Having had a bit of a fun ride getting an ArduCam IMX519 16MP Autofocus camera working with Motion (link) on a Raspberry Pi 3B+, I thought I’d share what I did and a couple of discoveries:
I installed the latest version of Raspberry Pi OS (Bullseye Lite 32 bit - Debian 11.6) via the Raspberry Pi Imager tool. As the Pi I’m using is run headless, I also set up ssh etc. prior to writing the SD card image.
The kernel version on my Pi 3B+ is: 5.15.84-v7+ #1613 SMP Thu Jan 5 11:59:48 GMT 2023 armv7l GNU/Linux
I installed Motion 4.5.1-1 (latest revision at time of posting):
Install dependencies (I’m not sure this is necessary):
sudo apt install autoconf automake autopoint build-essential pkgconf libtool libzip-dev libjpeg-dev git libavformat-dev libavcodec-dev libavutil-dev libswscale-dev libavdevice-dev libwebp-dev gettext libmicrohttpd-dev
Download the software:
wget https://github.com/Motion-Project/motion/releases/download/release-4.5.1/bullseye_motion_4.5.1-1_armhf.deb
Install the installer:
sudo apt install gdebi-core
Install Motion:
sudo gdebi bullseye_motion_4.5.1-1_armhf.deb
Installing software for ArduCam IMX519: (see: Quick Start - Arducam Wiki)
(these steps are all as listed in the Quick Start Guide)
Add the following to /boot/config.txt:
camera_auto_detect=0
dtoverlay=imx519
Get the software:
Reboot
Run raspi-config to enable Glamour and select the GL driver:
sudo raspi-config
Advanced Options
Enable Glamor graphic acceleration
Reboot
sudo raspi-config
Advanced Options
Navigate to GL Driver
Select GL (Full KMS)
Reboot
Install the camera driver:
./install_pivariety_pkgs.sh -p imx519_kernel_driver_low_speed
Reboot
Edit /etc/motion/motion.conf:
The motion software runs the camera as a /dev/video0 device, so there are no MMAL settings needed. The only ‘funny’ is the default motion ‘input’ parameter needs changing from ‘-1’ to ‘0’ for the video streaming to work. This is done via the ‘video_params’ setting (ie)
video_params palette=17,input=0
I started with the following width/height settings. Unfortunately, this seems to max out the Pi 3B (load average 1.6), so I used the PiCamera V2 settings instead, which brought the load average down to 0.55. This needs further investigation as of course it means I can’t use the camera’s full resolution.
width 3840; height 2160 changed to: width 1640; height 1232
Motion is then run with the following command:
sudo libcamerify motion -n &
Getting autofocus to work was interesting.
Firstly, I had to install pip for ‘FocuserExample.py’ to work.
sudo apt install python3-pip
Then I downloaded the focus software:
git clone https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver.git
To run the software, change directory:
cd Arducam-Pivariety-V4L2-Driver/focus
If you run the software using the ArduCam instructions, the Python script fails with a ‘no autofocus’ message:
python3 FocuserExample.py -d /dev/v4l-subdev0
I then went down a rabbit hole following this posting (how-is-it-possible-to-get-autofocus-working-along-with-picamera2-for-imx519) which led me to attempt to remove python3-libcamera. In retrospect, this may not have been necessary as it doesn’t appear to have been installed anyway.
This didn’t fix the issue, so investigating further I found:
v4l2-ctl -l -d /dev/v4l-subdev0
doesn’t show autofocus but
v4l2-ctl -l -d /dev/v4l-subdev1
does
So I ran python3 FocuserExample.py -d /dev/v4l-subdev1 instead and manual focus now works.
I hope the above is useful to someone. Observations/comments welcome!
