I’m trying to use the Low Light 2MP IMX462 STARVIS Camera but I’m having issues.
I went through the quick start guide and have done the following:
and added dtoverlay=arducam-pivariety
to /boot/firmware/config.txt
I have:
$ dmesg | grep -E "imx477|imx219|arducam"
[ 8.694301] arducam-pivariety 10-000c: firmware version: 0x10002
But when i use the camera, I get:
[0:12:20.090178436] [1913] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+246-9fb4698e-dirty (2024-02-27T06:28:07+00:00)
[0:12:20.122404793] [1916] WARN CameraSensorProperties camera_sensor_properties.cpp:274 No static properties available for 'arducam-pivariety'
[0:12:20.122461941] [1916] WARN CameraSensorProperties camera_sensor_properties.cpp:276 Please consider updating the camera sensor properties database
[0:12:20.132822722] [1916] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'rpi/vc4'
[0:12:20.164066693] [1916] ERROR RPI pipeline_base.cpp:825 Failed to load a suitable IPA library
[0:12:20.164127082] [1916] ERROR RPI vc4.cpp:217 Failed to register camera arducam-pivariety 10-000c: -22
What could it be? Thanks!
I changed the /boot/firmware/config.txt
file with dtoverlay=imx462
which seems to have gotten me a bit farther, but I’m still running into issues.
I now have this:
$ libcamera-hello
[0:01:46.243577090] [1787] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+246-9fb4698e-dirty (2024-02-27T06:28:07+00:00)
[0:01:46.309512610] [1790] INFO RPI vc4.cpp:455 Registered camera /base/soc/i2c0mux/i2c@1/imx290@1a to Unicam device /dev/media0 and ISP device /dev/media1
[0:01:46.309637684] [1790] INFO RPI pipeline_base.cpp:1169 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Preview window unavailable
Mode selection for 960:540:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 1125
SRGGB10_CSI2P,1920x1080/0 - Score: 1375
SRGGB12_CSI2P,1280x720/0 - Score: 125
SRGGB12_CSI2P,1920x1080/0 - Score: 375
Stream configuration adjusted
[0:01:46.313408774] [1787] INFO Camera camera.cpp:1183 configuring streams: (0) 960x540-YUV420 (1) 1280x720-SRGGB12_CSI2P
[0:01:46.316690734] [1790] INFO RPI vc4.cpp:619 Sensor: /base/soc/i2c0mux/i2c@1/imx290@1a - Selected sensor format: 1280x720-SRGGB12_1X12 - Selected unicam format: 1280x720-pRCC
[0:01:46.369713394] [1790] ERROR V4L2 v4l2_videodevice.cpp:1906 /dev/video0[14:cap]: Failed to start streaming: Input/output error
Has anyone ever had this issue?
Dion
April 10, 2024, 3:27am
3
This is the correct way to enable the camera driver.
I think you do not install the libcamera from the Arducam branch. Please follow the commands below to install it:
I went through a re-installation of everything and it looks like it’s working fine now!
I’m using a Waveshare base board B and when following the official guide I disabled camera_auto_detect
, which I guess seems to have made the cameras unavailable. Now, I kept camera_auto_detect=1
and it’s working fine. Thanks.
