Thanks for your camera, it is outstanding. What I cannot do is enabling strobe output in order to drive flash.
I did found some post about setting registers 0x3b08, but it does not work, also IMX219 datasheet suggests other values, but I failed all of my attempts.
I hooked oscilloscope to strobe and ground hoping to see something, but no luck.
That’s really bad. So it means strobe pad is there for no reason? Do you think I can use GPIO used for IRCUT to somehow do the flashing? I can make camera led on and off so maybe it is worth trying…
Maybe you can custom our pivariety camera, we have evaluated and and generating stroboscopic signals via an external controller. For the detail about the custom, please refer to the [email protected]
