How to take 256mp pictures with the quad-64mp kit? I can only get a 64mp image (ie each cam operates at 16mp)
    Arducam online.
    Quad-kit with 4 x 64mp cameras.
    Raspberry Pi 4 model b, 8gb; Bullseye (2022-04-04).
    Getting started manual; no problem getting a picture that is multiplexed of 4 cameras, but each cam working at 16mp resolution.
  5. Problems you were having?
    Unable to save an image above 64mp resolution (ie, each camera sends a 16mp image instead of a 64mp image).
    [ 0.000000] Linux version 5.15.32-v8+ ([email protected]) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022
    [ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
    [ 0.000000] Zone ranges:
    [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
    [ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
    [ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
    [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
    [ 0.000000] percpu: Embedded 28 pages/cpu s77144 r8192 d29352 u114688
    [ 0.000000] pcpu-alloc: s77144 r8192 d29352 u114688 alloc=28*4096
    [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2028848
    [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:90:5D:C7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=811068d4-02 rootfstype=ext4 fsck.repair=yes rootwait
    [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
    [ 0.000000] Memory: 7471900K/8245248K available (11456K kernel code, 1962K rwdata, 4144K rodata, 3776K init, 964K bss, 249060K reserved, 524288K cma-reserved)
    [ 0.000000] ftrace: allocating 37889 entries in 149 pages
    [ 0.000000] ftrace: allocated 149 pages with 4 groups
    [ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 10)
    [ 0.000000] random: get_random_bytes called from start_kernel+0x510/0x6f8 with crng_init=1
    [ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [ 0.000255] Console: colour dummy device 80x25
    [ 0.000814] printk: console [tty1] enabled
    [ 0.000894] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
    [ 0.000935] pid_max: default: 32768 minimum: 301
    [ 0.001070] LSM: Security Framework initializing
    [ 0.001294] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [ 0.001417] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [ 0.002651] cgroup: Disabling memory control group subsystem
    [ 0.005147] rcu: Hierarchical SRCU implementation.
    [ 0.006274] EFI services will not be available.
    [ 0.006823] smp: Bringing up secondary CPUs …
    [ 0.007889] Detected PIPT I-cache on CPU1
    [ 0.007971] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
    [ 0.009114] Detected PIPT I-cache on CPU2
    [ 0.009164] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
    [ 0.010272] Detected PIPT I-cache on CPU3
    [ 0.010321] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
    [ 0.010469] smp: Brought up 1 node, 4 CPUs
    [ 0.010560] SMP: Total of 4 processors activated.
    [ 0.010581] CPU features: detected: 32-bit EL0 Support
    [ 0.010601] CPU features: detected: 32-bit EL1 Support
    [ 0.010623] CPU features: detected: CRC32 instructions
    [ 0.041852] CPU: All CPU(s) started at EL2
    [ 0.041947] alternatives: patching kernel code
    [ 0.044085] devtmpfs: initialized
    [ 0.054994] Enabled cp15_barrier support
    [ 0.055062] Enabled setend support
    [ 0.055261] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [ 0.055310] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [ 0.072739] pinctrl core: initialized pinctrl subsystem
    [ 0.073594] DMI not present or invalid.
