Amazon market -
B0371C -
Raspberry Pi Zero 2W -
Arducam site pages -
I’ve already used with full satisfaction IMX219, and IMX447 from Arcuam motorized AF cameras with Raspberry Pi Zero 2W.
For AF I’ve modified a demo project in which “/usr/sbin/i2cset” command is used to move lens motor and get fine focus value sampling contrast of images.
For IMX219 and IMX447 I use:
I2C_BUS = 10
I2C_CHIP_ADDR = 0x0c
and all works fine, but with IMX519 I’ve get the error message:
Could not set address to 0x0c: Device or resource busy
Are BUS and CHIP ADDR changed for IMX519 ?
qem@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] Machine model: Raspberry Pi Zero 2 W Rev 1.0
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000000bc00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: ARM erratum 843419
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 112896
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i smsc95xx.macaddr=B8:27:EB:53:AF:E4 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyAMA0,115200 console=tty1 root=PARTUUID=4edf3bed-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 163092K/458752K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 33516K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 39744 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] Root IRQ handler: bcm2836_arm_irqchip_handle_irq
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000391] Console: colour dummy device 80x25
[ 0.001390] printk: console [tty1] enabled
[ 0.001483] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001551] pid_max: default: 32768 minimum: 301
[ 0.001745] LSM: Security Framework initializing
[ 0.002035] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.002097] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.004060] cgroup: Disabling memory control group subsystem
[ 0.007359] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.007409] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.007703] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.008060] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.008735] rcu: Hierarchical SRCU implementation.
[ 0.008774] rcu: Max phase no-delay instances is 1000.
[ 0.010610] EFI services will not be available.
[ 0.011416] smp: Bringing up secondary CPUs …
[ 0.013156] Detected VIPT I-cache on CPU1
[ 0.013334] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.015132] Detected VIPT I-cache on CPU2
[ 0.015270] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.017057] Detected VIPT I-cache on CPU3
[ 0.017198] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.017432] smp: Brought up 1 node, 4 CPUs
[ 0.017597] SMP: Total of 4 processors activated.
[ 0.017633] CPU features: detected: 32-bit EL0 Support
[ 0.017667] CPU features: detected: 32-bit EL1 Support
[ 0.017704] CPU features: detected: CRC32 instructions
[ 0.017901] CPU: All CPU(s) started at EL2
[ 0.017952] alternatives: applying system-wide alternatives
[ 0.020591] devtmpfs: initialized
[ 0.045664] Enabled cp15_barrier support
[ 0.045753] Enabled setend support
[ 0.046124] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.046202] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.059837] pinctrl core: initialized pinctrl subsystem
[ 0.061309] DMI not present or invalid.
[ 0.062383] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.074432] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.074883] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.076462] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.076663] audit: initializing netlink subsys (disabled)
[ 0.077119] audit: type=2000 audit(0.076:1): state=initialized audit_enabled=0 res=1
[ 0.078184] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.078318] cpuidle: using governor menu
[ 0.079044] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.079369] ASID allocator initialised with 32768 entries
[ 0.079657] Serial: AMBA PL011 UART driver
[ 0.097472] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.113274] platform 3f801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/imx519@1a
[ 0.120717] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:52:42, variant start
[ 0.124738] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.137543] KASLR enabled
[ 0.193770] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.200430] SCSI subsystem initialized
[ 0.200842] usbcore: registered new interface driver usbfs
[ 0.200980] usbcore: registered new interface driver hub
[ 0.201110] usbcore: registered new device driver usb
[ 0.201760] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.202162] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.202638] pps_core: LinuxPPS API ver. 1 registered
[ 0.202677] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.202748] PTP clock support registered
[ 0.204560] vgaarb: loaded
[ 0.205773] clocksource: Switched to clocksource arch_sys_counter
[ 0.207361] VFS: Disk quotas dquot_6.6.0
[ 0.207505] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.207838] FS-Cache: Loaded
[ 0.208138] CacheFiles: Loaded
[ 0.222693] NET: Registered PF_INET protocol family
[ 0.223073] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.225162] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.225240] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.225308] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.225416] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.225641] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.225907] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.225981] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.226338] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.227412] RPC: Registered named UNIX socket transport module.
[ 0.227457] RPC: Registered udp transport module.
