I am using an arducam OV9281 with the Arducam_Mipi drivers but reading a frame is slow.
RobotShop -
OV9281 -
Raspberry Pi 4b 8GB -
https://github.com/ArduCAM/MIPI_Camera/tree/master/RPI -
Reading an image from the camera works but it is too slow for our application (30 ms per frame) using the arducam_capture function. -
No hardware issues, only software -
Compared the speed output with the yavta application which is much faster (5 ms). -
A solution to have faster image reading using the arducam_mipi api.
I wonder if arducam_capture is slow in comparison to yavta because it reallocates memory on every frame capture.
Thanks,
Oliver
