
[ 0.426791] Tegra reboot handler registered.
[ 0.431460] iommu: Adding device tegra-carveouts to group 0
[ 0.431608] platform tegra-carveouts: domain=ffffffc0f9be13d8 allocates as[0]=ffffffc0f94400a8
[ 0.431976] iommu: Adding device smmu_test to group 1
[ 0.432027] platform smmu_test: domain=ffffffc0f9be1618 allocates as[0]=ffffffc0f9440110
[ 0.432845] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.432904] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.432954] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.432964] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.432986] mc-err: mcerr ops are set to t21x
[ 0.442921] iommu: Adding device 70090000.xusb to group 2
[ 0.443209] iommu: Adding device 70006000.serial to group 3
[ 0.443287] platform 70006000.serial: domain=ffffffc0f94d5618 allocates as[0]=ffffffc0f9440178
[ 0.443707] iommu: Adding device 70006040.serial to group 4
[ 0.443976] iommu: Adding device 70006200.serial to group 5
[ 0.444201] iommu: Adding device sound to group 6
[ 0.444251] platform sound: domain=ffffffc0f94d5b58 allocates as[0]=ffffffc0f94401e0
[ 0.444811] iommu: Adding device 7000d400.spi to group 7
[ 0.445243] iommu: Adding device 7000d600.spi to group 8
[ 0.445549] iommu: Adding device 70410000.spi to group 9
[ 0.445884] iommu: Adding device 50000000.host1x to group 10
[ 0.446162] iommu: Adding device 54080000.vi to group 11
[ 0.446567] iommu: Adding device 54600000.isp to group 12
[ 0.446826] iommu: Adding device 54680000.isp to group 13
[ 0.447139] iommu: Adding device tegradc.0 to group 14
[ 0.447195] platform tegradc.0: domain=ffffffc0f94e2a98 allocates as[0]=ffffffc0f9440248
[ 0.451367] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.451758] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.452120] iommu: Adding device tegradc.1 to group 15
[ 0.452168] platform tegradc.1: domain=ffffffc0f94e2cd8 allocates as[0]=ffffffc0f94402b0
[ 0.456335] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.456723] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456973] iommu: Adding device 54340000.vic to group 16
[ 0.457196] iommu: Adding device 544c0000.nvenc to group 17
[ 0.457407] iommu: Adding device 54500000.tsec to group 18
[ 0.457612] iommu: Adding device 54100000.tsecb to group 19
[ 0.457804] iommu: Adding device 54480000.nvdec to group 20
[ 0.458025] iommu: Adding device 54380000.nvjpg to group 21
[ 0.459055] iommu: Adding device 546c0000.i2c to group 22
[ 0.459383] iommu: Adding device 57000000.gpu to group 23
[ 0.459432] platform 57000000.gpu: domain=ffffffc0f94f1cd8 allocates as[0]=ffffffc0f9440318
[ 0.459469] platform 57000000.gpu: domain=ffffffc0f94f1cd8 allocates as[1]=ffffffc0f9440380
[ 0.459511] platform 57000000.gpu: domain=ffffffc0f94f1cd8 allocates as[2]=ffffffc0f94403e8
[ 0.459547] platform 57000000.gpu: domain=ffffffc0f94f1cd8 allocates as[3]=ffffffc0f9440450
[ 0.460466] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.460479] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.460490] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.460495] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.460499] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.513177] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.513188] tegra-pmc: Clear bootloader IO dpd settings
[ 0.513207] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.513272] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.513573] iommu: Adding device 70012000.se to group 24
[ 0.514340] iommu: Adding device 7000c000.i2c to group 25
[ 0.514594] iommu: Adding device 7000c400.i2c to group 26
[ 0.514853] iommu: Adding device 7000c500.i2c to group 27
[ 0.515115] iommu: Adding device 7000c700.i2c to group 28
[ 0.515407] iommu: Adding device 7000d000.i2c to group 29
[ 0.515655] iommu: Adding device 7000d100.i2c to group 30
[ 0.515954] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.516008] platform sdhci-tegra.0: domain=ffffffc0f958be58 allocates as[0]=ffffffc0f94404b8
[ 0.516855] iommu: Adding device 700d0000.xudc to group 32
[ 0.520281] vdd-ac-bat: 5000 mV
[ 0.520633] vdd-5v0-sys: 5000 mV
[ 0.521619] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.521691] vdd-5v0-hdmi: 5000 mV
[ 0.522102] vdd-1v8-sys: 1800 mV
[ 0.522503] vdd-fan: supplied by vdd-5v0-sys
[ 0.522539] vdd-fan: 5000 mV
[ 0.522920] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.522971] vdd-usb-vbus: 5000 mV
[ 0.523502] vdd-usb-vbus2: 5000 mV
[ 0.554123] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.556691] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.557819] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.557840] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.557888] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.558297] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.566296] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.566667] SCSI subsystem initialized
[ 0.566954] libata version 3.00 loaded.
