Robotshop -
IMX477 -
Orin Nano (Jetpack 6.2/L4T 36.4.7) -
All of them from the Arducam website. Never got 12P21 to work until I downloaded a criver for L4T 36.4.4 and was able to get 12P21 by configuring the 24 pin CSI connector to IMX477 dual. -
Kernel updated L4T to 36.4.7 and now I’m unable to get the 12P21 resolution. I can switch the CSI connector to IMX477-C and get the 4K30 and 1080P60 to work, but I can’t get the 12P21. -
jetson-orin@jetsonorin-desktop:~$ sudo dmesg -T | egrep -i ‘imx477|camera|nvcsi|tegra-capture-vi|vi-output|i2c|csi|camrtc’
[Wed Oct 22 17:30:43 2025] SCSI subsystem initialized
[Wed Oct 22 17:30:43 2025] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[Wed Oct 22 17:30:43 2025] i2c_dev: i2c /dev entries driver
[Wed Oct 22 17:30:46 2025] tegra-i2c 3160000.i2c: Adding to iommu group 1
[Wed Oct 22 17:30:46 2025] tegra-i2c 3180000.i2c: Adding to iommu group 1
[Wed Oct 22 17:30:46 2025] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[Wed Oct 22 17:30:46 2025] tegra-i2c c240000.i2c: Adding to iommu group 1
[Wed Oct 22 17:30:46 2025] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[Wed Oct 22 17:30:46 2025] tegra-i2c c250000.i2c: Adding to iommu group 1
[Wed Oct 22 17:30:46 2025] i2c i2c-2: Added multiplexed i2c bus 9
[Wed Oct 22 17:30:46 2025] i2c i2c-2: Added multiplexed i2c bus 10
[Wed Oct 22 17:30:46 2025] i2c-mux-gpio bus@0:cam_i2cmux: 2 port mux on 3180000.i2c adapter
[Wed Oct 22 17:30:52 2025] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with 9-001a
[Wed Oct 22 17:30:52 2025] platform 13e00000.host1x:nvcsi@15a00000: Fixing up cyclic dependency with tegra-capture-vi
[Wed Oct 22 17:30:53 2025] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[Wed Oct 22 17:30:53 2025] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e00000.host1x:nvcsi@15a00000- bound
[Wed Oct 22 17:30:53 2025] imx477 9-001a: tegracam sensor driver:imx477_v2.0.6
[Wed Oct 22 17:30:54 2025] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx477 9-001a bound -
Everything short of flashing back to the previous kernel…
This is what I can get working…
jetson-orin@jetsonorin-desktop:~$ gst-launch-1.0 -q nvarguscamerasrc sensor-id=0 num-buffers=1 !
‘video/x-raw(memory:NVMM),width=640,height=480,framerate=30/1’ ! fakesink
CONSUMER: Waiting until producer is connected…
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
Camera index = 0
Camera mode = 1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Also tried this:
wget https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.3/install_full.sh 16
chmod +x install_full.sh
./install_full.sh -m imx477
But got this:
Kernel version: 5.15.148-tegra-36.4.7-20250918154033
Jetson type: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
- What help do you need?
I would like to get the 12P21 camera resolution to work (that’s why we chose these cameras, and they worked great until today)
