Hi everyone. I have an Arducam B0200 UVC camera running on an ESP32-S3. The camera itself works fine in AMCap, so the hardware seems okay, but I can’t figure out how to get H.264 frames out of it. I’ve been following the paper instruction manual and I never got the H.264 part working. Does anyone know what H.264 software I need, or can someone point me to an example?
Thanks for reaching out. Could you check the document I sent you via private message? It covers the basic setup for the B0200. Let me know what you find once you’ve gone through it.
Sorry, I should have been clearer about the actual problem. The issue is specifically getting H.264 frames from the camera. It works in AMCap, so the camera is fine, but I need H.264 output. Can you give me an example of how to get H.264 frames? Honestly I just need the H.264 software.
Just so I’m on the same page: when you say “getting H.264 frames from the camera,” do you mean you want to write code to stream the camera in H.264 format? Or do you just need a working way to view and obtain the H.264 stream?
Yes, that’s correct. Our goal is to get the H.264 stream from the camera and then transfer it over a radio link. So we need an example or software for pulling H.264 frames from the camera. AMCap works but that doesn’t help us with H.264.
Unfortunately we don’t have any code examples that match that specific use case, getting the H.264 stream and transferring it over a radio link. What we can guarantee is that you can obtain the H.264 stream using our “H264 Preview” software. I’d suggest starting there to confirm the camera outputs H.264 correctly, and then the radio transfer part would need to be handled on your side.
