The command I am using to do it is sudo python3 rw_sensor.py -d 0 -r 12306 -v 500
I also tried different values other than 500 for exposure like 100.
but it doesn’t seem to change the exposure when I take a photo using this python script.
import cv2
import argparse
from utils import ArducamUtils
import RPi.GPIO as GPIO
import _thread
import uuid
import time
import v4l2
def fourcc(a, b, c, d):
return ord(a) | (ord(b) << 8) | (ord(c) << 16) | (ord(d) << 24)
def pixelformat(string):
if len(string) != 3 and len(string) != 4:
msg = "{} is not a pixel format".format(string)
raise argparse.ArgumentTypeError(msg)
if len(string) == 3:
return fourcc(string[0], string[1], string[2], ' ')
else:
return fourcc(string[0], string[1], string[2], string[3])
def show_info(arducam_utils):
_, firmware_version = arducam_utils.read_dev(ArducamUtils.FIRMWARE_VERSION_REG)
_, sensor_id = arducam_utils.read_dev(ArducamUtils.FIRMWARE_SENSOR_ID_REG)
_, serial_number = arducam_utils.read_dev(ArducamUtils.SERIAL_NUMBER)
print("Firmware Version: {}".format(firmware_version))
print("Sensor ID: 0x{:04X}".format(sensor_id))
print("Serial Number: 0x{:08X}".format(serial_number))
# for executing a thread to save the image.
def save_image(data):
cv2.imwrite("/home/dlinano/photos/imagetest" + str(uuid.uuid1()) + ".png", data)
print("finished execution")
# Initialize the camera
print("Initializing camera")
images = []
cap = cv2.VideoCapture(0, cv2.CAP_V4L2)
# set pixel format
if not cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter_fourcc('Y', '1', '6', ' ')):
print("Failed to set pixel format.")
arducam_utils = ArducamUtils(0)
# turn off RGB conversion
if arducam_utils.convert2rgb == 0:
cap.set(cv2.CAP_PROP_CONVERT_RGB, arducam_utils.convert2rgb)
# set width
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 4896)
# set height
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 3684)
ret, frame = cap.read()
print("Starting demo now! Press CTRL+C to exit")
print("Capture")
frame = arducam_utils.convert(frame)
_thread.start_new_thread(save_image, tuple([frame]))
I tried running the command before I initialize the camera in the script and after.
I am really new to using cameras this close to hardware where I am manually setting registers. Is it possible to adapt the code in the RPi section to do this?
What du you mean by “initialize” ? The camera is plugged on the MIPI port. I can get an image using OpenCV, I can read the register as you can see on my capture screen with :
v4l2-ctl --all
But it is just not possible to write a new value for any of the registers users should be able to control (exposure, gain ....).
Can you provide a code example to illustrate what you mean by “initialize”.
I can change the exposure but the process is really weird, I need to purge 6 frames and to change 6 times the exposure, if not the default exposure came back when reading the frame :
# -*- coding: utf-8 -*-
Created on Wed Oct 14 18:52:54 2020
@author: julien
import cv2
import subprocess
import time
Initializing the camera means to make the camera work, relative to the code, it is to open the camera and read a frame of image.
So you just need to do this:
cap.read() # or using cap.grap()
Modify the exposure here.
After modifying the exposure, there will be a certain number of frames that have not been modified. These frames are stored in the cache.
The default exposure also come back when camera is disconnected.
The camera does not store the last exposure value. When you disconnect or turn off the camera and turn it on again, the exposure value will be restored to the default value.