    [ 0.074083] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [ 0.077746] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [ 0.078063] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [ 0.078981] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [ 0.079091] audit: initializing netlink subsys (disabled)
    [ 0.079399] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
    [ 0.079914] thermal_sys: Registered thermal governor ‘step_wise’
    [ 0.080139] cpuidle: using governor menu
    [ 0.080470] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [ 0.080668] ASID allocator initialised with 65536 entries
    [ 0.080837] Serial: AMBA PL011 UART driver
    [ 0.094249] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [ 0.120377] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:26, variant start
    [ 0.124398] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
    [ 0.175508] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [ 0.179864] vgaarb: loaded
    [ 0.180311] SCSI subsystem initialized
    [ 0.180537] usbcore: registered new interface driver usbfs
    [ 0.180660] usbcore: registered new interface driver hub
    [ 0.180740] usbcore: registered new device driver usb
    [ 0.181120] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [ 0.181603] pps_core: LinuxPPS API ver. 1 registered
    [ 0.181629] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
    [ 0.181667] PTP clock support registered
    [ 0.183091] clocksource: Switched to clocksource arch_sys_counter
    [ 0.275655] VFS: Disk quotas dquot_6.6.0
    [ 0.275783] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [ 0.275963] FS-Cache: Loaded
    [ 0.276217] CacheFiles: Loaded
    [ 0.286990] NET: Registered PF_INET protocol family
    [ 0.287952] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [ 0.293985] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [ 0.294107] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [ 0.294554] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [ 0.295544] TCP: Hash tables configured (established 65536 bind 65536)
    [ 0.295887] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [ 0.296040] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [ 0.296446] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [ 0.297521] RPC: Registered named UNIX socket transport module.
    [ 0.297553] RPC: Registered udp transport module.
    [ 0.297574] RPC: Registered tcp transport module.
    [ 0.297593] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.297623] PCI: CLS 0 bytes, default 64
    [ 0.300436] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [ 0.300808] kvm [1]: IPA Size Limit: 44 bits
    [ 0.301978] kvm [1]: vgic interrupt IRQ9
    [ 0.302254] kvm [1]: Hyp mode initialized successfully
    [ 1.197849] Initialise system trusted keyrings
    [ 1.198256] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [ 1.205236] zbud: loaded
    [ 1.207147] FS-Cache: Netfs ‘nfs’ registered for caching
    [ 1.207872] NFS: Registering the id_resolver key type
    [ 1.207938] Key type id_resolver registered
    [ 1.207960] Key type id_legacy registered
    [ 1.208078] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
    [ 1.208104] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
    [ 1.209314] Key type asymmetric registered
    [ 1.209343] Asymmetric key parser ‘x509’ registered
    [ 1.209433] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [ 1.209724] io scheduler mq-deadline registered
    [ 1.209751] io scheduler kyber registered
    [ 1.217905] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
    [ 1.217971] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
    [ 1.218073] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
    [ 1.218167] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
    [ 1.281191] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [ 1.281576] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [ 1.281607] pci_bus 0000:00: root bus resource [bus 00-ff]
    [ 1.281635] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [ 1.281736] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [ 1.281993] pci 0000:00:00.0: PME# supported from D0 D3hot
    [ 1.286216] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [ 1.286355] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [ 1.286790] pci 0000:01:00.0: PME# supported from D0 D3hot
    [ 1.290859] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [ 1.290900] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [ 1.290954] pci 0000:00:00.0: PCI bridge to [bus 01]
    [ 1.290986] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
    [ 1.300219] iproc-rng200 fe104000.rng: hwrng registered
    [ 1.300847] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [ 1.302343] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [ 1.302783] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [ 1.314051] brd: module loaded
    [ 1.323673] loop: module loaded
    [ 1.324508] Loading iSCSI transport class v2.0-870.
