I would like to connect the B04232 IMX462 module to a Raspberry Pi5:
Because both the B0423 Camera, AND the Pi5 have 22 pin connectors, I have purchased the CB023 150mm 22pin to 22pin camera cable (different side contacts) :
Is this the correct cable to use?
I am concerned I might inadvertently reverse the connections and damage the camera or Pi. The Pi does not even indicate which is Pin 1 so it’s difficult to check.
Do you plan to expand your connection guide page(s) to include connections to Raspberry Pi 5?
Thank you,
regards,
Daniel
