Could not open device node /dev/video0. ToF
I followed the official tutorial and got the following results.
open ***WARNING*** Could not open device node /dev/video0. Please check for permissions.
initialization failed
I can see some similar reports but could not find a solution.
What I did:
  • Auducam-Pivariety Driver update
    sudo apt install arducam-pivariety-sdk-dev
  • check /boot/config.txt
    dtoverlay=arducam-pivariety
  • does the driver exist
    /boot/overlays/arducam-pivariety.dtbo
  • check dmesg
[   10.479222] arducam-pivariety 10-000c: pivariety_read: Reading register 0x103 failed
[   10.479244] arducam-pivariety 10-000c: probe failed
Hi
Please provide hte info of your Raspberry Pi and OS, additionally, you also need to attach the config file here(cat /boot/config.txt)
Thank you for your reply.
I use a Raspberry Pi 4 Model B(4GB RAM)
OS info:
$lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 11 (bullseye)
Release:	11
Codename:	bullseye
config file:
$cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
dtoverlay=vc4-fkms-v3d
arm_boost=1
gpu_mem=128
camera_auto_detect=0
Best Regards.
Hi
You seem not to refer to a correct guidance.
Delete this sentence in the config file and then follow the link below to install relevant dependencies:
https://docs.arducam.com/Raspberry-Pi-Camera/Tof-camera/Getting-Started/#using-the-tof-camera-on-raspberry-pi