[ 0.567278] usbcore: registered new interface driver usbfs
[ 0.567328] usbcore: registered new interface driver hub
[ 0.567410] usbcore: registered new device driver usb
[ 0.571492] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.576345] random: fast init done
[ 0.576364] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.577410] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.580253] vdd-ddr-1v1: 1150 mV
[ 0.584242] vdd-pre-reg-1v35: 1350 mV
[ 0.588239] vdd-1v8: 1800 mV
[ 0.592239] avdd-sys-1v2: 1200 mV
[ 0.596240] vdd-pex-1v0: 1050 mV
[ 0.596928] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.597471] max77620-ldo3: at 3100 mV
[ 0.600242] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.600788] max77620-ldo5: at 3100 mV
[ 0.604238] vddio-sdmmc3-ap: 1800 <–> 3300 mV at 2800 mV
[ 0.608238] avdd-1v05-pll: 1050 mV
[ 0.612237] avdd-io-hdmi-dp: 1050 mV
[ 0.614905] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.615187] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.615459] max77620 4-003c: max77620 probe successful
[ 0.618212] media: Linux media interface: v0.10
[ 0.618278] Linux video capture interface: v2.00
[ 0.619222] pps_core: LinuxPPS API ver. 1 registered
[ 0.619230] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.619250] PTP clock support registered
[ 0.622566] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.623441] Advanced Linux Sound Architecture Driver Initialized.
[ 0.624121] Bluetooth: Core ver 2.22
[ 0.624168] NET: Registered protocol family 31
[ 0.624171] Bluetooth: HCI device and connection manager initialized
[ 0.624186] Bluetooth: HCI socket layer initialized
[ 0.624195] Bluetooth: L2CAP socket layer initialized
[ 0.624278] Bluetooth: SCO socket layer initialized
[ 0.626059] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.626078] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.626127] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.626142] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.630030] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.631259] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.631343] vdd-3v3-sys: 3300 mV
[ 0.631611] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.632323] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.632801] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.632869] vdd-3v3-sd: 3300 mV
[ 0.633967] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.634011] avdd-io-edp-1v05: 1050 mV
[ 0.634441] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.634480] vdd-usb-hub-en: 5000 mV
[ 0.635925] camchar: rtcpu character device driver loaded
[ 0.636731] extcon-gpio-states extcon:[email protected]: Cable state:1, cable id:1
[ 0.638219] clocksource: Switched to clocksource arch_sys_counter
[ 0.679723] VFS: Disk quotas dquot_6.6.0
[ 0.679848] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.680351] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.680794] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.680810] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.681018] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.681024] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.681035] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.681069] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.681075] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.681088] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.681095] nvmap_page_pool_init: Total RAM pages: 1009287
[ 0.681100] nvmap_page_pool_init: nvmap page pool size: 126160 pages (492 MB)
[ 0.681191] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.681688] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.682708] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.691280] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.691756] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.692136] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.692422] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.692607] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.692893] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.692898] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.693338] NET: Registered protocol family 2
[ 0.694422] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.694632] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.695177] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.695336] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.695416] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.695846] NET: Registered protocol family 1
[ 0.696582] RPC: Registered named UNIX socket transport module.
[ 0.696587] RPC: Registered udp transport module.
[ 0.696591] RPC: Registered tcp transport module.
[ 0.696595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.696609] PCI: CLS 0 bytes, default 64
[ 0.696877] Trying to unpack rootfs image as initramfs…
[ 0.932357] Freeing initrd memory: 5356K
[ 0.942655] host1x 50000000.host1x: initialized
[ 0.944549] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.947963] audit: initializing netlink subsys (disabled)
[ 0.948061] audit: type=2000 audit(0.795:1): initialized
[ 0.948847] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.958940] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.960403] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.961222] 9p: Installing v9fs 9p2000 file system support
[ 0.964565] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.964703] io scheduler noop registered
[ 0.964991] io scheduler cfq registered (default)
[ 0.967800] gic 702f9000.agic: GIC IRQ controller registered
[ 0.970830] iommu: Adding device 702ef000.adsp to group 33
[ 0.980034] iommu: Adding device [email protected]:adsp_audio to group 34
[ 0.980208] tegra-aconnect [email protected]: Tegra ACONNECT bus registered
[ 0.980839] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x79e7c10
[ 0.980848] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.982602] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.982707] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.982796] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.982996] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.983090] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.983178] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.983274] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.983361] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.983449] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.983540] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.989726] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.991564] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.993444] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.994733] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.995102] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.996382] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.996605] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 0.996856] Adding domain tsec-pd to PM domain host1x-pd
[ 0.999231] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.000272] tsec 54500000.tsec: initialized
[ 1.001862] tsec 54100000.tsecb: initialized
[ 1.002646] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.006403] nvdec 54480000.nvdec: initialized
[ 1.007512] Adding domain vic03-pd to PM domain host1x-pd
[ 1.007702] Adding domain msenc-pd to PM domain host1x-pd
[ 1.007862] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.012165] falcon 54340000.vic: initialized
[ 1.013387] falcon 544c0000.nvenc: initialized
[ 1.014763] falcon 54380000.nvjpg: initialized
[ 1.019158] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.019204] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.019238] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.019527] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.019531] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.019535] tegra_cec 70015000.tegra_cec: probed
[ 1.019630] display board info: id 0x0, fab 0x0
[ 1.019702] generic_infoframe_type: 0x87
[ 1.019855] tegradc tegradc.0: DT parsed successfully
[ 1.019907] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.020502] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.024177] tegradc tegradc.0: probed
[ 1.029582] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.036632] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.037643] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.037653] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.038028] kfuse 7000fc00.kfuse: initialized
[ 1.039711] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.040902] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.042449] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.042470] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.043019] pwm-regulator pwm_regulators:[email protected]: PWM regulator registration passed
[ 1.044820] vdd-gpu: applied init 1000000uV constraint
[ 1.044827] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.045297] pwm-regulator pwm_regulators:[email protected]: PWM regulator registration passed
[ 1.050201] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.050444] No Device Node present for smmu client: serial8250 !!
