For this reason I would like to upgrade to latest Jetpack release, but the lacking of a driver from RPi HQ camera (IMX477) is a showstopper. Is there a workaround that can be used in the meantime?
Hi Edward,
Thank you for the fast response.
I was aware of the “pin-configuration” (“jetson-io”), but I thought I still needed to install a driver. Thank you for the clarification. I will test and verify that it works.
Thanks.
I see that I can detect the IMX477 without the additional driver. However, I also see that the “one more resolution” that you add, is 4032 x 3040… which is exactly the resolution we have been using in our application. And I believe we need to rely on that.
I don’t know what dtb file is used for this carrier board. I have only adapted it in the official development kit so far. In general, third-party carrier boards only support their specified camera models.
