I²C not detected after unexpected power loss – Arducam Multi-Camera Kit (SKU B0397) with Jetson Orin NX
Hello Arducam Team,
I am using the Arducam Multi-Camera Kit for Jetson Orin, SKU: B0397.
The system was working correctly before an unexpected power outage / sudden power OFF–ON caused by electricity issues.
After this accidental power event, I am now facing a complete I²C detection failure.
Current Situation
  • Jetson Orin boots normally
  • Arducam multi-camera board powers ON
  • No visible physical damage
  • Cameras are no longer detected
  • I²C devices are not detected at all
What Changed
  • No hardware modifications
  • No cable changes or reconnections
  • The issue appeared only after the unexpected power interruption
This leads me to suspect that the I²C lines (SDA/SCL) may be stuck, damaged, or not recovering properly after the power event.
###I²C Scan Results (Bus 7)
I scanned the I²C bus used by the Arducam kit. Below is the output:
$ sudo i2cdetect -y 7
00: – – – – – – – – – – – – – – – –
70: – – – – – – – –
No I²C devices are detected on bus 7, whereas the setup was previously working without issues.
Debug Steps Already Taken
  • Multiple reboots and full power cycles
  • Verified that power rails are present and stable
  • Re-ran I²C scans multiple times
  • Issue persists consistently
Help / Guidance Requested
Could you please advise on:
  1. How to diagnose possible I²C line damage or lock-up after power loss
  2. Any recommended recovery steps specific to this multi-camera kit
  3. Whether the board includes I²C protection against power glitches
  4. Hardware-level checks you recommend (pull-ups, reset lines, isolating camera ports, etc.)
Since the setup was stable before the power incident, I believe this may be a recoverable I²C-related issue, and I would appreciate your guidance on how to proceed.
Thank you for your support.
@arducam-support-team
@Dion Any help regarding this will be highly appericiated
Could you please try powering the HAT board directly via the USB Type-C port using an external power adapter, and let us know the status of the indicator LEDs? Do you see the green led blinks when powering it?
Thank you for your response. @Dion
Yes, when i power on the HAT with USB-C type, red led glow properly and the green led start blinking.
@Dion @arducam-support-team
Cam Array Hat red led constantly powered-on and the green blinks on the power-up. But the Camera Array HAT is no longer communicating over the I²C bus. The HAT powers up, but no I²C devices are detected.
Is it possible to reprogram or recover the Camera Array HAT to restore I²C communication, or does this behavior generally indicate that the HAT’s I²C hardware has been damaged?
Any guidance or troubleshooting suggestions would be greatly appreciated.
I tried running it on the Raspberry Pi 4 Raspbian GNU/Linux 12 (bookworm) but still its not working. Screenshots are attached pls let me know if there is any solution possible.
Looking forward to your feedback
Screenshot 2026-07-02 144113
Hi @ahmadjamal
Actually, with ox24 observed in bus 10, the HAT board is detected by your Raspberry Pi.
It seems that the RPI cannot identify the camera modules. To proceed with the next step, could you please send us photos of the hardware connection?
