Hey everyone, I’m having trouble with my Arducam T2 camera. It seems like the firmware image on the device got corrupted somehow — the camera is basically non-functional right now. When I plug it in, it’s not being recognized properly and none of the capture utilities can talk to it. Has anyone run into this before? I’m guessing I need to re-flash the image but I’m not sure where to get the correct files.
Hi there — sorry to hear about the trouble. That does sound like a corrupted firmware image, especially if the device isn’t enumerating at all. Before we jump to re-flashing, can you describe what was happening right before this started? Any interrupted firmware updates, power loss during operation, or did it just suddenly stop working out of nowhere? Also, what OS are you on and which capture software were you using?
I was actually trying to update the firmware when it happened — the USB cable got bumped mid-write and after that the camera just went dark. Really kicking myself here. I’m on Windows 10 and was using the Arducam utility at the time. Device Manager shows it as an unknown USB device now, so the bootloader might still be reachable but Windows doesn’t know what to make of it.
Alright, that explains it — an interrupted flash will absolutely leave the firmware in a corrupted state. The good news is that if Device Manager is still detecting something on the USB bus, the bootloader is likely intact and you should be able to recover. The root cause here is clear: the image on the device is incomplete/corrupt from the interrupted write, so re-flashing with a known-good image is the way forward.
Here’s what you need to do — the official Arducam T2 image files are hosted on SourceForge. Head over to:
Download the latest firmware package for the T2 from there. Once you have it, you’ll want to put the camera into bootloader mode (usually by holding down the button on the board while plugging it in) and then use the Arducam flashing utility to write the image. The tool should be able to detect it even if Windows has it listed as unknown — the bootloader uses a standard USB descriptor. Let us know how it goes.
Thanks for the detailed walkthrough! The SourceForge link had exactly what I needed. I grabbed the latest T2 image package, held the button during plug-in to force bootloader mode, and the flashing utility picked it up right away. Flash completed successfully and the camera is back to life. For anyone who finds this later — definitely make sure your USB connection is solid before starting a firmware update. Lesson learned the hard way.
