Pi 4 Model B Rev 1.2 - 4GB
Linux raspberrypi 5.15.76-v8+ #1597 SMP PREEMPT Fri Nov 4 12:16:41 GMT 2022 aarch64 GNU/Linux
Running BullsEye
16mp Autofocus imx519 - UC-873 Rev C.
When updating/installing I get an error which indicates the install failed and the error needs to be reported:
Using wget -O install_pivariety_pkgs.sh https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/install_pivariety_pkgs.sh
to download install script.
Log from console:
./install_pivariety_pkgs.sh -p libcamera
Hardware Revision: c03112
Kernel Version: 5.15.76-v8+
OS Codename: bullseye
ARCH: aarch64
--2023-10-03 18:43:39-- https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/packages.txt
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/b3348f44-8b22-4085-a232-0d2e4cabbf06?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164340Z&X-Amz-Expires=300&X-Amz-Signature=71ad257032c35c83006c267ad00fffd0cb89964d8b3db4e2911a5d30043b16c1&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dpackages.txt&response-content-type=application%2Foctet-stream [following]
--2023-10-03 18:43:40-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/b3348f44-8b22-4085-a232-0d2e4cabbf06?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164340Z&X-Amz-Expires=300&X-Amz-Signature=71ad257032c35c83006c267ad00fffd0cb89964d8b3db4e2911a5d30043b16c1&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dpackages.txt&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.111.133, 185.199.108.133, 185.199.109.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.111.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2130 (2.1K) [application/octet-stream]
Saving to: ‘packages.txt’
packages.txt 100%[============================================================================================================================================>] 2.08K --.-KB/s in 0.002s
2023-10-03 18:43:40 (930 KB/s) - ‘packages.txt’ saved [2130/2130]
kernel:5.15.76-v8+
--2023-10-03 18:43:40-- https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/libcamera_links.txt
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/509766ce-689d-426c-8717-331c3fa90052?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164341Z&X-Amz-Expires=300&X-Amz-Signature=7f6d6063fb291f35155fe2942a77174ad04a152ee82a01bfa886bd36f9434e68&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dlibcamera_links.txt&response-content-type=application%2Foctet-stream [following]
--2023-10-03 18:43:41-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/509766ce-689d-426c-8717-331c3fa90052?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164341Z&X-Amz-Expires=300&X-Amz-Signature=7f6d6063fb291f35155fe2942a77174ad04a152ee82a01bfa886bd36f9434e68&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dlibcamera_links.txt&response-content-type=application%2Foctet-stream
Length: 7874 (7.7K) [application/octet-stream]
Saving to: ‘libcamera_links.txt’
libcamera_links.txt 100%[============================================================================================================================================>] 7.69K --.-KB/s in 0.01s
2023-10-03 18:43:41 (767 KB/s) - ‘libcamera_links.txt’ saved [7874/7874]
--2023-10-03 18:43:41-- https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/libcamera-v0.0.5/libcamera0_0_git20230724+ad9428b4-1_arm64.deb
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/e38bafa9-c952-442a-9542-b49520685407?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164341Z&X-Amz-Expires=300&X-Amz-Signature=f955202b166c9ea14e1d9ca68d142aea841b726087fe7dc24cc337701bec1c5e&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dlibcamera0_0_git20230724%2Bad9428b4-1_arm64.deb&response-content-type=application%2Foctet-stream [following]
--2023-10-03 18:43:41-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/e38bafa9-c952-442a-9542-b49520685407?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164341Z&X-Amz-Expires=300&X-Amz-Signature=f955202b166c9ea14e1d9ca68d142aea841b726087fe7dc24cc337701bec1c5e&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dlibcamera0_0_git20230724%2Bad9428b4-1_arm64.deb&response-content-type=application%2Foctet-stream
Length: 694516 (678K) [application/octet-stream]
Saving to: ‘libcamera0_0_git20230724+ad9428b4-1_arm64.deb’
libcamera0_0_git20230724+ad9428b4-1_arm64.deb 100%[============================================================================================================================================>] 678.24K 897KB/s in 0.8s
2023-10-03 18:43:43 (897 KB/s) - ‘libcamera0_0_git20230724+ad9428b4-1_arm64.deb’ saved [694516/694516]
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [242 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main armhf Packages [243 kB]
Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB]
Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
Fetched 1,179 kB in 2s (520 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
The following packages were automatically installed and are no longer required:
libboost-program-options1.74.0 raspinfo
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
libcamera-apps libcamera0
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 5,401 kB disk space will be freed.
