I need proper instructions for installing the 16MP AF Camera on a fresh Raspbian, preferably 12 Bookworm
    Kickstarter
    Arducam 16MP High-Resolution Autofocus camera
    RPI3; Raspbian GNU/Linux 11 (bullseye)
sudo raspi-config
sudo cp /boot/config.txt /boot/config.txt.original
echo "dtoverlay=imx519" | sudo tee -a /boot/config.txt
sudo reboot now
sudo libcamera-still --list-cameras
./install_pivariety_pkgs.sh -d
sudo reboot now
  1. Problems you were having?
    Camera not detected.
  2. The dmesg log from your hardware?
    Arducam 16MP Autofocus install failure · GitHub
  3. Troubleshooting attempts you’ve made?
    I have the same hardware working on an install on an RPi4, but I can’ make it work on a new install.
  4. What help do you need?
It shows the hardware part of the camera is normal, isn’t it?
Interesting, on Bookworm OS, the config.txt file is moved to /boot/firmware/config.txt instead of /boot/config.txt on Bullseye OS. Hence,
should be
echo "dtoverlay=imx519" | sudo tee -a /boot/firmware/config.txt
Hope it will help you.
I try to connect B0371 camera to RPI4B. What is the proper way to do it. In what order software should be installed. OS Bookworm, Klipper. Kiauh used for installation.
libcamera-still -t 5000 -n -o test.jpg works and picture is saved in home directory. Mainsail does not see camera. Do I need to install crowsnest?