[ 1.050461] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.050527] iommu: Adding device serial8250 to group 35
[ 1.052882] console [ttyS0] disabled
[ 1.053006] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.053108] console [ttyS0] enabled
[ 1.054046] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.054445] serial-tegra 70006200.serial: RX in PIO mode
[ 1.054557] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.055704] [drm] Initialized
[ 1.056292] Console: switching to colour frame buffer device 240x67
[ 1.056418] tegradc tegradc.0: fb registered
[ 1.064551] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.064608] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.065152] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.065169] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.066421] brd: module loaded
[ 1.072117] loop: module loaded
[ 1.072234] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.072390] tegra_profiler: auth: init
[ 1.073772] THERMAL EST: found 2 subdevs
[ 1.073781] THERMAL EST num_resources: 0
[ 1.073786] [THERMAL EST subdev 0]
[ 1.073792] [THERMAL EST subdev 1]
[ 1.074336] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.074342] THERMAL EST: thz register success.
[ 1.074740] THERMAL EST: end of probe, return err: 0
[ 1.076006] sd: No Scsi addr parsed to reserve index
[ 1.076044] hisi_sas: driver version v1.6
[ 1.081635] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.082964] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.082975] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.086078] libphy: Fixed MDIO Bus: probed
[ 1.087032] tun: Universal TUN/TAP device driver, 1.6
[ 1.087039] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.088066] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.088070] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.088128] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.088132] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.088179] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.088183] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.088228] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.088232] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.089439] PPP generic driver version 2.4.2
[ 1.089645] PPP BSD Compression module registered
[ 1.089651] PPP Deflate Compression module registered
[ 1.089694] PPP MPPE Compression module registered
[ 1.089702] NET: Registered protocol family 24
[ 1.089779] usbcore: registered new interface driver r8152
[ 1.089821] usbcore: registered new interface driver asix
[ 1.089870] usbcore: registered new interface driver ax88179_178a
[ 1.089910] usbcore: registered new interface driver cdc_ether
[ 1.089949] usbcore: registered new interface driver net1080
[ 1.089990] usbcore: registered new interface driver cdc_subset
[ 1.090032] usbcore: registered new interface driver zaurus
[ 1.090086] usbcore: registered new interface driver cdc_ncm
[ 1.090293] VFIO - User Level meta-driver version: 0.3
[ 1.091513] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.091519] Extcon AUX1(HDMI) enable
[ 1.092605] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.092679] tegradc tegradc.1: No lt-data, using default setting
[ 1.092712] tegradc tegradc.1: No hpd-gpio in DT
[ 1.092745] tegradc tegradc.1: DT parsed successfully
[ 1.092795] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 1.094498] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.094877] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.094898] ehci-pci: EHCI PCI platform driver
[ 1.094952] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.094963] ohci-pci: OHCI PCI platform driver
[ 1.095006] ohci-platform: OHCI generic platform driver
[ 1.097488] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.100805] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.102030] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f909ec00 id
[ 1.103345] usbcore: registered new interface driver uas
[ 1.103422] usbcore: registered new interface driver usb-storage
[ 1.103554] usbcore: registered new interface driver usbserial
[ 1.105012] tegradc tegradc.1: probed
[ 1.108906] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.108977] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.109015] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.109782] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.109836] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.110055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.110062] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.110067] usb usb1: Product: xHCI Host Controller
[ 1.110072] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.110077] usb usb1: SerialNumber: 70090000.xusb
[ 1.113091] tegradc tegradc.1: fb registered
[ 1.113401] hub 1-0:1.0: USB hub found
[ 1.113447] hub 1-0:1.0: 5 ports detected
[ 1.114127] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.114142] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.114178] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.114282] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.114382] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.114388] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.114394] usb usb2: Product: xHCI Host Controller
[ 1.114399] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.114403] usb usb2: SerialNumber: 70090000.xusb
[ 1.115657] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.115671] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.115690] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.115705] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.115732] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.116319] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.116326] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.116335] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.116351] tegradc tegradc.1: blank - powerdown
[ 1.116375] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.116381] Extcon DP: HPD disabled
[ 1.116388] hpd: hpd_switch 0
[ 1.116392] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.116401] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.116408] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.116619] mousedev: PS/2 mouse device common for all mice
[ 1.116739] usbcore: registered new interface driver xpad
[ 1.116770] hub 2-0:1.0: USB hub found
[ 1.116820] hub 2-0:1.0: 4 ports detected
[ 1.126228] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.214279] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.225687] tegradc tegradc.0: blank - powerdown
[ 1.247397] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.249528] rtc rtc1: alarm rtc device
[ 1.249540] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.249558] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.249954] i2c /dev entries driver
[ 1.251616] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.251924] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.251928] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.252468] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.263213] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.263216] Extcon AUX1(HDMI) disable
[ 1.275760] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.275841] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.275872] imx219 7-0010: board setup failed
[ 1.275933] imx219: probe of 7-0010 failed with error -121
[ 1.276334] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.294897] tegradc tegradc.0: unblank
[ 1.299641] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.299727] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.299758] imx219 8-0010: board setup failed
[ 1.299866] imx219: probe of 8-0010 failed with error -121
