For the same lens, the HFOV will increase as you go from smaller (1/4" ) to the larger (1/3.2") and larger still 1/3" sensors.
The roll-off in uniformity of illumination will typically be worse as the sensor size goes up, but if the lens was designed to be used with the larger sensors this shouldn’t be an issue, and probably won’t be noticeable.
The distortion is a fixed feature of the lens, but with smaller sensors as you’ll be using a smaller portion of the FOV any pincushion or barrel distortion effect will be less obvious. So most visible with 1/3" and least with 1/4"
