Exposure for Quad-Camera (OV9782) does not work properly
    uctronics
    Arducam 1MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Four OV9782 Global Shutter Color Camera Modules and Camarray Camera HAT
    Raspberry Pi 4
    OpenCV: Capture Frames from V4L2-Compliant Camera on Raspberry Pi (Python) - Arducam
  5. Problems you were having?
    -I use python script for frame capturing and use subprocess.call([‘v4l2-ctl -d /dev/video0 -c exposure=50’],shell=True) to set exposure.
    a) Exposure settings applied only if before and right after subprocess.call script makes frame capturing
    ret, frame1 = cap1.read()
    b) If the same script will run once again exposure setting does not work and picture looks like default exposure value (681) was used. Despite this ‘v4l2-ctl -d /dev/video0 -all’ shows exposure=50.
    please see pic exposure-50 — ImgBB - with exposure 50
    please see at second attempt to run exposure-like-681 — ImgBB
The only workaround I found is reboot, then script can be run one time with customized exposure.
c) Сolor distortion os observed. Red objects looks blue on the picture
see example here Test-outside-exposure-50 — ImgBB
    frame capturing before and after exposure set, reboot.
  2. What help do you need?
    For the issue described in point a) - any other elegant solution can be applied?
    For the issue described in point b) - what workaround/solution can be applied to do not make reboot. E.g. some re-init/reset by v4l2-ctl
    For the issue described in point c) is there any filter whic can be switched off/removed?
    Most critical points are b and c
    Thanks
    Python script
    import numpy as np
    import cv2
    import subprocess
    import time
def camera_capture(frames_to_skip, max_frames):
#Initialisation
cap1 = cv2.VideoCapture(0) #, cv2.CAP_V4L)
if not cap1.isOpened():
print(‘Error open camera array. Exiting’) #Write to log and exit
#Set resolution for camera array
cap1.set(3,5120)
cap1.set(4,800)
#subprocess.call([‘v4l2-ctl -d /dev/video0 -c exposure=50’],shell=True) #it does not make any effect if set exposure here
ContinueFlag=True
i=0
#Set exposure required immediate capturing of frame to take in to effect
#Cycle to capture frames given in frames_to_skip parameter to skip frames which still use “old” exposure settings
while(i < frames_to_skip):
if not ret:
print (‘Unable to read frame from camera array’) #Write to log and exit
i+=1
i=0
while(i < max_frames):
ret1, frame1 = cap1.read()
cv2.imwrite(f’C1{str(i)}c100{time.strftime("%Y%m%d-%H%M%S")}.jpg’, frame1, [int(cv2.IMWRITE_JPEG_QUALITY), 100])
i+=1
cap1.release()
cv2.destroyAllWindows()
#End of camera_capture
#Main routine
camera_capture(3, 5)
Printout before second attempt to run script
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.4.79-v7l+ #4 SMP Thu Dec 10 10:08:29 CST 2020 armv7l GNU/Linux
pi@raspberrypi:~ $ v4l2-ctl -d /dev/video0 --all
Driver Info:
Driver name : unicam
Card type : unicam
Bus info : platform:fe801000.csi
Driver version : 5.4.79
Capabilities : 0x85a00001
Video Capture
Metadata Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Media Driver Info:
Model : unicam
Serial :
Media version : 5.4.79
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x01000004 : 0: Sink
Link 0x02000007: from remote pad 0x1000002 of entity ‘arducam 10-000c’: Data, Enabled, Immutable
Priority: 2
Video input : 0 (Camera 0: ok)
Format Video Capture:
Width/Height : 5120/800
Pixel Format : ‘BA81’ (8-bit Bayer BGBG/GRGR)
Field : None
Bytes per Line : 5120
Size Image : 4096000
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
User Controls
                   exposure 0x00980911 (int)    : min=1 max=65535 step=1 default=681 value=50
                       gain 0x00980913 (int)    : min=0 max=15 step=1 default=1 value=1
               trigger_mode 0x00981901 (bool)   : default=0 value=0
                 frame_rate 0x00981906 (int)    : min=5 max=46 step=1 default=30 value=30
Hi @eserray,
Did you find any solution to set the exposure and not getting back to the default value??