[ 1.301447] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.304471] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.304476] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.304978] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.304994] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.305003] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.305148] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.305159] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.305165] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.305321] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.305333] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.305338] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.305538] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.306497] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.306561] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.306589] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.306605] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.306614] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.307720] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.307741] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.307920] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.307951] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.308409] parse_throttle_dt_data: Num cap clks = 6
[ 1.308414] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.308429] parse_throttle_dt_data: clk=gpu type=4
[ 1.308458] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.308480] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.308505] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.308508] parse_throttle_dt_data: clk=emc type=3
[ 1.309019] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.309140] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.309275] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.310309] FAN dev name: pwm-fan
[ 1.310409] FAN:gpio request success.
[ 1.310495] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.310832] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.311026] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.311035] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.311138] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.311143] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.311148] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.311152] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.311156] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.311160] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.311164] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.311169] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.311173] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.311177] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.311668] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.311777] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.312104] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.312449] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.312904] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.312921] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.313434] device-mapper: uevent: version 1.0.3
[ 1.313926] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 1.319081] tegra210-cpufreq cpufreq: probe()…completed
[ 1.319814] sdhci: Secure Digital Host Controller Interface driver
[ 1.319815] sdhci: Copyright(c) Pierre Ossman
[ 1.319817] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.320324] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.320663] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.320788] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.324929] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.325443] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.326567] usbcore: registered new interface driver usbhid
[ 1.326568] usbhid: USB HID core driver
[ 1.328698] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.328864] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.330760] nvpmodel: initialized successfully
[ 1.331875] usbcore: registered new interface driver snd-usb-audio
[ 1.331932] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.331937] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.331953] iommu: Adding device snd-soc-dummy to group 36
[ 1.337422] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.347741] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.347743] Extcon AUX1(HDMI) enable
[ 1.349629] OPE platform probe
[ 1.349716] OPE platform probe successful
[ 1.350007] OPE platform probe
[ 1.350085] OPE platform probe successful
[ 1.363242] tegradc tegradc.0: sync windows ret = 246
[ 1.366363] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.373561] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.373691] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.373822] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.373954] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.374078] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.374220] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.374367] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.374502] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.374630] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.374760] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.386473] u32 classifier
[ 1.386474] Actions configured
[ 1.386549] Initializing XFRM netlink socket
[ 1.387258] NET: Registered protocol family 10
[ 1.387955] NET: Registered protocol family 17
[ 1.387967] NET: Registered protocol family 15
[ 1.388038] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.388082] Bluetooth: RFCOMM socket layer initialized
[ 1.388090] Bluetooth: RFCOMM ver 1.11
[ 1.388094] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.388098] Bluetooth: HIDP socket layer initialized
[ 1.388116] 9pnet: Installing 9P2000 support
[ 1.388151] Key type dns_resolver registered
[ 1.395457] Registered cp15_barrier emulation handler
[ 1.395494] Registered setend emulation handler
[ 1.402261] registered taskstats version 1
[ 1.402808] Adding domain ve2-pd to PM domain host1x-pd
[ 1.403058] Adding domain ve-pd to PM domain host1x-pd
[ 1.405253] isp 54600000.isp: initialized
[ 1.406242] isp 54680000.isp: initialized
[ 1.411888] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.411892] Extcon HDMI: HPD enabled
[ 1.411907] tegradc tegradc.0: hdmi: plugged
[ 1.416755] last reset is due to power on reset
[ 1.416759] KERNEL: PMC reset status reg: 0x0
[ 1.416821] BL: PMC reset status reg: 0x0
[ 1.416823] BL: PMIC poweroff Event Recorder: 0x40
[ 1.418388] clk_cbus_recalc_rate: no gbus parent
[ 1.418393] clk_cbus_round_rate: no gbus parent
[ 1.418396] clk_cbus_round_rate: no gbus parent
[ 1.418404] clk_cbus_recalc_rate: no gbus parent
[ 1.418507] clk_cbus_recalc_rate: no gbus parent
[ 1.418510] clk_cbus_round_rate: no gbus parent
[ 1.418513] clk_cbus_round_rate: no gbus parent
[ 1.418517] clk_cbus_recalc_rate: no gbus parent
[ 1.419183] tegra_dvfs: GPU-cap: registered
[ 1.419237] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.419240] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.419242] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.420729] tegra_dvfs: vdd-gpu-vts: registered
[ 1.421395] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.421982] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.422536] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.441680] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.442228] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.456273] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.457363] vi 54080000.vi: vi_probe: ++
[ 1.472832] vi 54080000.vi: initialized
[ 1.479144] vi 54080000.vi: subdev nvcsi–2 bound
[ 1.479252] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.480881] Disable partitions left on by BL
[ 1.480885] disb
[ 1.480932] bwmgr: missing cdev-type property
[ 1.481028] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.481035] DRAM derating cdev registered.
