ESP32-S3 with ArduCam 2MP mini
    Arducam Official Website
    Arducam Mini Module UNO mega2560 Board
    Working with a ESP32-S3 devkitC-1 board
    Tried running the ArduCAM library examples for Arduino UNO, but got no results
  5. Problems you were having?
    I have been trying to connect the camera to my esp32-s3 board, I am able to detect the camera but am not getting any input feed.
  6. What help do you need?
Firstly, Is it possible to use ArduCam Mini module to work with ESP32-S3 devkit-C1? I have tried numerous connections for MISO, MOSI etc. but am still not able to get the input stream
One year now. Did you figure this out? Arducam has the absolute garbage support. Time to look at other better brands
Hi @simardeep27 @Fakeer
Sorry for the reply taking forever :smiling_face_with_tear:
We got this setup(ESP32-S3 devkitC-1 board + Arducam 2MP mini) working this morning. Here are the steps to access the camera on ESP32-S3.
1. Hardware Connection
2. Software configuration
  1. Search esp32 and Arducam_mini, then install them.
  2. Click on File → Examples → Arducam_mini → mini → ArduCAM_Mini_2MP_Plus_VideoStreamig
  3. Click on Tools → Board → esp32 → ESP32S3 Dev Module
  4. Click on Tools → Port → COM21(choose the indeed port from your side).
  5. Open memorysaver.h
  6. Select hardware platform
  7. Click on Upload and wait for the upload process to finish
  8. Open serial monitor → choose 921600 baud
    If the cable connection is all right, the serial monitor will print “ACK CMD SPI interface OK.END” and “ACK CMD OV2640 detected.END”
3. Capture
  1. Open ArduCAM_Host_V2, select the specified port and 921600 Baudrate and click on open
  2. click on Capture
  3. Preview
Hi @Fakeer @simardeep27
Looking forward to your response :slight_smile:
@Dion The camera we are testing is this one
with this Arduino Nano ESP32 board
https://docs.arduino.cc/tutorials/nano-esp32/cheat-sheet/
Hardware connection
CS      D10
MOSI    D11
MISO    D12
SCK     D13
VCC     3.3V
GND     GND
SDA     A5
SCL     A4
Running this example:
Result
ACK CMD SPI interface Error! END
You can try to connect Pin CS to D4.
Please note in the code in my reply that the CS value is changed. We had tried with
CS = D10
and also
CS = 21
Will also try CS = D4 and CS = 7 and let you know shortly. Thanks for replying
@Dion Pls see this is mentioned in the documentation