    [ 1.329497] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [ 1.387248] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [ 1.388412] usbcore: registered new interface driver r8152
    [ 1.388508] usbcore: registered new interface driver lan78xx
    [ 1.388574] usbcore: registered new interface driver smsc95xx
    [ 1.436061] pci 0000:00:00.0: enabling device (0000 → 0002)
    [ 1.436260] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [ 1.436304] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [ 1.437049] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
    [ 1.438383] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
    [ 1.438421] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 1.438450] usb usb1: Product: xHCI Host Controller
    [ 1.438472] usb usb1: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
    [ 1.438495] usb usb1: SerialNumber: 0000:01:00.0
    [ 1.439297] hub 1-0:1.0: USB hub found
    [ 1.439407] hub 1-0:1.0: 1 port detected
    [ 1.440080] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [ 1.440116] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [ 1.440152] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [ 1.440617] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
    [ 1.440653] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 1.440681] usb usb2: Product: xHCI Host Controller
    [ 1.440703] usb usb2: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
    [ 1.440726] usb usb2: SerialNumber: 0000:01:00.0
    [ 1.441388] hub 2-0:1.0: USB hub found
    [ 1.441466] hub 2-0:1.0: 4 ports detected
    [ 1.443187] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [ 1.443531] dwc_otg: FIQ enabled
    [ 1.443543] dwc_otg: NAK holdoff enabled
    [ 1.443552] dwc_otg: FIQ split-transaction FSM enabled
    [ 1.443566] Module dwc_common_port init
    [ 1.444131] usbcore: registered new interface driver uas
    [ 1.444241] usbcore: registered new interface driver usb-storage
    [ 1.444479] mousedev: PS/2 mouse device common for all mice
    [ 1.449973] sdhci: Secure Digital Host Controller Interface driver
    [ 1.450010] sdhci: Copyright(c) Pierre Ossman
    [ 1.450695] sdhci-pltfm: SDHCI platform and OF driver helper
    [ 1.454301] ledtrig-cpu: registered to indicate activity on CPUs
    [ 1.454906] hid: raw HID events driver (C) Jiri Kosina
    [ 1.455107] usbcore: registered new interface driver usbhid
    [ 1.455133] usbhid: USB HID core driver
    [ 1.455484] ashmem: initialized
    [ 1.464243] Initializing XFRM netlink socket
    [ 1.464317] NET: Registered PF_PACKET protocol family
    [ 1.464443] Key type dns_resolver registered
    [ 1.465564] registered taskstats version 1
    [ 1.465610] Loading compiled-in X.509 certificates
    [ 1.466273] Key type ._fscrypt registered
    [ 1.466299] Key type .fscrypt registered
    [ 1.466319] Key type fscrypt-provisioning registered
    [ 1.478399] uart-pl011 fe201000.serial: there is not valid maps for state default
    [ 1.478722] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [ 1.478891] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
    [ 1.487824] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [ 1.488320] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [ 1.489485] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [ 1.489518] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [ 1.519731] of_cfs_init
    [ 1.519913] of_cfs_init: OK
    [ 1.555728] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
    [ 1.556220] Waiting for root device PARTUUID=811068d4-02…
    [ 1.608195] mmc1: new high speed SDIO card at address 0001
    [ 1.652201] mmc0: new ultra high speed DDR50 SDHC card at address 0001
    [ 1.653258] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
    [ 1.656438] mmcblk0: p1 p2
    [ 1.656981] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
    [ 1.677199] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [ 1.677333] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [ 1.682866] devtmpfs: mounted
    [ 1.691027] Freeing unused kernel memory: 3776K
    [ 1.691291] Run /sbin/init as init process
    [ 1.691316] with arguments:
    [ 1.691325] /sbin/init
    [ 1.691335] with environment:
    [ 1.691343] HOME=/
    [ 1.691353] TERM=linux
    [ 1.695166] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [ 1.845751] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [ 1.845826] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [ 1.845853] usb 1-1: Product: USB2.0 Hub
    [ 1.847979] hub 1-1:1.0: USB hub found
    [ 1.848273] hub 1-1:1.0: 4 ports detected
    [ 2.038732] systemd[1]: System time before build time, advancing clock.
    [ 2.137486] NET: Registered PF_INET6 protocol family
    [ 2.139438] Segment Routing with IPv6
    [ 2.139497] In-situ OAM (IOAM) with IPv6
    [ 2.191295] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    [ 2.192260] systemd[1]: Detected architecture arm64.
    [ 2.200276] systemd[1]: Set hostname to .
    [ 2.871114] systemd[1]: Queued start job for default target Multi-User System.
