Arducam eShop -
B0371 -
Jetson (jetpack 5.1.1 i.e. kernel version L4T 35.3.1) -
Quick Start Guide - Arducam Wiki -
What handles do we have to control the camera settings?
v4l2-ctl
listed out a bunch of things but I could not find any doc from Arducam related to them
$ v4l2-ctl --list-ctrls -d /dev/video0
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
sensor_mode 0x009a2008 (int64) : min=0 max=4 step=1 default=0 value=0 flags=slider
gain 0x009a2009 (int64) : min=16 max=256 step=1 default=16 value=35 flags=slider
exposure 0x009a200a (int64) : min=13 max=683709 step=1 default=2495 value=33000 flags=slider
frame_rate 0x009a200b (int64) : min=2000000 max=10000000 step=1 default=10000000 value=9000000 flags=slider
sensor_configuration 0x009a2032 (u32) : min=0 max=4294967295 step=1 default=0 [22] flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=4294967295 step=1 default=0 [1026] flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=4294967295 step=1 default=0 [30][18] flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=4294967295 step=1 default=0 [30][36] flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=4294967295 step=1 default=0 [30][16] flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
preferred_stride 0x009a206e (int) : min=0 max=65535 step=1 default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=4 flags=read-only
My original problem:
The image from the cam seems “artificially sharpened”, see the edges below. This is actually harmful in my use case. I wonder if the sensor had some internal ISP applied? If so I would like to disable that