[ 1.481409] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.481414] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.481418] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.481421] usb 1-2: Manufacturer: Generic
[ 1.482116] vdd-fan: disabling
[ 1.482120] vdd-usb-vbus: disabling
[ 1.482122] vdd-usb-vbus2: disabling
[ 1.482133] vddio-sdmmc3-ap: disabling
[ 1.482809] avdd-io-edp-1v05: disabling
[ 1.482812] vdd-usb-hub-en: disabling
[ 1.483900] ALSA device list:
[ 1.483903] #0: tegra-hda at 0x70038000 irq 83
[ 1.483905] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.483915] hub 1-2:1.0: USB hub found
[ 1.484908] hub 1-2:1.0: 4 ports detected
[ 1.486999] Freeing unused kernel memory: 8576K
[ 1.511527] Root device found: mmcblk0p1
[ 1.570357] mmc0: hw tuning done …
[ 1.570404] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[ 1.570808] mmcblk0: mmc0:59b4 GD2S5 119 GiB
[ 1.574554] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.716138] Found dev node: /dev/mmcblk0p1
[ 1.751142] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.751944] Rootfs mounted over mmcblk0p1
[ 1.775979] Switching from initrd to actual rootfs
[ 1.782240] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 1.806854] usb 1-2.1: New USB device found, idVendor=0bda, idProduct=b812
[ 1.806860] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.806863] usb 1-2.1: Product: USB3.0 802.11ac 1200M Adapter
[ 1.806867] usb 1-2.1: Manufacturer: Realtek
[ 1.806870] usb 1-2.1: SerialNumber: 123456
[ 1.848466] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.886229] usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
[ 1.911277] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c016
[ 1.911283] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.911287] usb 1-2.2: Product: Optical USB Mouse
[ 1.911290] usb 1-2.2: Manufacturer: Logitech
[ 1.914380] input: Logitech Optical USB Mouse as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C016.0001/input/input2
[ 1.914603] hid-generic 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-70090000.xusb-2.2/input0
[ 1.955769] systemd[1]: System time before build time, advancing clock.
[ 1.980089] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.992082] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.998229] usb 1-2.4: new low-speed USB device number 5 using tegra-xusb
[ 2.009722] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.010539] systemd[1]: Detected architecture arm64.
[ 2.027255] usb 1-2.4: New USB device found, idVendor=03f0, idProduct=0024
[ 2.027260] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.027263] usb 1-2.4: Product: HP Basic USB Keyboard
[ 2.027266] usb 1-2.4: Manufacturer: CHICONY
[ 2.032920] systemd[1]: Set hostname to <Optical-nano>.
[ 2.033072] input: CHICONY HP Basic USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:03F0:0024.0002/input/input3
[ 2.038228] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.094666] hid-generic 0003:03F0:0024.0002: input,hidraw1: USB HID v1.10 Keyboard [CHICONY HP Basic USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 2.102800] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.102804] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.132679] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.132689] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.257508] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.259576] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.263472] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.263505] systemd[1]: Reached target User and Group Name Lookups.
[ 2.263694] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.265384] systemd[1]: Created slice User and Session Slice.
[ 2.265435] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.265457] systemd[1]: Reached target Swap.
[ 2.266297] systemd[1]: Created slice System Slice.
[ 2.266657] systemd[1]: Listening on Journal Audit Socket.
[ 2.307000] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.362899] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.362907] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.362911] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.362914] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.362919] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.362940] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.363002] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.363162] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.363278] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.363303] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.363333] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.363353] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.363487] pci 0000:01:00.0: supports D1 D2
[ 2.363491] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.374320] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.374352] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.374357] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.374365] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.374383] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.374400] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.374408] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.374412] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.374418] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.374708] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.374712] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.374718] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.374811] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.374994] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.375011] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.392864] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.392936] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e7:0b:76 from device tree
[ 2.393522] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.393536] r8168 Copyright (C) 2017 Realtek NIC software team <[email protected]>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.440784] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.452049] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.452073] cpu-throttle-alert cooling device registered.