    [ 2.873316] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.875653] systemd[1]: Created slice system-getty.slice.
    [ 2.876527] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.877592] systemd[1]: Created slice system-modprobe.slice.
    [ 2.878000] random: systemd: uninitialized urandom read (16 bytes read)
    [ 2.878958] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [ 2.880211] systemd[1]: Created slice User and Session Slice.
    [ 2.881054] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [ 2.881835] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [ 2.883280] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [ 2.883861] systemd[1]: Reached target Local Encrypted Volumes.
    [ 2.884406] systemd[1]: Reached target Paths.
    [ 2.884870] systemd[1]: Reached target Slices.
    [ 2.885319] systemd[1]: Reached target Swap.
    [ 2.886574] systemd[1]: Listening on Syslog Socket.
    [ 2.887674] systemd[1]: Listening on fsck to fsckd communication Socket.
    [ 2.888380] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [ 2.889878] systemd[1]: Listening on Journal Audit Socket.
    [ 2.890970] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 2.892359] systemd[1]: Listening on Journal Socket.
    [ 2.899328] systemd[1]: Listening on udev Control Socket.
    [ 2.900725] systemd[1]: Listening on udev Kernel Socket.
    [ 2.901996] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [ 2.906085] systemd[1]: Mounting POSIX Message Queue File System…
    [ 2.910809] systemd[1]: Mounting RPC Pipe File System…
    [ 2.916514] systemd[1]: Mounting Kernel Debug File System…
    [ 2.921941] systemd[1]: Mounting Kernel Trace File System…
    [ 2.922904] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    [ 2.932237] systemd[1]: Starting Restore / save the current clock…
    [ 2.940641] systemd[1]: Starting Set the console keyboard layout…
    [ 2.946905] systemd[1]: Starting Create list of static device nodes for the current kernel…
    [ 2.953585] systemd[1]: Starting Load Kernel Module configfs…
    [ 2.959900] systemd[1]: Starting Load Kernel Module drm…
    [ 2.966191] systemd[1]: Starting Load Kernel Module fuse…
    [ 2.970034] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [ 2.975935] systemd[1]: Starting File System Check on Root Device…
    [ 2.985766] systemd[1]: Starting Journal Service…
    [ 2.999602] systemd[1]: Starting Load Kernel Modules…
    [ 3.005862] systemd[1]: Starting Coldplug All udev Devices…
    [ 3.007260] fuse: init (API version 7.34)
    [ 3.022153] systemd[1]: Mounted POSIX Message Queue File System.
    [ 3.023969] systemd[1]: Mounted RPC Pipe File System.
    [ 3.025444] systemd[1]: Mounted Kernel Debug File System.
    [ 3.026558] systemd[1]: Mounted Kernel Trace File System.
    [ 3.030594] systemd[1]: Finished Restore / save the current clock.
    [ 3.039391] systemd[1]: Finished Create list of static device nodes for the current kernel.
    [ 3.049243] systemd[1]: [email protected]: Succeeded.
    [ 3.050855] systemd[1]: Finished Load Kernel Module configfs.
    [ 3.053691] systemd[1]: [email protected]: Succeeded.
    [ 3.055280] systemd[1]: Finished Load Kernel Module fuse.
    [ 3.067276] systemd[1]: Mounting FUSE Control File System…
    [ 3.076553] systemd[1]: Mounting Kernel Configuration File System…
    [ 3.083019] systemd[1]: Started File System Check Daemon to report status.
    [ 3.096867] systemd[1]: [email protected]: Succeeded.
    [ 3.098563] systemd[1]: Finished Load Kernel Module drm.
    [ 3.101622] systemd[1]: Finished Load Kernel Modules.
    [ 3.103314] systemd[1]: Mounted FUSE Control File System.
    [ 3.104566] systemd[1]: Mounted Kernel Configuration File System.