[ 0.227493] RPC: Registered tcp transport module.
[ 0.227527] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.227583] PCI: CLS 0 bytes, default 64
[ 0.230323] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.230787] kvm [1]: IPA Size Limit: 40 bits
[ 0.232643] kvm [1]: Hyp mode initialized successfully
[ 2.015659] Initialise system trusted keyrings
[ 2.016379] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 2.029817] zbud: loaded
[ 2.034613] NFS: Registering the id_resolver key type
[ 2.034690] Key type id_resolver registered
[ 2.034727] Key type id_legacy registered
[ 2.034932] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.034980] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.037185] Key type asymmetric registered
[ 2.037232] Asymmetric key parser ‘x509’ registered
[ 2.037382] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.037975] io scheduler mq-deadline registered
[ 2.038022] io scheduler kyber registered
[ 2.047667] simple-framebuffer 1eaa9000.framebuffer: framebuffer at 0x1eaa9000, 0x151800 bytes
[ 2.047746] simple-framebuffer 1eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
[ 2.051536] Console: switching to colour frame buffer device 90x30
[ 2.056495] simple-framebuffer 1eaa9000.framebuffer: fb0: simplefb registered!
[ 2.066669] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 2.072626] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.075760] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 2.081813] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.104549] brd: module loaded
[ 2.120817] loop: module loaded
[ 2.123905] Loading iSCSI transport class v2.0-870.
[ 2.133571] usbcore: registered new interface driver r8152
[ 2.135721] usbcore: registered new interface driver lan78xx
[ 2.137764] usbcore: registered new interface driver smsc95xx
[ 2.140392] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.872005] Core Release: 2.80a
[ 2.873869] Setting default values for core params
[ 2.875725] Finished setting default values for core params
[ 3.078080] Using Buffer DMA mode
[ 3.079856] Periodic Transfer Interrupt Enhancement - disabled
[ 3.081661] Multiprocessor Interrupt Enhancement - disabled
[ 3.083517] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.085329] Dedicated Tx FIFOs mode
[ 3.092030] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = ffffffc008459000 dma = 0x00000000cc000000 len=9024
[ 3.097157] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.105130] dwc_otg: Microframe scheduler enabled
[ 3.105198] WARN::hcd_init_fiq:497: MPHI regs_base at ffffffc008065000
[ 3.108267] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.109871] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.111500] dwc_otg 3f980000.usb: irq 74, io mem 0x00000000
[ 3.113096] Init: Port Power? op_state=1
[ 3.114680] Init: Power Port (0)
[ 3.116784] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.120049] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.121819] usb usb1: Product: DWC OTG Controller
[ 3.123537] usb usb1: Manufacturer: Linux 6.1.21-v8+ dwc_otg_hcd
[ 3.125259] usb usb1: SerialNumber: 3f980000.usb
[ 3.128125] hub 1-0:1.0: USB hub found
[ 3.129924] hub 1-0:1.0: 1 port detected
[ 3.132840] dwc_otg: FIQ enabled
[ 3.132860] dwc_otg: NAK holdoff enabled
[ 3.132876] dwc_otg: FIQ split-transaction FSM enabled
[ 3.132908] Module dwc_common_port init
[ 3.133722] usbcore: registered new interface driver uas
[ 3.135609] usbcore: registered new interface driver usb-storage
[ 3.137682] mousedev: PS/2 mouse device common for all mice
[ 3.146143] sdhci: Secure Digital Host Controller Interface driver
[ 3.147774] sdhci: Copyright(c) Pierre Ossman
[ 3.150261] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.154493] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.156660] hid: raw HID events driver (C) Jiri Kosina
[ 3.158606] usbcore: registered new interface driver usbhid
[ 3.160291] usbhid: USB HID core driver
[ 3.162381] bcm2835_vchiq 3f00b840.mailbox: there is not valid maps for state default
[ 3.172368] NET: Registered PF_PACKET protocol family
[ 3.174315] Key type dns_resolver registered
