How to assign a fixed unique identifier to a USB camera in Windows?
Hi everyone, I’m working with several UC-724 cameras (16MP Autofocus USB Camera with Microphone, IMX298 sensor) on Windows and I have a couple of questions:
  1. Is there a way to update the firmware on these cameras to the latest version? I want to make sure all our units are running the same firmware.
  2. More importantly — is there any way to assign a unique, fixed serial number or identifier to each camera? Right now, Windows seems to identify them differently depending on which USB port they’re plugged into, or even between sessions. This makes automated device management a nightmare because I can’t reliably tell which camera is which.
Looking for any tool or method to give each camera a persistent, recognizable ID. Thanks!
Good questions. Let me address both:
Regarding firmware updates — there is no firmware update available or necessary for the UC-724. The firmware hasn’t changed since the initial release, so every unit is already running the latest version. No action needed there.
As for serial numbers — yes, there is a dedicated Serial Number Tool that lets you configure a unique serial number and device name for each camera. Once written, the camera will present that identifier consistently across USB ports and reboots on Windows.
You can find the full step-by-step guide here:
https://docs.arducam.com/UVC-Camera/Serial-Number-Tool-Guide/#supported-usb-uvc-camera-module
Give it a try and let us know how it goes.
Thanks for the info on the serial number tool — I’ll be trying that shortly.
But I’ve run into another issue while doing some preliminary testing. I have several units of the exact same UC-724 model, and they’re not behaving consistently under the same conditions. Same lighting, same scene, same computer — but I’m getting different image quality results across units. Some look fine, others have noticeably different noise levels or color rendering.
Is there a way to factory reset these cameras? Maybe some units have settings from previous testing that are causing the inconsistency, and a full reset would bring them all to the same baseline. Any guidance would be appreciated.
A “factory reset” in the traditional sense doesn’t really apply to these camera modules. The camera sensor itself doesn’t have onboard non-volatile memory for storing settings — there’s nothing to reset. Whatever parameters are in play (exposure, gain, white balance, etc.) are typically managed by the host system’s UVC driver on a per-session basis.
The inconsistency you’re seeing between units could be either a software/firmware-level issue on certain units, or subtle hardware variance between individual camera modules.
To narrow this down, I’ll need a more detailed comparison between a “good” unit and a “bad” unit. Could you put together a report with the following?
  1. A clear description of the behavioral differences — be specific. For example: “Unit A shows low noise in low-light scenes, while Unit B has heavy red/blue color noise speckles under the exact same lighting conditions.”
  2. Side-by-side evidence — photos or short video clips from different units captured under identical conditions (same lighting, same scene, same host machine).
  3. Test conditions confirmation — verify that everything is truly identical across tests: same power supply, same USB port/cable, same host system and OS version.
Once we have that, we can dig deeper into what’s going on.
Quick update — I went ahead and tested the serial number tool (ArducamUVCSerialNumber_Formal.exe) and it worked great on the units I tried. I was able to change both the camera name and serial number without any issues.
Now here’s the thing: we’re moving toward production deployment and I need to automate this. Having to manually run the GUI tool on each camera isn’t going to scale. Is there any documentation or API/command-line interface that would let me programmatically change the camera name and ID from within our own software? Even just the raw UVC commands would work — I can implement the calls myself. I need to integrate this into our provisioning pipeline.
I understand the need for automation at scale, but unfortunately this isn’t something I can provide.
The serial number modification uses low-level proprietary UVC vendor commands that are specific to Arducam’s implementation. The ArducamUVCSerialNumber_Formal.exe utility is closed-source software, and the internal command details and source code cannot be shared externally.
For now, you’ll need to continue using the provided executable tool for all serial number and device name modifications. I know it’s not ideal for a fully automated pipeline, but the underlying protocol isn’t something we’re able to publish.
I’ve got a serious problem now. I was using ArducamUVCSerialNumber_Formal.exe to program serial numbers on a batch of our UC-724 cameras. It worked fine on most of them, but on one unit the write process failed partway through — and now that camera is basically dead.
Here’s what I’m seeing:
  • In Windows Device Manager, the camera now shows up as “Sonix Technology Co., Ltd.” instead of “Arducam_16MP”
  • The Windows Camera app throws error 0xA00F4240 (0x80004003) when I try to use it
  • The camera is detected as a USB device, but it’s not functional as a camera anymore
I’ve tried everything I can think of:
  • Unplugging and reconnecting the camera (multiple times)
  • Uninstalling and disabling the device in Device Manager
  • Attempting to rewrite the device info using the serial number tool (it doesn’t recognize the camera now)
  • Restarting the computer
  • Testing on a completely different PC
Nothing works. The camera is stuck showing up as “Sonix Technology Co., Ltd.” and is unusable.
Is there a recovery tool? Something that can reflash the UVC firmware or restore the factory descriptors? A way to reset the USB bridge controller? I’m hoping this isn’t a permanent brick.
What you’re describing is a known failure mode. When the serial number write operation fails on a unit, it can corrupt the UVC descriptor/identification data stored on the camera. The device then falls back to the underlying USB bridge chip manufacturer’s default identifier — in this case, “Sonix Technology Co., Ltd.” — and Windows no longer treats it as a valid camera.
Unfortunately there isn’t a publicly available recovery tool that can fix this. The descriptor corruption needs to be addressed at a low level.
I’ve sent you details via private message for a remote support session where we can diagnose and attempt to recover the bricked camera. Please check your messages — we’ll need to coordinate a time and I’ll need your AnyDesk ID to connect. There’s a booking link in the PM as well so you can pick a time slot that works for you (note: we’re UTC+8, and the 10 PM slot is for sales only, not support).
In the meantime, I’d recommend holding off on using the serial number tool on any additional units until we can investigate what went wrong with this one.