    [ 3.111604] systemd[1]: Starting Apply Kernel Variables…
    [ 3.181610] systemd[1]: Finished Apply Kernel Variables.
    [ 3.200733] systemd[1]: Finished File System Check on Root Device.
    [ 3.205844] systemd[1]: Starting Remount Root and Kernel File Systems…
    [ 3.314849] systemd[1]: Started Journal Service.
    [ 3.358889] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    [ 3.412945] systemd-journald[134]: Received client request to flush runtime journal.
    [ 3.417625] systemd-journald[134]: File /var/log/journal/fd32a8d28941455586c0c4ac29899718/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [ 4.395067] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [ 4.444771] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [ 4.460243] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [ 4.504075] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.509523] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [ 4.534507] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [ 4.534550] [vc_sm_connected_init]: start
    [ 4.547758] mc: Linux media interface: v0.10
    [ 4.549378] [vc_sm_connected_init]: installed successfully
    [ 4.652810] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.659998] videodev: Linux video capture interface: v2.00
    [ 4.662127] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
    [ 4.662980] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
    [ 4.719810] i2c i2c-22: Added multiplexed i2c bus 0
    [ 4.746893] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
    [ 4.777666] bcm2835_audio bcm2835_audio: card created with 8 channels
    [ 4.778704] i2c i2c-22: Added multiplexed i2c bus 10
    [ 4.792347] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.794038] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.808307] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.809852] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.826086] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [ 4.849424] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [ 4.871267] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [ 4.879291] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [ 4.880783] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [ 4.880824] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [ 4.880846] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [ 4.880865] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [ 4.880882] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [ 4.907735] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
    [ 4.938924] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
    [ 4.939555] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
    [ 4.940099] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
    [ 4.940133] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [ 4.940155] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [ 4.940227] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [ 4.940245] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [ 4.947292] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [ 4.953208] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [ 4.953282] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [ 4.957858] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [ 4.957879] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [ 4.957924] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [ 5.030544] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [ 5.030620] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [ 5.073791] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
    [ 5.073864] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
    [ 5.112004] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
    [ 5.121091] Registered IR keymap rc-cec
    [ 5.125358] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
    [ 5.125892] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
    [ 5.137657] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
    [ 5.137728] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
    [ 5.341686] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [ 5.386682] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
    [ 5.440352] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
    [ 5.442394] Registered IR keymap rc-cec
    [ 5.442743] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
    [ 5.448667] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    [ 5.511425] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
    [ 5.639974] brcmfmac: F1 signature read @0x18000000=0x15264345
    [ 5.666911] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [ 5.667985] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
    [ 5.719170] random: crng init done
    [ 5.719201] random: 7 urandom warning(s) missed due to ratelimiting
    [ 5.818479] usbcore: registered new interface driver brcmfmac
    [ 5.881776] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
    [ 5.905113] Registered IR keymap rc-cec
    [ 5.925994] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [ 5.926167] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [ 5.930738] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
    [ 5.933599] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
    [ 5.970698] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
    [ 6.533624] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
    [ 6.536563] Registered IR keymap rc-cec
    [ 6.554216] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
    [ 6.584062] dw9807_vcm: loading out-of-tree module taints kernel.
    [ 6.587888] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input3
    [ 6.658502] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
    [ 6.664817] Registered IR keymap rc-cec
    [ 6.665234] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
    [ 6.665496] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input4
    [ 6.671692] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
    [ 6.672133] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
    [ 6.672469] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
    [ 6.672757] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
    [ 6.673063] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
    [ 6.673324] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
    [ 6.673625] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
    [ 6.674595] arducam_64mp 10-001a: Device found Arducam 64MP.
