Purchased from here Arducam 1MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Four OV9782 Global Shutter Color Camera Modules and Camarray Camera HAT
B0331
Nvidia Jetson Orin Nano Dev Kit and Nvidia Jetson Xavier Nx board with seedstudio’s A206 Carrier board (should be compatible with the official dev carrier board design)
We followed the instruction here to connect 4 OV9782 cameras to the multicam array HAT board. Then the difference I made is that I have to connect the HAT board to Jetson Orin Nano’s camera0/1 socket using a 22pin FFC cable instead of the 22-to-15 pin cable provided by the camera kit since Orin Nano has a different camera port design.
- Problems you were having?
Right after I connect the MIPI cable, the cable start burning and I have to disconnect it right away to avoid any further hardware damage.
We don’t think this is a driver issue so we didn’t check the dmesg log.
We connected the array HAT board to Seedstudio’s A206 carrier board (designed for Xavier NX) which is a 15 pin port using the cable provided with the bundle and everything works. Since the major difference related to this issue between Xavier NX and Orin Nano board is the camera connection port, we looked into the carrier board specification for both and found the root cause of the burning:
Here is the camera connector pin description for Jetson Xavier Nx carrier board:
And the image below is the description for Orin Nano:
Where we can see for Xavier NX the first pin is GND and the last pin is for +3.3V, while this is reversed for Orin Nano. And when we make the direct connection between the array HAT board to orin nano’s camera board, we are actually connecting GND to +3.3V and +3.3V to GND and this causes the circuit shortcut which burned the cable.
- What help do you need?
Would like to know what’s the correct solution to connect the array HAT board to orin nano board.
