UCTRONICS
Arducam 12MP MINI IMX477 Synchronized Stereo Camera Bundle Kit for Raspberry Pi
Raspberry Pi 4
manual
No
**---@raspberrypi**:**~/MIPI_Camera/RPI $** ./arducamstill -t 0 -m 2
Open camera...
Found sensor imx477 at address 1A
mode: 0, width: 4056, height: 3040, pixelformat: BA81, desc: (null)
mode: 1, width: 2028, height: 1520, pixelformat: BA81, desc: (null)
mode: 2, width: 1920, height: 1080, pixelformat: BA81, desc: (null)
mode: 3, width: 8112, height: 3040, pixelformat: BA81, desc: Used for Arducam synchronized stereo camera HAT, 4056x3040 * 2
index: 0, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1606, current: 1000
mmal: mmal_vc_port_enable: failed to enable port vc.ril.isp:out:0(I420): ENOSPC
mmal: mmal_port_enable: failed to enable port vc.ril.isp:out:0(I420)(0x1f5ac20) (ENOSPC)
mmal: Failed to enable isp outptu.
mmal: Failed to enable isp output.
mmal: Failed to enable camera
set resolution status = 2
**---@raspberrypi**:**~/MIPI_Camera/RPI $** vcgencmd get_camera
supported=1 detected=1
Tried Bullseye and Buster. Reset cabling. Trying every Google result I could find.
What am I doing wrong?