    [ 6.680091] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [ 6.680339] vc4-drm gpu: [drm] Cannot find any crtc or sizes
    [ 6.700712] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
    [ 7.161440] 8021q: 802.1Q VLAN Support v1.8
    [ 7.211745] uart-pl011 fe201000.serial: no DMA platform data
    [ 7.347830] Adding 102396k swap on /var/swap. Priority:-2 extents:3 across:135168k SSFS
    [ 7.591604] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    [ 7.855456] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [ 7.856464] bcmgenet fd580000.ethernet eth0: Link is Down
    [ 11.935231] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [ 11.935272] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [ 12.958689] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [ 13.928700] Bluetooth: Core ver 2.22
    [ 13.928874] NET: Registered PF_BLUETOOTH protocol family
    [ 13.928889] Bluetooth: HCI device and connection manager initialized
    [ 13.928918] Bluetooth: HCI socket layer initialized
    [ 13.928937] Bluetooth: L2CAP socket layer initialized
    [ 13.928991] Bluetooth: SCO socket layer initialized
    [ 13.939030] Bluetooth: HCI UART driver ver 2.3
    [ 13.939132] Bluetooth: HCI UART protocol H4 registered
    [ 13.939262] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [ 13.939677] Bluetooth: HCI UART protocol Broadcom registered
    [ 14.254000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [ 14.254018] Bluetooth: BNEP filters: protocol multicast
    [ 14.254031] Bluetooth: BNEP socket layer initialized
    [ 14.264048] NET: Registered PF_ALG protocol family
    [ 31.711234] cam-dummy-reg: disabling
    I’ve googled for a solution, found nothing about resolution.
  8. What help do you need?
    Parameter or different driver to install so I can save 256mp images.
@hugodro
You CAN switch the interface to display full resolution for a single camera at a time, but have not tested how quickly this can be done. I had REALLY hoped we were going to be able to trigger all 4 cameras together at full res, unfortuantely looks like we would need 4x 64MP standalones, and 2x CM4 with I/O board, or 4x standard Raspberry PIs. Hopefully the switching speed is fast enough to get decent throughput - also worth trying the 2-up option. Even if thats 32MP each, still viable
I’m trying this, I’ve enabled i2c and installed i2c-tools and selected camera 0 only. I then try to take an image at 9152x6944 but I get:
[email protected]:~ $ libcamera-still -t 5000 --viewfinder-width 9152 --viewfinder-height 6944 -o pi_hawk_eye.jpg --autofocus
Preview window unavailable
[0:01:31.961702560] [754]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:01:31.967976306] [756]  WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:01:31.968090583] [756]  WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:01:31.968432583] [756] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:01:31.991371366] [756]  WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:01:31.992059346] [756] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:01:31.992255864] [756]  INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media2
[0:01:31.992938511] [754]  INFO Camera camera.cpp:1029 configuring streams: (0) 9152x6944-YUV420
[0:01:31.993337473] [756]  INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 9152x6944-SBGGR10_1X10 - Selected unicam format: 9152x6944-pBAA
[0:01:31.995995004] [756] ERROR V4L2 v4l2_videodevice.cpp:1211 /dev/video21[16:cap]: Unable to request 4 buffers: Cannot allocate memory
ERROR: *** failed to allocate capture buffers ***
My GPU mem is set at 256M:
[pi4]
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
gpu_mem=256
However I’m still getting buffer problems; if I run at 4624x3472, it works in that I get a 64MP image file but that is only with a 16MP viewfinder (I assume it is scaled up by the driver). Is there a way to get a true 64MP image from a camera? Ideally I’d like to take all 4 at 64MP and handle the huge image that comes back but it seems like this is not possible.
hi, @neil-bennziath-com
The saved 64mp image is the real 64mp, not enlarged by the driver.
The libcamera-still program stops the camera when saving the image, and starts the camera after resetting the configuration.
Thanks, I’m trying to understand - if the viewfinder height/width is 4624 x 3472; and the image is 9152 x 6944. How is this scaled; is do we have four areas on the sensor being taken up by one area on the viewfinder?
Thanks.
Regards,
Neil
