Hey @Edward , Thanks for the reply.
Which software tool did you use to record this video? I will use the same and send across the video.
Also to add more context, the image I shared was taken with opencv (VideoCapture().read(mat))
I just use the camera software that comes with windows and open the recording with obisp. You can also try using the camera software that comes with Windows.
I read out my firmware and send it to you, you can try it with the same status as mine.
2286-IMX477-A-V220120_V0_02-YinHu_IPC.src (256 KB)
Guide and software
CommonBurnerAP_B0278.7z (2.3 MB)
Please try it again
Hello, Thanks for sharing the updated firmware.
Now, I am unable to set width and height with the new firmware.
Please find the java code below (uses opencv)
VideoCapture capture = new VideoCapture(“/dev/video0”, Videoio.CAP_V4L2);
capture.set(Videoio.CAP_PROP_FRAME_WIDTH, 4032);
capture.set(Videoio.CAP_PROP_FRAME_HEIGHT, 3040);
If I skip setting HEIGHT and WIDTH, I am getting a image of size (0,0)
Before using the code directly, could you please test it first using existing software
Hi @Edward , Do you mean with the old firmware that was already on the board? I tested that and gotten partial black images.
Also, now that I have flashed the board with new firmware you have provided, I do not have old firmware which I can use.
I mean can you open the camera with software like amcap or vlc. You are currently using code to use the camera.
I have also tested flashing the new firmware and for me the whole process has been smooth.
