Amazon
Raspberry Pi 3B
The cameras work fine
I recently designed my own PCB for the first time (which was exciting), and to start out I figured I’d do something simple but still something I could put to good use. I ended up starting on a RasPi camera switcher. The idea behind it was to link up the pins of all 8 camera inputs and the camera output, then use relays to direct power to only 1 camera at a time. I figured if none of the other cameras got power it wouldn’t matter if they were connected to signal.
The schematics of the PCB can be found here: https://cdn.discordapp.com/attachments/656770973852237844/867238888003469322/CameraSwitcher.zip
I made the design and went ahead and ordered the PCB and components, which recently arrived. I soldered up the relays, the output, and 2 of the camera inputs. Needless to say, it didn’t work.
Some things I’ve figured out so far:
It works with a single camera plugged in
The relays make a sound
Giving power to the relay pauses the video feed same as unplugging… but the light on the camera stays on
I went over the board with a multimeter
I taped over certain pins of the 2nd camera connector to see what pins are causing the issue. I got success with this:
but even this it was buggy.
Any way possible, even if I have to approach this from a whole new angle