[ 3.178373] registered taskstats version 1
[ 3.180149] Loading compiled-in X.509 certificates
[ 3.183219] Key type .fscrypt registered
[ 3.184908] Key type fscrypt-provisioning registered
[ 3.213063] uart-pl011 3f201000.serial: there is not valid maps for state default
[ 3.215736] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.217609] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 99, base_baud = 0) is a PL011 rev2
[ 3.242050] Indeed it is in host mode hprt0 = 00021501
[ 3.245101] printk: console [ttyAMA0] enabled
[ 3.433830] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.447703] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.451853] Indeed it is in host mode hprt0 = 00001101
[ 3.454307] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.658586] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 3.668441] sdhost: log_buf @ 000000006fbdab9a (c2f76000)
[ 3.668772] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.726091] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.728032] usb 1-1: Product: USB 2.0 Hub
[ 3.746687] of_cfs_init
[ 3.751271] hub 1-1:1.0: USB hub found
[ 3.756059] of_cfs_init: OK
[ 3.757613] hub 1-1:1.0: 4 ports detected
[ 3.787820] mmc0: host does not support reading read-only switch, assuming write-enable
[ 4.201820] usb 1-1.4: new high-speed USB device number 3 using dwc_otg
[ 4.213065] mmc0: new high speed SDHC card at address b368
[ 4.450789] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
[ 4.464734] mmcblk0: mmc0:b368 USD00 29.5 GiB
[ 4.468126] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.613929] usb 1-1.4: Product: USB 10/100 LAN
[ 4.613938] mmcblk0: p1 p2
[ 4.614798] mmcblk0: mmc0:b368 USD00 29.5 GiB
[ 4.615886] usb 1-1.4: Manufacturer: Realtek
[ 4.637673] usb 1-1.4: SerialNumber: 00E04C360396
[ 4.654317] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 4.663693] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 4.786488] EXT4-fs (mmcblk0p2): recovery complete
[ 4.795478] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 4.807678] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.825836] usb 1-1.4: reset high-speed USB device number 3 using dwc_otg
[ 4.835227] devtmpfs: mounted
[ 4.852722] Freeing unused kernel memory: 4160K
[ 4.859811] Run /sbin/init as init process
[ 4.865800] with arguments:
[ 4.865817] /sbin/init
[ 4.865835] with environment:
[ 4.865847] HOME=/
[ 4.865864] TERM=linux
[ 5.068201] r8152 1-1.4:1.0: skip request firmware
[ 5.107730] r8152 1-1.4:1.0 eth0: v1.12.13
[ 5.523429] systemd[1]: System time before build time, advancing clock.
[ 5.805288] NET: Registered PF_INET6 protocol family
[ 5.815136] Segment Routing with IPv6
[ 5.820711] In-situ OAM (IOAM) with IPv6
[ 5.915994] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 5.946146] systemd[1]: Detected architecture arm64.
[ 5.971572] systemd[1]: Set hostname to .
[ 6.232518] uart-pl011 3f201000.serial: no DMA platform data
[ 7.092206] systemd[1]: Queued start job for default target Multi-User System.
[ 7.128404] systemd[1]: Created slice system-getty.slice.
[ 7.140649] systemd[1]: Created slice system-modprobe.slice.
[ 7.152570] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.165203] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 7.177546] systemd[1]: Created slice User and Session Slice.
[ 7.188712] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.202068] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.216197] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.233054] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.244227] systemd[1]: Reached target Paths.
[ 7.253619] systemd[1]: Reached target Slices.
[ 7.263055] systemd[1]: Reached target Swap.
[ 7.273677] systemd[1]: Listening on Syslog Socket.
[ 7.290194] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.302696] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.316172] systemd[1]: Listening on Journal Audit Socket.
[ 7.327839] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.340330] systemd[1]: Listening on Journal Socket.
[ 7.354267] systemd[1]: Listening on udev Control Socket.
[ 7.365839] systemd[1]: Listening on udev Kernel Socket.