[ 2.452191] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.452206] gpu-throttle-alert cooling device registered.
[ 2.452378] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.452391] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.452405] hot-surface-alert cooling device registered.
[ 2.581443] systemd-journald[1990]: Received request to flush runtime journal from PID 1
[ 3.526567] random: crng init done
[ 3.530000] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.786832] using random self ethernet address
[ 3.791593] using random host ethernet address
[ 4.723891] Mass Storage Function, version: 2009/09/11
[ 4.723898] LUN: removable file: (no medium)
[ 4.728830] using random self ethernet address
[ 4.733354] using random host ethernet address
[ 4.788218] rndis0: HOST MAC 8e:ae:57:2f:b9:14
[ 4.788965] rndis0: MAC 8e:ae:57:2f:b9:15
[ 4.795968] usb0: HOST MAC 8e:ae:57:2f:b9:16
[ 4.796009] usb0: MAC 8e:ae:57:2f:b9:17
[ 4.796049] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.801098] l4tbr0: port 1(rndis0) entered blocking state
[ 4.801104] l4tbr0: port 1(rndis0) entered disabled state
[ 4.801288] device rndis0 entered promiscuous mode
[ 4.815982] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.821331] l4tbr0: port 2(usb0) entered blocking state
[ 4.821336] l4tbr0: port 2(usb0) entered disabled state
[ 4.822847] device usb0 entered promiscuous mode
[ 4.846616] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.863725] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.864854] eth0: 0xffffff800d553000, 00:04:4b:e7:0b:76, IRQ 407
[ 4.970510] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.276382] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.276389] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.312830] zram: Added device: zram0
[ 5.316404] zram: Added device: zram1
[ 5.318850] zram: Added device: zram2
[ 5.321168] zram: Added device: zram3
[ 5.340721] zram0: detected capacity change from 0 to 518541312
[ 5.372506] Adding 506384k swap on /dev/zram0. Priority:5 extents:1 across:506384k SS
[ 5.377340] zram1: detected capacity change from 0 to 518541312
[ 5.389520] Adding 506384k swap on /dev/zram1. Priority:5 extents:1 across:506384k SS
[ 5.393600] zram2: detected capacity change from 0 to 518541312
[ 5.408004] Adding 506384k swap on /dev/zram2. Priority:5 extents:1 across:506384k SS
[ 5.411691] zram3: detected capacity change from 0 to 518541312
[ 5.423448] Adding 506384k swap on /dev/zram3. Priority:5 extents:1 across:506384k SS
[ 5.602638] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.632195] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.632202] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.632206] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.632209] usb 2-1: Manufacturer: Generic
[ 5.635639] hub 2-1:1.0: USB hub found
[ 5.636437] hub 2-1:1.0: 4 ports detected
[ 5.790264] usb 2-1: usb_suspend_both: status 0
[ 5.790456] usb usb2: usb_suspend_both: status 0
[ 6.422702] usbcore: registered new interface driver rtl88x2bu
[ 6.474875] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.105062] tegradc tegradc.0: unblank
[ 7.105337] tegradc tegradc.1: blank - powerdown
[ 7.241478] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 7.259384] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.336556] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.239574] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.239586] Bluetooth: BNEP socket layer initialized
[ 10.623892] fuse init (API version 7.26)
[ 11.688090] tegradc tegradc.0: unblank
[ 11.688101] tegradc tegradc.1: blank - powerdown
[ 13.656651] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 13.809601] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1463.166877] tegradc tegradc.0: blank - powerdown
[ 1463.226760] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1463.226763] Extcon AUX1(HDMI) disable
[ 1463.260282] tegradc tegradc.0: unblank
[ 1463.267134] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1463.267222] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1463.268278] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1463.268285] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1463.304222] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1463.304224] Extcon AUX1(HDMI) enable
[ 1463.345394] tegradc tegradc.0: unblank
[ 1463.345404] tegradc tegradc.1: blank - powerdown
[ 1463.498162] PM: suspend entry 2020-11-04 01:32:16.249262816 UTC
[ 1463.498168] PM: Syncing filesystems … done.
[ 1463.623193] PM: Preparing system for sleep (mem)
[ 1463.626934] tegradc tegradc.0: blank - powerdown
[ 1463.685333] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1463.685336] Extcon AUX1(HDMI) disable
[ 1463.705892] tegradc tegradc.1: blank - powerdown
[ 1463.738316] tegradc tegradc.0: blank - powerdown
[ 1463.738376] tegradc tegradc.0: unblank
[ 1463.746987] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1463.747149] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1463.748312] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1463.748319] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1463.784206] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1463.784208] Extcon AUX1(HDMI) enable
[ 1463.798641] tegradc tegradc.0: sync windows ret = 247
[ 1463.843833] tegra_dvfs: suspended
[ 1463.843839] Freezing user space processes …
[ 1464.324826] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1464.351058] (elapsed 0.507 seconds) done.
