IMX519
NVIDIA Jetson Nano B01.
ArduCAM/Jetson_IMX519_Focus_Example (github.com)
werate-01@werate-01:~/Arducam-IMX519$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 4656x3496
Interval: Discrete 0.100s (10.000 fps)
Size: Discrete 3840x2160
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.008s (120.000 fps)
- Problems you were having?
I can’t use 2328x1748 sensor which exists if I plug the IMX519 to Raspberry Pi 4B. This sensor does not exist in NVIDIA Jetson Nano B01.
I use 4656x3496 sensor because it has the same aspect ratio which is 1,3:1 . However it is slow, it only have 10 fps instead of 30 fps.
- What help do you need?
I need help on how to use the 2328x1748 sensor or any sensor with aspect ratio 1,3:1 (other available sensor have aspect ratio 1,7:1) that have higher fps in NVIDIA Jetson Nano B01.