[ 7.377065] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 7.410545] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.429166] systemd[1]: Mounting RPC Pipe File System…
[ 7.447595] systemd[1]: Mounting Kernel Debug File System…
[ 7.466453] systemd[1]: Mounting Kernel Trace File System…
[ 7.477830] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 7.501653] systemd[1]: Starting Restore / save the current clock…
[ 7.521121] systemd[1]: Starting Set the console keyboard layout…
[ 7.541405] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 7.571948] systemd[1]: Starting Load Kernel Module configfs…
[ 7.591527] systemd[1]: Starting Load Kernel Module drm…
[ 7.612594] systemd[1]: Starting Load Kernel Module fuse…
[ 7.629345] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.659462] systemd[1]: Starting File System Check on Root Device…
[ 7.692433] fuse: init (API version 7.37)
[ 7.733266] systemd[1]: Starting Journal Service…
[ 7.761263] systemd[1]: Starting Load Kernel Modules…
[ 7.781496] systemd[1]: Starting Coldplug All udev Devices…
[ 7.813387] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.826539] systemd[1]: Mounted RPC Pipe File System.
[ 7.839535] systemd[1]: Mounted Kernel Debug File System.
[ 7.852228] systemd[1]: Mounted Kernel Trace File System.
[ 7.866488] systemd[1]: Finished Restore / save the current clock.
[ 7.882543] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 7.902391] systemd[1]: [email protected]: Succeeded.
[ 7.912891] systemd[1]: Finished Load Kernel Module configfs.
[ 7.921933] i2c_dev: i2c /dev entries driver
[ 7.934660] systemd[1]: [email protected]: Succeeded.
[ 7.945025] systemd[1]: Finished Load Kernel Module drm.
[ 7.959225] systemd[1]: [email protected]: Succeeded.
[ 7.970378] systemd[1]: Finished Load Kernel Module fuse.
[ 7.984514] systemd[1]: Finished Load Kernel Modules.
[ 8.031420] systemd[1]: Mounting FUSE Control File System…
[ 8.049467] systemd[1]: Mounting Kernel Configuration File System…
[ 8.079855] systemd[1]: Started File System Check Daemon to report status.
[ 8.107022] systemd[1]: Starting Apply Kernel Variables…
[ 8.126481] systemd[1]: Mounted FUSE Control File System.
[ 8.140186] systemd[1]: Finished File System Check on Root Device.
[ 8.153102] systemd[1]: Mounted Kernel Configuration File System.
[ 8.195226] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.229570] systemd[1]: Finished Apply Kernel Variables.
[ 8.247414] systemd[1]: Started Journal Service.
[ 8.438494] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 8.552105] systemd-journald[144]: Received client request to flush runtime journal.
[ 8.596130] systemd-journald[144]: File /var/log/journal/6b721b1de7884ceb950a81456657cb04/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 10.176593] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.179650] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 10.179710] [vc_sm_connected_init]: start
[ 10.183017] [vc_sm_connected_init]: installed successfully
[ 10.213194] mc: Linux media interface: v0.10
[ 10.335740] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.403221] videodev: Linux video capture interface: v2.00
[ 10.533088] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.542962] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.563703] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.578743] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.582412] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.607279] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.609142] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 10.609970] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 10.615311] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 10.616024] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 10.616099] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 10.616137] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 10.616168] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 10.616198] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 10.633383] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 10.634878] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 10.635638] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 10.636223] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 10.636282] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 10.636321] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 10.636354] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 10.636386] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 10.636799] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 10.647987] i2c i2c-11: Added multiplexed i2c bus 0
[ 10.650888] i2c i2c-11: Added multiplexed i2c bus 10
[ 10.663229] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 10.663333] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 10.667508] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 10.667601] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 10.673480] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 10.673599] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 10.677420] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 10.677513] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 10.723509] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 10.723622] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 11.291423] Console: switching to colour dummy device 80x25
[ 11.310276] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 11.325018] Registered IR keymap rc-cec
[ 11.326342] rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 11.326738] input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 11.330498] vc4_hdmi 3f902000.hdmi: ‘dmas’ DT property is missing or empty, no HDMI audio
[ 11.330697] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 11.331382] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 11.331975] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.332519] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.333060] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.333481] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 11.374347] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 11.389569] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 12.222831] ak7375 10-000c: supply vio not found, using dummy regulator
[ 12.257103] imx519 10-001a: Device found is imx519
[ 12.257522] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 12.871183] 8021q: 802.1Q VLAN Support v1.8
[ 13.049708] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 13.389608] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.430646] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 13.464351] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 13.782816] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.784138] r8152 1-1.4:1.0 eth0: carrier on
- What help do you need?
How to control focus motor position in IMX519 using /usr/sbin/i2cset -y … command