[ 1464.351065] Freezing remaining freezable tasks … (elapsed 0.001 seconds) done.
[ 1464.352325] PM: Suspending system (mem)
[ 1464.358804] usb 2-1: usb_suspend_both: status 0
[ 1464.363894] usb usb2: usb_suspend_both: status 0
[ 1464.367146] usb 1-2.2: usb_suspend_both: status 0
[ 1464.367171] sdhci-tegra sdhci-tegra.0: Tuning done, restoring the best tap value : 19
[ 1464.368152] tegra_cec 70015000.tegra_cec: suspended
[ 1464.373159] tegra-xudc-new 700d0000.xudc: device mode off: 0
[ 1464.373181] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 0
[ 1464.373191] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1464.373511] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1464.373528] sdhci-tegra sdhci-tegra.0: Tuning done, restoring the best tap value : 19
[ 1464.379986] usb 1-2.1: usb_suspend_both: status 0
[ 1464.380578] tegradc tegradc.1: suspend
[ 1464.380581] tegradc tegradc.0: suspend
[ 1464.380737] hpd: state 3 (Disabled), hpd 0, pending_hpd_evt 1
[ 1464.380739] hpd: request suspend
[ 1464.380742] hpd: switching from state 3 (Disabled) to state 3 (Disabled)
[ 1464.382035] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1464.382038] Extcon AUX1(HDMI) disable
[ 1464.396155] usb 1-2.4: usb_suspend_both: status 0
[ 1464.416179] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 1464.436117] usb 1-2: usb_suspend_both: status 0
[ 1464.436187] usb usb1: usb_suspend_both: status 0
[ 1464.436313] tegra-xusb 70090000.xusb: entering ELPG
[ 1464.437404] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 1464.437597] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 1464.439112] tegra-xusb 70090000.xusb: entering ELPG done
[ 1464.439253] PM: suspend of devices complete after 80.581 msecs
[ 1464.441226] host1x 50000000.host1x: suspended
[ 1464.441451] PM: late suspend of devices complete after 2.188 msecs
[ 1464.444346] PM: noirq suspend of devices complete after 2.884 msecs
[ 1464.444355] Disabling non-boot CPUs …
[ 1464.468578] IRQ10 no longer affine to CPU1
[ 1464.473049] CPU1: shutdown
[ 1464.475869] psci: CPU1 killed.
[ 1464.500583] IRQ11 no longer affine to CPU2
[ 1464.505325] CPU2: shutdown
[ 1464.508474] psci: CPU2 killed.
[ 1464.536542] IRQ12 no longer affine to CPU3
[ 1464.541103] CPU3: shutdown
[ 1464.543923] psci: CPU3 killed.
[ 1464.552627] tegra-pmc: PMC wake level = 0x40178800010000
[ 1464.552627] tegra-pmc: PMC wake enable = 0x48178801010001
[ 1464.552627] Entered SC7
[ 1464.552627] Exited SC7
[ 1464.552627] tegra-pmc: PMC wake status = 0x10000000000
[ 1464.552627] tegra-pmc: Resume caused by PMC WAKE40, xhci-hcd:usb1
[ 1464.552627] Suspended for 68286.218 seconds
[ 1464.552846] Enabling non-boot CPUs …
[ 1464.553234] CPU1: Booted secondary processor [411fd071]
[ 1464.553719] cache: parent cpu1 should not be sleeping
[ 1464.559303] CPU1 is up
[ 1464.559619] CPU2: Booted secondary processor [411fd071]
[ 1464.559825] cache: parent cpu2 should not be sleeping
[ 1464.565349] CPU2 is up
[ 1464.565582] CPU3: Booted secondary processor [411fd071]
[ 1464.565839] cache: parent cpu3 should not be sleeping
[ 1464.571474] CPU3 is up
[ 1464.573406] tegra-xusb 70090000.xusb: exiting ELPG
[ 1464.574829] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1464.577166] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1464.577428] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 1464.577449] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 1464.577468] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 1464.578276] tegra-xusb 70090000.xusb: exiting ELPG done
[ 1464.580615] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1464.582719] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1465.004206] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1465.408019] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1465.812028] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1465.814041] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 1465.921043] PM: noirq resume of devices complete after 1349.559 msecs
[ 1465.922447] host1x 50000000.host1x: resuming
[ 1465.924320] PM: early resume of devices complete after 2.348 msecs
[ 1465.924922] tegradc tegradc.0: resume
[ 1465.924943] tegradc tegradc.1: resume
[ 1465.928037] hpd: state 3 (Disabled), hpd 0, pending_hpd_evt 1
[ 1465.928040] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[ 1465.928046] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1465.928055] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1465.928057] Extcon DP: HPD disabled
[ 1465.928059] hpd: hpd_switch 0
[ 1465.928062] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1465.928067] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1465.928072] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1465.929612] sdhci-tegra sdhci-tegra.0: Tuning done, restoring the best tap value : 19
[ 1465.929723] sdhci-tegra sdhci-tegra.0: Tuning done, restoring the best tap value : 19
[ 1465.941081] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 1465.941646] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 1465.941651] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1465.941659] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1465.941668] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1465.941676] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1465.941722] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1465.941729] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1465.941733] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1465.941738] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1465.941743] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1465.941747] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1465.941752] tegra_cec 70015000.tegra_cec: Resuming
[ 1465.946615] extcon-gpio-states extcon:[email protected]: Cable state:1, cable id:1
[ 1465.946724] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1466.043750] tegradc tegradc.0: read_edid_into_buffer: extension_blocks = 1, max_ext_blocks = 3
[ 1466.059482] tegradc tegradc.0: hdmi_recheck_edid: read_edid_into_buffer() returned 256
[ 1466.059487] tegradc tegradc.0: old edid len = 256
[ 1466.059491] tegradc tegradc.0: hdmi: No EDID change after HPD bounce, taking no action
[ 1466.064234] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1466.064264] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1466.065343] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1466.065351] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1466.100351] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1466.100355] Extcon AUX1(HDMI) enable
[ 1466.237080] sdhci-tegra sdhci-tegra.0: Tuning done, restoring the best tap value : 19
[ 1466.767209] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1466.784222] PM: resume of devices complete after 859.914 msecs
[ 1466.785144] PM: Finishing wakeup.