(Reading database ... 94056 files and directories currently installed.)
Removing libcamera-apps (1.2.1-1) ...
Removing libcamera0:arm64 (0~git20230720+bde9b04f-1) ...
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
The following additional packages will be installed:
libcamera0
The following NEW packages will be installed:
libcamera0 python3-libcamera
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,016 kB of archives.
After this operation, 4,787 kB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230720+bde9b04f-1 [826 kB]
Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230720+bde9b04f-1 [190 kB]
Fetched 1,016 kB in 1s (772 kB/s)
Selecting previously unselected package libcamera0:arm64.
(Reading database ... 93909 files and directories currently installed.)
Preparing to unpack .../libcamera0_0~git20230720+bde9b04f-1_arm64.deb ...
Unpacking libcamera0:arm64 (0~git20230720+bde9b04f-1) ...
Replaced by files in installed package libcamera-dev (0.0.10) ...
Selecting previously unselected package python3-libcamera.
Preparing to unpack .../python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb ...
Unpacking python3-libcamera (0~git20230720+bde9b04f-1) ...
dpkg: error processing archive /var/cache/apt/archives/python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb (--unpack):
trying to overwrite '/usr/lib/python3/dist-packages/libcamera/__init__.py', which is also in package libcamera-dev 0.0.10
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
E: Sub-process /usr/bin/dpkg returned an error code (1)
Note, selecting 'libcamera0' instead of './libcamera0_0_git20230724+ad9428b4-1_arm64.deb'
The following packages will be upgraded:
libcamera0
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/695 kB of archives.
After this operation, 691 kB disk space will be freed.
Get:1 /home/ray/libcamera0_0_git20230724+ad9428b4-1_arm64.deb libcamera0 arm64 0~git20230724+ad9428b4-1 [695 kB]
apt-listchanges: Reading changelogs...
(Reading database ... 94009 files and directories currently installed.)
Preparing to unpack .../libcamera0_0_git20230724+ad9428b4-1_arm64.deb ...
Unpacking libcamera0:arm64 (0~git20230724+ad9428b4-1) over (0~git20230720+bde9b04f-1) ...
Setting up libcamera0:arm64 (0~git20230724+ad9428b4-1) ...
--2023-10-03 18:44:05-- https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/libcamera-v0.0.5/libcamera-dev_0_git20230724+ad9428b4-1_arm64.deb
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/7d02c6e8-37df-48cb-8b5e-eb9d73b4b221?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164406Z&X-Amz-Expires=300&X-Amz-Signature=ca8fd4c5bb8fea49873d55867b86cabf941ee0d2ff20e4fef0d35c2e99ef6265&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dlibcamera-dev_0_git20230724%2Bad9428b4-1_arm64.deb&response-content-type=application%2Foctet-stream [following]
--2023-10-03 18:44:06-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/353945933/7d02c6e8-37df-48cb-8b5e-eb9d73b4b221?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20231003%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20231003T164406Z&X-Amz-Expires=300&X-Amz-Signature=ca8fd4c5bb8fea49873d55867b86cabf941ee0d2ff20e4fef0d35c2e99ef6265&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=353945933&response-content-disposition=attachment%3B%20filename%3Dlibcamera-dev_0_git20230724%2Bad9428b4-1_arm64.deb&response-content-type=application%2Foctet-stream
Length: 24384 (24K) [application/octet-stream]
Saving to: ‘libcamera-dev_0_git20230724+ad9428b4-1_arm64.deb’
libcamera-dev_0_git20230724+ad9428b4-1_arm64.deb 100%[============================================================================================================================================>] 23.81K --.-KB/s in 0.03s
2023-10-03 18:44:06 (920 KB/s) - ‘libcamera-dev_0_git20230724+ad9428b4-1_arm64.deb’ saved [24384/24384]
Note, selecting 'libcamera-dev' instead of './libcamera-dev_0_git20230724+ad9428b4-1_arm64.deb'
The following packages will be DOWNGRADED:
libcamera-dev
0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
E: Packages were downgraded and -y was used without --allow-downgrades.