[ 1466.785146] Restarting tasks … done.
[ 1466.832167] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1466.832199] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1466.832214] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1466.835853] tegra_dvfs: resumed
[ 1466.842168] PM: suspend exit 2020-11-04 20:30:25.811654068 UTC
[ 1466.856012] usb 2-1: usb_suspend_both: status 0
[ 1466.856153] usb usb2: usb_suspend_both: status 0
[ 1466.963998] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 1466.996554] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1466.997647] eth0: 0xffffff800d553000, 00:04:4b:e7:0b:76, IRQ 407
[ 1467.048040] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1467.051488] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1467.132450] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1467.688693] tegradc tegradc.0: unblank
[ 1467.688703] tegradc tegradc.1: blank - powerdown
[ 1467.741406] tegradc tegradc.0: unblank
[ 1467.741563] tegradc tegradc.1: blank - powerdown
[ 1472.502530] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1472.658373] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 7736.677535] tegradc tegradc.0: blank - powerdown
[ 7736.732685] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 7736.732687] Extcon AUX1(HDMI) disable
[12484.522805] tegradc tegradc.0: unblank
[12484.528073] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[12484.528173] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[12484.529251] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[12484.529258] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[12484.564058] extcon-disp-state extcon:disp-state: cable 47 state 1
[12484.564060] Extcon AUX1(HDMI) enable
[12484.587638] tegradc tegradc.0: unblank
[12484.587648] tegradc tegradc.1: blank - powerdown
[16621.789930] tegradc tegradc.0: blank - powerdown
[16621.852106] extcon-disp-state extcon:disp-state: cable 47 state 0
[16621.852107] Extcon AUX1(HDMI) disable
[38410.204080] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[75348.058174] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[88295.187028] tegradc tegradc.0: unblank
[88295.192296] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[88295.192397] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[88295.193565] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[88295.193572] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[88295.228333] extcon-disp-state extcon:disp-state: cable 47 state 1
[88295.228336] Extcon AUX1(HDMI) enable
[88295.272474] tegradc tegradc.0: unblank
[88295.272484] tegradc tegradc.1: blank - powerdown
[90105.377118] tegradc tegradc.0: blank - powerdown
[90105.439199] extcon-disp-state extcon:disp-state: cable 47 state 0
[90105.439201] Extcon AUX1(HDMI) disable
[112284.633429] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[149223.984085] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[175210.027253] tegradc tegradc.0: unblank
[175210.032633] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[175210.032718] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[175210.033792] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[175210.033799] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[175210.068650] extcon-disp-state extcon:disp-state: cable 47 state 1
[175210.068653] Extcon AUX1(HDMI) enable
[175210.076412] tegradc tegradc.0: unblank
[175210.076422] tegradc tegradc.1: blank - powerdown
[178598.462936] tegradc tegradc.0: blank - powerdown
[178598.525205] extcon-disp-state extcon:disp-state: cable 47 state 0
[178598.525207] Extcon AUX1(HDMI) disable
[186157.956353] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[223096.481847] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[260034.174945] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[296968.679967] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[333906.340552] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[370842.272285] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[407778.762080] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[439411.268146] tegradc tegradc.0: unblank
[439411.273443] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[439411.273543] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[439411.274587] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[439411.274595] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[439411.309451] extcon-disp-state extcon:disp-state: cable 47 state 1
[439411.309454] Extcon AUX1(HDMI) enable
[439411.320394] tegradc tegradc.0: unblank
[439411.320411] tegradc tegradc.1: blank - powerdown
Have you ever found similar problems caused by software? I am not sure what caused that.
Connect through forum is too slow, it cost us a week and nothing happened. Any idea so we can chat?