freeglut3 libglu1-mesa libturbojpeg0 python3-libcamera python3-opengl python3-pidng python3-piexif python3-simplejpeg python3-v4l2
Suggested packages:
libgle3
freeglut3 libglu1-mesa libturbojpeg0 python3-libcamera python3-opengl python3-picamera2 python3-pidng python3-piexif python3-simplejpeg python3-v4l2
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,210 kB/1,400 kB of archives.
After this operation, 10.2 MB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-pidng arm64 4.0.9-1 [25.4 kB]
Get:2 http://deb.debian.org/debian bullseye/main arm64 freeglut3 arm64 2.8.1-6 [119 kB]
Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-piexif all 1.1.3-1 [17.4 kB]
Get:4 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-simplejpeg arm64 1.6.4-1 [70.0 kB]
Get:5 http://deb.debian.org/debian bullseye/main arm64 libglu1-mesa arm64 9.0.1-1 [146 kB]
Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.12-2 [50.4 kB]
Get:8 http://deb.debian.org/debian bullseye/main arm64 libturbojpeg0 arm64 1:2.0.6-4 [158 kB]
Get:9 http://deb.debian.org/debian bullseye/main arm64 python3-opengl all 3.1.5+dfsg-1 [610 kB]
Fetched 1,210 kB in 1s (823 kB/s)
Selecting previously unselected package freeglut3:arm64.
(Reading database ... 93957 files and directories currently installed.)
Preparing to unpack .../0-freeglut3_2.8.1-6_arm64.deb ...
Unpacking freeglut3:arm64 (2.8.1-6) ...
Selecting previously unselected package libglu1-mesa:arm64.
Preparing to unpack .../1-libglu1-mesa_9.0.1-1_arm64.deb ...
Unpacking libglu1-mesa:arm64 (9.0.1-1) ...
Selecting previously unselected package libturbojpeg0:arm64.
Preparing to unpack .../2-libturbojpeg0_1%3a2.0.6-4_arm64.deb ...
Unpacking libturbojpeg0:arm64 (1:2.0.6-4) ...
Preparing to unpack .../3-python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb ...
dpkg: error processing archive /tmp/apt-dpkg-install-c050Tg/3-python3-libcamera_0~git20230720+bde9b04f-1_arm64.deb (--unpack):
Selecting previously unselected package python3-opengl.
Preparing to unpack .../4-python3-opengl_3.1.5+dfsg-1_all.deb ...
Unpacking python3-opengl (3.1.5+dfsg-1) ...
Selecting previously unselected package python3-pidng.
Preparing to unpack .../5-python3-pidng_4.0.9-1_arm64.deb ...
Unpacking python3-pidng (4.0.9-1) ...
Selecting previously unselected package python3-piexif.
Preparing to unpack .../6-python3-piexif_1.1.3-1_all.deb ...
Unpacking python3-piexif (1.1.3-1) ...
Selecting previously unselected package python3-simplejpeg.
Preparing to unpack .../7-python3-simplejpeg_1.6.4-1_arm64.deb ...
Unpacking python3-simplejpeg (1.6.4-1) ...
Selecting previously unselected package python3-v4l2.
Preparing to unpack .../8-python3-v4l2_0.3.2-1_all.deb ...
Unpacking python3-v4l2 (0.3.2-1) ...
Selecting previously unselected package python3-picamera2.
Preparing to unpack .../9-python3-picamera2_0.3.12-2_all.deb ...
Unpacking python3-picamera2 (0.3.12-2) ...
Unknown error, please send the error message to [email protected]
